The Processing Stations tab allows you to create and set up processing stations (machining instructions). You can also export and import processing stations.
The Processing Station menu has a variety of commands.
Each Processing Station row can be selected by a single left-click. Double left-clicking will open a new window to edit the selected station in the user interface. The user can select multiple rows while holding Ctrl + left-click to pick and choose only the rows desired. Additionally, the user can hold shift while selecting multiple rows, and all the rows in-between will be selected.
After selecting the row(s), you want to modify, click the appropriate command button to make the modifications.
A standard search bar is available at the bottom of each tab.
The search bar will enable the user to locate the desired command or property with ease.
