This document catalogs all versions of the Microvellum Foundation Library released between the years of 2021-2024. This encompasses builds 20.1201 to 24.0624 (current).
To download the Foundation Library in one of the builds listed in this document, visit the
Foundation Library Downloads Page. To learn more information about the Microvellum Foundation Library, or any of the individual builds from the year 2023 and onward, visit Microvellum's community and watch Microvellum's monthly
Product Engineering Reviews.
Year of 2024
This section lists all of the Foundation Library builds that released in the year of 2024.
Microvellum Foundation Library Release Notes | Build 24.0624
The following release notes apply to Microvellum Foundation Library, Build 24.0624
Additions
- Added additional sample Generic Five Piece solid wood door styles:
- Raised Panel 5pc with Applied Molding
- Mitered Solid Raised Panel 5pc
- Mitered Haunched Solid Raised Panel 5pc
- Mitered with Applied Molding Raised Panel 5pc
- Mitered Inset Panel 5pc
- Mitered Inset Beaded Panel 5pc
- Plank
- Plank w Slab Molding
- Added legacy “Cal Door” Door Library with 49 different Door Styles and Four Door Types (new Door Wizard)*:
- Cal Door Mitered Solid
- Cal Door Mitered Inset
- Cal Door Cope N Stick Solid
- Cal Door Cope N Stick Inset
- Added Blum 95 deg Overlay Blind Corner Hinges
- Added 64 & 167 heights to the Hafele Alto Slim
- Added a “Post Laminate” option to the Extruded Countertop Products
- Modified the Access Panel subassembly insert. Added a visible prompt to control the lip thickness.
- Added enhancements & features to the Extruded Die Wall products:
- Extruded Die Walls will now perform better when extruding along a polyline a with non-blended radius.
- Extruded Die Wall products along a blended radius can now be segmented via the prompts
- Added “Bay Position” hidden prompt to all drawer subassemblies. This can be used in reporting to designate which drawer it is for assembly. Bay Position comment added to all drawer bottoms and wood drawer sub front parts.
- Added nine new global variables to better control which Nailers the user requires:
- "Use Top Nailer Base"
- "Use Center Nailer Base"
- "Use Bottom Nailer Base"
- "Use Top Nailer Tall"
- "Use Center Nailer Tall"
- "Use Bottom Nailer Tall"
- "Use Top Nailer Upper"
- "Use Center Nailer Upper"
- "Use Bottom Nailer Upper"
- Added new global variable to control whether Hardware is included within the Flatshot dynamic product image feature.
- "Flatshot Hardware"
Resolutions General
- Restored the "Slab Molding" feature within the Solid Wood Door subassembly. Added missing molding profile drawings.
- Resolved graphical rotation issues with Tab Pulls that affected 2D elevation and section views.
- Resolved an issue with handle location when using a top shadowline only with a drawer bank cabinet.
- Resolved an issue with toe kick assembly option in Any Angle cabinets.
- The Base 2 Bay Drawer has been rebuilt from the Master 2 Bay Horizontal Cabinet to resolve some issues with the shadowline feature.
- Resolved an issue in corner cabinets when using shelf standards.
- Resolved an issue when using the global variable “Extend Sides to Floor”. This will no longer affect Upper cabinets.
- Selecting the global “Face Frame Miter FE Joint” will now force the Applied Panel FF to ignore "G!Face_Frame_Outside_Overlay_at_FE" and align with the mitered face frame.
- Resolved a 2D plan view draw token issue for Transition Angle Cabinet FF products.
- Resolved an issue with Horizontal Opening Splitter FF when adding Shelf ADJ to a bay.
- The back in all Face Frame Cabinets will now be placed correctly in the Z origin and size correctly when selecting no bottom.
Microvellum Foundation Library Release Notes | Build 24.0607
The following release notes apply to Microvellum Foundation Library, Build 24.0607
Additions
- Added additional features to the ADA Sink Angled Frame:
- Option to turn on Mounting Rails for the Angled Panel (and toe kick). Fastening method have been included.
- Hardware options have been modified to include fastening hardware to attach the angled panel to either a side or mount to a rail.
- Hardware position control prompts for the new hardware have been added for (X,Y) position along with lift off clearance.
