An expression is made up of variables, functions, and field values from databases. A value can be calculated and either printed or displayed in a report.
If you know the programming language of a report, you can include code when calculating the value of an expression. Use curly braces (“{“ and “}”) to separate code from other text. When utilized, the result of a calculation will be converted into a string.
The result of this expression in the report:
There is no limit to the number of code insertions permitted in an expression.
The result in the report:
Nesting of code sections in an expression is not permitted. As an example, the following expression will result in the calculation failing:
