ASSOCPLINE Machine Token
Microvellum uses machine tokens to identify the type and frequency of machining operations necessary to construct your products.
ASSOCPLINE
The Associative Polyline Token was created to facilitate the use of parametric polylines where two parts touch. The token can be used to guide machining along a specific route on the part's surface, using nine parameters for precise control.
An example of ASSOCPLINE being used on the treads of this staircase causing machining to be made on the Right Stringer part.
Moving the Stringer 100mm to the right shows that the machining is being generated by the Associative Polyline Machine Token from the Staircase's Tread, but since the parts are not in contact, no machining is being generated on the Stringer's face.
Parameter Overview
Here are the details of each parameter for this token.
ASSOCPLINE (Associative Polyline Machining Token)
We use the word ‘ASSOCPLINE’ to identify this token. Followed by a numbered edge to apply the token. In the example below, ‘ASSOCPLINE’ identifies the token and ‘4’ is the edge or face number.
Example: "ASSOCPLINE4"
Parameter 1: Vector Locations
Enter the X, Y, and Z coordinates of each vector of the routing sequence. Each point should be separated by a semi-colon. Each group of points should be separated by a pipe.
Parameter 2: Bulge List
Enter the bulge for each vector, 0 for a straight-line route. Separate each value with a semi-colon. If the entry is left blank, all vectors will be straight.
Parameter 3: Feed Speeds
If you want to control the feed speed of the machine on a per vector basis, make a semi-colon separated list with the feed speed of each vector listed. If the entry is left blank, the feed speed in the material file will be used. If no feed speed is found in the material file, the feed speed in the tool file will be used.
Parameter 4: Options
This parameter provides seven options. Separate each value with a semi-colon. If the entry is left blank, all default option settings will be used. With the first option, enter a 1 if the token is for machine code only. Enter a 2 if the token is for drawing purposes only. Enter a 0 (the default) if the token is used for both. For the second option, enter a 1 if you want the polyline to be drawn as a region or enter a 0 (the default) if you don't (Valid for closed polylines only). For the third option, enter a 1 if you want the first vector to be treated as a lead-in, meaning that it will be ignored for drawing purposes. Otherwise, enter 0 (the default). For the fourth option, enter a 1 if you want the last vector to be treated as a lead-out, meaning that it will be ignored for drawing purposes. Otherwise, enter 0 (the default). For the fifth option, enter a number that represents the sequence priority of the route. 1 is the highest priority and 99 is the lowest priority. With a value of 0, the sequence will be determined automatically. For the sixth option enter a value that will be passed to the tool file to control the route angle. For the seventh option enter a value that will be passed to the tool file for the angle depth for the route. A tool file must be configured to support options 6 and 7.
Parameter 5: Offset|Rotation
This parameter can contain two groups of points that should be separated by a pipe. For the first group of points, enter an X, Y, and/or Z offset from the values in parameter 1. Each point should be separated by a semi-colon. For the second group of points enter the X center, Y center, and rotation angle. Each point should be separated by a semi-colon. All the points in parameter 1 will first be offset and then rotated about the center point by the rotation angle specified.
Parameter 6: Profile File Name
If you want to assign a profile cutter to the token, enter the drawing name here.
Parameter 7: Tool Number
The tool number.
Parameter 8: Tool Offset
The offset of the router bit.
Parameter 9: Penetration Value
The amount the part penetrates the associated panel. Positive values will penetrate the associated part, negative values will be away from the associated part.
    • Associative Polyline from Holes Machining Token
      Create a token that will be assigned to an edge of a part, add a drill hole to that edge, and then apply a route to an associated face of another part. PLINEFROMHOLES Parameter 1 - Horizontal Hole Locations. "The dimension from the edge of the panel ...
    • EDGEARRAY Machine Token
      EDGEARRAY Machine Token Microvellum uses machine tokens to identify the type and frequency of machining operations necessary to construct your products. This article explains the Associative Edge Machining Array (EDGEARRAY) token.  Description There ...
    • CAMLOCK Machine Token
      Microvellum uses machine tokens to identify the type and frequency of machining operations necessary to construct your products.  One of these is the associative CAMLOCK token we use for creating the machining necessary to assemble your products with ...
    • Understanding Machine Tokens
      Understanding Machine Tokens To view the machining tokens for a part, select the part from the parts list and click on the Machining Tab under the Parts tools. All machining operations are contained in machine tokens. There are machine tokens that ...
    • Associative Hardware Tutorial
      This document demonstrates how to apply associative hardware to a product designed with Microvellum Toolbox. The tutorial will add the following hardware to the doors of a 2-door base cabinet: • Hinges • Double Touch Latch • Lock • Elbow Catch • ...
    • Adding a Font to Toolbox
      This article will explain the process of adding new fonts to Toolbox, both in drawing space and the Report Designer. Toolbox offers an array of fonts for users to customize their text in reports, documents, and drawings. New fonts can be added to the ...
    • Toolbox Release Notes | Build 25.1.0505.641
      The following release notes apply to Toolbox build 25.1.0505.641. Project Workbook Permissions Fix An issue was reported and resolved regarding the permissions of employee access to project factory workbooks. Users who do not have authorization to ...
    • The Microvellum Client Portal
      When logging into Microvellum’s Client Portal, several features are available to help ease the purchasing and management of Microvellum products, the ability to find accurate information in a convenient and timely manner, as well as keep track of ...
    • Toolbox Release Notes | Build 25.1.0421.641
      The following release notes apply to Toolbox build 25.1.0421.641 Drilling Coordinate Fix Fig. 1: Drilling G-code with correct coordinates (left) and an extra erroneous set of coordinates (right). An issue was sometimes occurring when processing parts ...
    • Microvellum Foundation Library Release Notes | Build 25.0418
      The following release notes apply to Microvellum Foundation Library build 25.0418. Additions Added a new Cost Based Estimating Report, “Shop Quote Optimized Option”. Instead of using the square footage plus waste, this will use the actual optimized ...