- LookUpTableHorizontalMountHwr added to easily include user added hardware that will update the dropdown list of hardware and modify control values.
- Angled_Panel_Bottom_Reveal now works correctly and defaults to 0 for a flush Angled Panel to the edge of the carcass.
- Added additional hardware mounting options to the ADA Sink Angled Frame:
- Side Mounts:
- Keku EH Suspension Fitting
- Keku EHS Suspension Fitting
- Button-fix type 2
- SH 325 Zero Side Mount
- Rail Mounts:
- Button-fix type 1
- Button-fix type 3
- SH 227 Galaxy
- SH 350 Lock
- SH 400 NZ Clip
- Added additional functionality for grain matching products and door/drawer fronts together:
- Setting product item numbers to a value over 100 will trigger a new feature where the system will create perfect grain containers grouping doors & drawer fronts with matching item numbers (101.1, 101.2, 101.3).
- 2D elevation tokens added to help identify the grouping of perfect grain containers.
- New global variables added:
- "Split Drawers From Doors"
- "Split Double Width Cabinets"
- "Allow Grain Matching Across Multiple Products"
- "Show Perfect Grain ID on Elevation"
- Added additional global variables to control the Item Number positions for Counter Top and Toe Kick products:
- "Countertop ItemNumberX2DElv"
- "Countertop ItemNumberZ2DElv"
- "Countertop ItemNumberX3D"
- "Countertop ItemNumberY3D"
- "Countertop ItemNumberZ3D"
- "Toe Kick ItemNumberX2DElv"
- "Toe Kick ItemNumberZ2DElv"
- "Toe Kick ItemNumberX3D"
- "Toe Kick ItemNumberY3D"
- "Toe Kick ItemNumberZ3D"
- Added additional Blum Aventos HK Top options for “Chipboard Screw” machining.
- Within the Toe Kick Base product, screw construction has been added to the top of the sleepers into the cleats as well as machining from the front and back of the cleats into the front and back rails. We have also added in the"G!Dado_Minimum_Width" variable to add DADOs.
- Added a new report “Product Detail Report w Bays”. This report will display more information typically needed for designer cabinets with multiple bays.
- Added the ability to drop cabinet backs to the floor (when not captured). Added new global variable "G!Extend_Backs_To_Floor".
- Added prompts to the Tall Pullout Pantry. When selecting Horizontal Handles you now have the option to have centered Horizontal Handles. When unselecting Horizontal Handles you now have an option to have the handle on the left or right side of the face panel.
- Added help text warning messages for Base 1 Drawer Waste Bin product (and others). If the cabinet's inside width, height, or depth does not accommodate the correct size for the selected Pullout, the message will appear on the 2D plan view of the product.
Modifications
- Modified all appliance products to better differentiate appliance opening size vs actual appliance size. For example, a dishwasher may require 24” opening, but the appliance is actually 23.875”.
- Improvements made to the Door and Drawer Front Fabrication report. Door Styles will now display. Also removed subassemblies that were not actually doors from appearing.
- Magic Corner hardware for blind corner cabinets renamed to Magic Corner II to match manufacture’s specs.
- Extruded Countertop – The HeightAboveFloor formula has been updated to align with the standard Base Cabinet height.
Resolutions General
- Resolved an issue with many drawer systems’ drawer bottom part sizes when using “Back Over Bottom” option. Recommend verifying your particular drawer system drawer depths are matching your expected sizes. Also verify the “Back Over Bottom” selection is set to your desired option.
- Resolved a formula issue inside Base 1 Door Sink With False Front that was introduced in the previous update. Finished Faces will now display correctly.
- Resolved numerous hardware graphics issues wherein the graphics were not scaling properly for imperial scale users.
- Resolved a 2D elevation issue with Countertop With Waterfall Ends product.
- Resolved an issue with the rotation of the handle on the 2d elevation drawing for the left bi-fold doors.
- Resolved an issue when using Tall Wall Oven with Shadowline.
- “Adj/Fixed Shelf Qty” prompts will now remain visible when using “Division with Adj Shelves”.
- Resolved an issue when using Blum HF lift up hardware within Wall Oven cabinets. The calculation for the position of the lift mech in the component doors sub has been updated to look at the opening size, not the size of the overall cabinet.
- Resolved a Z location issue for certain drawer types inside the Component Drawers subassembly.
- Resolved an issue with “Base 1 Drawer Waste Bin” products where waste bin pullout types in the subassembly were not automatically being set when product is added.
- Resolved an issue in “Upper Open End Cabinet”. Adj shelf holes will now line up when selecting Right Hand option.
- Resolved an issue with “Scribe Filler With Cleats” option when using different thickness material for the fillers.
- Global variable “Draw Hardware Blocks For Pullouts” will no longer control wood drawers. They will use “Draw Hardware Blocks For Slides”.
- Resolved an issue where extra AutoCAD scales were being added to the drawing whenever a dwg block (such as hardware) was brought in from a product. All dwg blocks have been purged of unnecessary scales.*
Additions/Resolutions Face Frame Cabinetry*
- Resolved a cabinet issue with the internal height calculation when using the “Add Center Shelf” option. This was introduced from the previous update and has now been corrected.
- Resolved an issue when selecting a cabinet Finished End and also Applied End on the same side. Parts will no longer be in the same space.
- Resolved an issue with door heights when selecting Top Facia and deselecting Intermediate Rails.
- Resolved issues with Base Transition Angle Cabinet FF. Product has been rebuilt from Master Transition Angle Cabinet FF.
Additions/Resolutions Office Furniture Expansion*
- Added the Office Desk - 1 Piece Top and Office Desk - 2 Piece Top products each with a shaped cutout in the corner and a bow shape on the front.
- Added the 3-piece Top Desk product with a corner leg configuration.
- Added scallop cutout options to desks and worktops used for back edge cable management.
- Added Cabinet Connector Holes option to all office furniture cabinet products.
- Simplified the office furniture cabinet products that were using two back parts used to transpose the part orientations and grain directions. This can now be done within the MV processing stations, so the extra parts were removed.
- Corrected a part thickness issue inside Standard Hob.
Additions/Resolutions Closet/Wardrobe Expansion
- Resolved an issue with Closet Drawers with Single Hanging product. Top Fixed Shelf will now be in the correct location when activated.
Microvellum Foundation Library Release Notes | Build 24.0520
The following release notes apply to Microvellum Foundation Library, Build 24.0520
Additions
- Added a new product, the “Extruded Master Countertop”. Four other extruded countertop products have been replaced with a new version based on this product. Many new features have been added into this enhanced extruded product (Toolbox 24.1.0416 or newer required for some new features):
- Connector hardware (toggle bolts) available.
- Buildup options.
- Backsplash options.
- Offset from Polyline variable.
- Position of product Left or Right of line.
- Countertop front edge detail options.
- Supports recalculation of geometry with product prompt depth changes (without the need to extrude from polyline again).
- Supports additional more complex polylines such as non-blended radius conditions.
- More features planned for future enhancements.
- Added Galvin Prime Slim Drawers. (No Graphics) (AU/NZ Market only)
- Added Furnware Group SYMETRA Drawers. (No Graphics) (AU/NZ Market only)
- Added slot cutouts for aluminum file bars in wood drawers.
- Added the ability to associate drilling screw holes to thin backs as well as thick backs. New global variable added “Screw Construction Regular Backs”.
- Added a new global variable “Door Rounding” used with a FLOOR function to round down the width and height of all door & drawer front parts.
- Grain Direction & Perfect Grain Container prompts have been added to the MV Profile Door and the Solid Wood Door subassemblies.
- Added new features to the ADA Sink Angled Frame product:
- Angled Frame with Toe Kick.
- Inset or Overlay Angled Panel.
- Finished Front, Finished Sub Front, or Sub Front.
- Added horizontal parts to create an optional enclosed bottom.
- Inside and outside radius parameters for the angled polyline cut.
- Prompt layout has been changed and will most likely continue to be refined in the next update as we gather additional feedback.
Modifications
- Modified the rear notch on the Front Stretchers to match the Rear Stretchers. The notch will now look at "G!Dado_Small_Part_Notch_Distance_To_Rear_Edge".
- Replaced many M2U functions throughout the library with UCN to prevent undesirable default imperial values from appearing. For example, instead of “=M2U(1,Accuracy)" which results in “0.03937” inches, we now use “=UCN(0.0312,1)” or “=UCN(0.0625,1)” which provides fractional values (1/32” or 1/16”) more commonly used by imperial users.
![](https://static.zohocdn.com/zoho-desk-editor/static/images/file.png)
These changes will not affect metric users. However, for imperial users, some default variables might change slightly in new library installs. M2U values that match specific hardware specifications have not been changed.*
- Changed how the globals “Back Width Adjustment” & “Back Height Adjustment” behave when they are both used together with Full Applied backs. The back sizes will adjust, however the X & Z origins will remain flush with the left side and bottom of cabinet. This will prevent any associative screw hole machining issues.
- All drawers updated to use "G!Drawer_Bottom_Hole_Depth" for the Bottom Hole Depth instead of a fixed value.
- Wood Drawers now use "G!Drawer_Box_Dowel_Target_Spacing" instead of "VLOOKUP(PARTMACHINEY(),G!LookupTableTargetSpacingDowels,2,TRUE)"
- Default value for "G!Drawer_Box_Dowel_Target_Spacing" changed to "UCN(3.7795,96)"
- For Solid Wood Drawer fronts, Stiles and Rails will now be the same width by default.*
Resolutions General
- Resolved the Solid Wood Door "Add Finish Label" prompt to match Finished Faces subassembly. The prompt will now correctly display one label per product when global “Finish Label Condition” = “Product”.
- Resolved an issue with all Finished Face/MV Profile Door/Solid Wood Door subassemblies referencing an incorrect column in the Door Wizard "D!LookUpTableDoorStyle" table. Various parameters such as “Default Top Rail Width” will now correctly reference the Door columns when it’s a door and the Drawer columns when it’s a drawer front.*
- Resolved an issue with the Hettich WingLine Guide hardware graphics. Should no longer cause issues with the Flatshot feature.
- Added a 140mm option to the Hafele Alto drawer system for the NZ region.
- Resolved a Hinge Plate issue for right hand doors in corner diagonal cabinets.
- Resolved an issue with Base Under Counter Oven product that was affecting the bottom Facia.
- For Solid Wood Drawer fronts, corrected "Use Single Solid Wood Front SA" so it will not reference the Min Door Height (column 13) when it's a drawer front.
- Resolved an issue in certain subassembly insert components that were incorrectly displaying Fixed Shelf Qty prompts when bay 2 was set to Adj Shelf.
- Resolved a machining issue in all Corner Cabinet’s right-side backs. Dado tokens were missing a value for parameter 5 Dado Thickness. This seemed to only affect users using a Saw.
- Resolved an issue when using Buyout Doors. Default buyout material used is no longer zero thickness.
- Added the option for Interior Components to reference Frame Opening vs Box Opening. When selected, certain interior inserts will reference the Face Frame Opening Height instead of the Interior Cabinet Height, allowing them to be centered in the frame opening.
- Resolved an issue within some Office Drawer Cabinets.
Microvellum Foundation Library Release Notes | Build 24.0419
The following release notes apply to Microvellum Foundation Library, Build 24.0419
Additions
- Added the new Blum SPACE STEP system. This can be activated within the “Toe Kick Assembly” construction option prompt in certain base & tall cabinet products.
- Added a new drawer system, the Harn Alunan T.
- Added 9 new Lamello Cabineo X hardware Edge Array options:
- Lamello Cabineo X Flush 12
- Lamello Cabineo X Flush 8
- Lamello Cabineo X Flush Shelf Support 5mm
- Lamello Cabineo X Flush With Cover Cap 12
- Lamello Cabineo X Flush With Cover Cap 8
- Lamello Cabineo X Flush With Cover Cap Shelf Support 5mm
- Lamello Cabineo X Overlay 12
- Lamello Cabineo X Overlay 8
- Lamello Cabineo X Overlay Shelf Support 5mm
- Improvements & additions have been made to the cabinet Shadow Rail feature.
- All updated to work with a backing rail.
- The prompt “Add Wrapped Batten” in all products has been changed to “Add Backing Rail” to avoid confusion with the main Wrapped Batten feature.
- Added the ability to have the backing rail in-between the cabinet sides.
- Drawer Stretchers will now sit behind the shadow rails.
- Added SEARCH functions to look for "L-Shape", "Solid Rail" and "Batten" If the name of the profile has "Solid Rail" in the name it will use machinable parts. If "Batten” is in the name, it will change the backing rail to a wrapped batten. If the name has "L-Shape" it will turn on parts to create an L-shaped shadow rail. With this setup, users can easily create their own shadow rail features by adding rows to D!LookUpTableShadowline.
- Added three new Shadow Rail profile styles:
- L Shape Solid Rail with Backing Rail
- Gola Standard
- Gola Zero Radius
- Mounting clips added, and 3 new columns to the lookup table in the door wizard for the position of the clip and the type.
- Added two additional Sink Faucet options.
- Added a new global variable, “Use Simple Face Frame”. This will now turn on a simple face frame when the doors are inset and “G!Inset Door Setback” is less than 0.
- Added an appliance panel option to the Fridge product. Note that the default sizes are generic and will need to be modified to match appliance manufacture’s specs.
- Added a double Facia (False Front) feature to all Sink Cabinets, the Master Cabinet, and several other base cabinets.
- Added a new frameless master cabinet: Master Split Height Designer Cabinet.
- Added six new global variables to control the inset backs left and right on corner cabinets:
- “Base Left Corner Inset Back”
- “Base Right Corner Inset Back”
- “Tall Left Corner Inset Back”
- “Tall Right Corner Inset Back”
- “Upper Left Corner Inset Back”
- “Upper Right Corner Inset Back”
- Added a new global variable, “Thick Backs Top and Bottom Use Default Construction Method”. With this selected, the top and bottom machining on thick backs will look at the default Construction Method Top and Construction Method Bottom. This will address certain challenges that are encountered when configuring cabinet back machining when the method differs from the carcase machining.
- Added the "Use Aluminium Handles" prompt to all products with handles. Previously this was only able to be activated from the Door Wizard.
- Added a Library Change Log to a worksheet in the Factory workbook. This can be used to track & document custom library changes and/or feature requests. Also useful for MV technical support agents or service providers to review information about your library.
Modifications
- Modified the “Cabinet Leveler” feature inside the Notched Toe Kick subassembly. Materials for “EZ Level” have been renamed and the SA info has been updated to better reflect the needed hardware quantities and names for ordering.
- Drawer Divisions within Door/Drawer cabinets will now only contain horizontal dowel/screw holes where they meet up with stretchers above or below.
- Modified the "Internal_Profile_Lead" location inside center pocket tool path of MDF Profile Doors. Lead in should no longer interfere with the rail detail in small doors/drawer fronts.
- Toe kick assembly boxes have been updated to look at the global variables "Toe Kick End Offset", "Toe Kick Finished End Offset" and "Toe Kick Back Offset". Added new global variables for the Adjustable Leg subassemblies as they were looking at the Toe kick offsets. New global variables have been added:
- “Adjustable Leg End Offset”
- “Adjustable Leg Finished End Offset”
- “Adjustable Leg Back Offset”
- Updated the hinge plate setback as well as the door reveals in the Diagonal and Transition cabinets. Default results should be improved in these scenarios.
- Resolved issues when adding a Component Door insert into an opening.
- The Prompts "Is_DivisionLeft", "IS_Division_Right", "Is_Shelf_Top", "Is_Shelf_Bottom" are now visible prompts on the Construction Options tab.
- The Prompts "Left_Hinge_Overlay" and "Right_Hinge_Overlay" have been updated as well as the "Left_Reveal_Overhang" and "Right_Reveal_Overhang". The overlays will now calculate correctly when changing the Left and Right hinge overlay types. Previously the “Hinge_Overlay” and “Reveal_Overhang” prompts were disconnected with one another.
Resolutions General
- Resolved numerous issues and inconsistencies with all drawer system subassemblies. Reviewed, compared, and conducted extensive testing within each drawer subassembly. Some items addressed (not a complete list):
- Resolved issues with switching between back over bottom and back around bottom construction.
- Reduced complexity of (Space_Required_Under_drawer_Bottom) Formulas, verified they were subtracting (Reduce_Bottom_Thickness)
- All Drawer Systems now contain 3SIDEDCUTOUT for center notch function.
- All drawer system bottoms that receive rout machining to size the thickness are now using a 4-sided cutout token on the part instead of an associative Dado token from a phantom part. This solves some reported Toolbox post processing (nesting) issues.
- Many other issues resolved.
- Global "ADA Sink Toe Kick Options" category no longer missing from Library Update.
- Resolved an issue with sink cutout graphic not displaying in 3D.
- Resolved an issue with Extruded Toe Kick Base when used on a 90° blended radius.
- Resolved a misspelled prompt in Drawer Stretcher subassembly (Strectcher Width).
- Resolved issue with applied finished ends not displaying in 2D elevation view of product. Also corrected elevation dimension that occurred in certain circumstances.
- All Extruded Products using legacy "G!Default_Routing_Tool_CW" variable have now been updated to use "G!Default_Cutting_Tool".
- When certain adjacent cabinets were processed together, Perfect Grain Container errors would sometimes appear. This was due to the system trying to perfect grain match all the adjacent panels onto the same container and exceeded the size of available sheet stock. To prevent this, all designer cabinet products now have their “Perfect Grain Container” option defaulted to “None”. Users will be able to set the “Perfect Grain Container” as needed.
- When adding glass to the MV Profile Door, the layer name used has been corrected to “Door_Glass”.
- Resolved issue in the Component Drawers subassembly that affected the “Left/Right Reveal” variables.
- Adjusted the IF PEANUT 3 Invisible Fastener machining to match manufacture’s specifications.
- Resolved an issue in Open End cabinets. Dowel/Screw machining will no longer be missing in certain conditions.
- Resolved an adjustable shelf line bore hole issue inside Transition Angle cabinets when back machining was required with Continuous Shelf Holes option selected.
- Resolved a 2D cross section dimension detail when changing the door bottom reveal.
- Resolved a small calculation issue inside the Cost Based Reports related to the waste factor.
- Changed the behavior within Face Frame cabinets wherein changing End Condition to “Applied End” or “Face Frame” the side face frame overlay control will switch to “Outside Control”.
- Updated the Face Frame subassembly to include the "Left_Stile_Scribe_Amount" and "Right_Stile_Scribe_Amount" in the stile size and the overall dim within the automated generated 2D Face Frame image and 2D elevation drawing of products.
- Applied Panel FF will now extend in the correct direction when using the “Extend Front Edge” prompt.
- Added additional global variables to better control the desired Cleat options.
- “Closet Top Cleat”
- “Closet Center Cleat”
- “Closet Bottom Cleat”
- “Closet Individual Cleats”
- “Closet Full Cleats”
- “Closet Full Top Cleat”
Microvellum Foundation Library Release Notes | Build 24.0322
The following release notes apply to Microvellum Foundation Library, Build 24.0322
Additions
- Added the Master Angled Ends Cabinet.
- Added a Global prompt, "Hinge Plate Offset From Front" for easier control.
- Added “Double Division” option to Horizontal Designer Cabinets, 3 Door Cabinets, and other similar products.
- Added a new feature to the MV Profile Door (MDF Doors) subassembly. When selecting “Grooved Panel”, one can now optionally select “Equal Spaced Grooves”. This will act as a “target spacing”, keeping all the grooves equally spaced instead of fixed distances that go outward from the center. New Door Wizard variable added “Equal Spaced Grooves” that can be used to select this on/off by default.
- Added an optional second and third row of set screw holes within the Wood Drawer Box subassembly. Formulas will automatically add the additional holes as required, but user can specify with the new prompt variable “Drawer_Front_Set_Screw_Hole_Qty”.
Modifications
- Modified the Nikpol Dragon Pro drawer system to match its supplier’s changes.
- "E!Drawer_Front_Edge" edging has been added to the backing rail parts in the Shadowline feature.
- Pie Cut Corner Cabinets- When the carcass radius is set to zero, the shelves will now also become zero. The "Shelf Setback" variable will no longer be included.
- Updated several drawer systems to prevent face 6 machining when the "Back Over Bottom" option is selected.
- The material pointer "M!Drawer_Box_Side" has been replaced with "M!Drawer_Wood_Spacer" to avoid confusion with “M!Drawer_Box_Wood_Sides”. Note that if you are running the Library Update utility, the new material pointer "M!Drawer_Wood_Spacer” will need to be pointed to your desired material.
- Modified default dowel and cam positions for small parts like nailers, toe kicks, and stretchers to avoid collisions.
- Modified the LEGRABOX drawer subassembly. All pocket cutouts for the drawer box bottom are now coming from a 4-sided cutout instead of phantom parts with dado tokens. This was changed to resolve potential machining issues with Toolbox. Other drawer systems to follow soon.
Resolutions General
- Resolved an issue with Wood Drawer Box subassembly. Added "Construction Method Into Bottom" so user can turn off dowels going into bottom when using "Raise Front/Back on top of Bottom".
- Resolved an Imperial/Metric conversion issue in Lamello Cabineo drill diameter machining (only affected imperial users). *
- Product Detail Reports styles 1-3 are now using the MVValueFormat for the Part Length and width. This affects the rounding of the displayed values. *
- Resolved an issue with Hettich AvanTech inner drawer system. Updated molding drawing for steel backs.
- Resolved an issue with the Room Component Wall product. All windows and door styles should now come in correctly.*
- When using the global “Drill Through At Divisions”, holes will no longer be missing in one opening. Also, when removing shelves from either the left or right openings, the holes will no longer be absent. This only applies to the Component Insert “Divisions With Adj Shelves”.
- Resolved an issue inside the Sink subassembly that sometimes caused issues with the AutoCAD Viewbase feature.
- Resolved a drill machining issue with Titus Tekform Slimline drawer system.
- Resolved an issue with Hettich hinge plate machining. Drill depth was not converting to imperial when required.*
- Resolved an issue that occurred when using the Shadowline Rail feature in certain products like Tall Wall Oven With Microwave. Added prompt "Top_Shadow_Rail_3_Sided_Cutout" to control when the top cutout is a 3-sided cutout vs regular corner notch.
- Resolved a part size issue with Cabinet Modification Option “Chamfer Top/Bottom” when using Full Applied backs.
- Resolved an issue with Wood Drawer Box subassembly when it’s an inner drawer (rollout). Set screw holes will now be disabled.
- Resolved an issue with Samson Fennel Legs. Middle back leg will now be orientated correctly.
- Added the“Buyout File Drawers” to the global variables and project wizard. This was a missing legacy option that the Wood Drawer Box was referring to.
- Resolved an issue with Corner Cabinets and their adjustable legs. Locations now correct when selecting finished ends.
- All "Base Handle Distance From Top" and "Upper Handle Distance From Bottom" variables have been updated in all products to look directly at their corresponding global variables.
- Added Dado and Hardware Array tokens to the Carcase subassembly. This is used for the Master Multi Carcase Designer FF cabinet.
- Added the prompt "Carcase Width" to all face frame cabinets. This can be used for reporting.
- Resolved an issue with “Extend Bottom Rail to Floor” feature.
- Resolved an issue with Face Frame Quarter Cabinets. Doors now sized correctly in imperial.
- Resolved an issue that affected Horizontal Designer FF cabinets when using Left/Right Overlay Control set to “Outside” AND side face frames/applied panels. Internal openings sizes will now calculate correctly and prevent issues with internal shelves being sized incorrectly.
- Related to this, inconsistencies between the designer cabinets and the regular framed cabinets have also been addressed. Applied FE panels will now be located in the same X location. It is recommended one review their project details if updating to this build.
- Resolved a part size issue with Closet/Wardrobe fillers & applied end panels at conditions when the bay height is smaller than the product height.
- Resolved an issue with Full Captured Back construction.
Microvellum Foundation Library Release Notes | Build 24.0221
The following release notes apply to Microvellum Foundation Library, Build 24.0221
Additions
- Added “Lookup” Option for all Fixed and Adjustable Shelf Quantity variables. Rather than entering a number for base/tall/upper shelf quantity, we now have an option called “Lookup”. When choosing “Lookup” from the dropdown, the shelf quantity becomes dynamic and uses "G!Max_Shelf_Spacing" variable to round down the available space to calculate the shelf qty. You can also override it at the product/subassembly.
- Base Applied Panel product - Added "Applied_End_to_Floor" as a local prompt, can now untick in the product to use the toe kick height when the global “G!Applied_Ends_to_Floor” is ticked. Also added a filter to the Bottom_Reveal so that it will only populate from the local product if the reveal is a negative value.
- Added Titus System 3 Cam option.
- Added new global variable “Component Setback” and linked to all products.
- Added new option to angled corner cabinet products: “Miter Side Front Edges”. All tops and bottoms have been updated with a draw only tokens and machine only tokens for the front route.
- Added “Master Corner Vertical Designer Cabinet”.
- Added new Removable Sub Top cabinet modifier subassembly. This insert will automatically cut an opening in the cabinet top, add lighting, and add a removable panel. Option to center the downlights in opening or to the doors.
- Added “Peka Shoe Pullout” to the Closet expansion.
- Added Grass Vionaro V8 system Drawer.
- Added Richelieu Undermount Soft-Close Drawer Slides 815 EVOLUTION, 825, & 823.
- Added additional Richelieu Axial drawer sizes 250 & 600mm.
- Added Richelieu Front Locking Devices 825 & 828 for narrow drawers.
- Added Peka Shoe Pullout option to the Closet Component Insert Options.
- Added additional options to the Shoe Shelf subassembly:
- Cam option
- Cam rear only
- Fixed Shelves
- Added four additional global variables to provide further control over which tools are to be used for thick back dado machining:
- Tenon Tool Thick Back
- Dado Tool Thick Back
- Dado Groove Width Thick Back
- Dado Depth Thick Back
- Added front cutout options to wooden drawer boxes (Rollouts). "Scoop" and "Angled" are included with variables for cutout size and radius options.
- Added a new global variable “Inset Door Setback” to allow inset doors to be set a specific distance in Y. Entering a negative value will trigger a special “simple” face frame option to appear in the Master Cabinet product. This option can be utilized to achieve a “face frame look” with a frameless cabinet carcass.
Modifications
- Modified the global variable “Dowel Distance to Front Edge”. For new library installs, will now default to 51mm for US Region.
- Modified the global variable “Dowel Target Spacing”. For new library installs, will now default to 96mm for US Region.
- Modified the Project Wizard variable “Default Construction Method”. For new library installs, will now default to “Dowel” for US Region.
- Modified the Project Wizard variable “Toe Kick Assembly”. For new library installs, will now default to “Notched Toe Kick” for US Region.
- Door Reveals will no longer reference "G!Inset_Door_Drawer_Reveal" when a cabinet filler or applied end is added.
Resolutions General
- Resolved issues with the Pricing Cost Based Estimating Product.
- Resolved issues within the Box End product.
- Resolved issue with Shadow Rails inside Horizontal Designer cabinets.
- Resolved issue when using Valance option with Vertical Designer upper cabinets. Hinge locations for upper openings will no longer incorrectly shift with a bottom valance.
- Shelf pin hardware quantity now correct when third row of holes are added due to increased shelf depth.
- Resolved issue in Upper Cabinets when "G!Applied_Ends_to_Floor" is turned on. The bottom reveal will now stay the same. There is a prompt in the subassembly that can be ticked if you require the upper applied ends to go to the floor.
- Resolved issue with Base Under Counter Oven product involving the Facia Height variable.
- Resolved issue with “Base Applied Panel” when using "G!Applied_Ends_To_Floor" option. Added "Applied_End_to_Floor" as a local prompt. Can now untick in the product to use the toe kick height when the global "G!Applied_Ends_to_Floor" is ticked. Also added a filter to the Bottom_Reveal so that it will only populate from the local product if the reveal is a negative value.
- Resolved issue with MV Profile Door subassembly. Updated the Offsetpolylines for the outer edges to resolve a problem when using the corner radius variable.
- Resolved Circular Reference Issue in Solid Wood Doors. Updated D!LookUpTableDoorProfilesInside column 30.
- Resolved edgebanding problem in “Shelves with Shelf Std” product.
- Resolved issues within the Shoe Shelf subassembly.
- Reviewed Appliance products and ensured all have associated 2D plan and elevation drawings.
- Resolved issues with Blum Merivobox Drawer height E Pure and F height.
- Resolved issue with the perfect grain prompt formula inside the Finished Faces subassembly. Will now properly reference drawer front material when it’s a drawer front.
- Resolved issue with the face frame cabinet plan view dimensions.
- Resolved issue with the "Drawer Bank" option in drawer bank cabinets.
- Resolved issue inside the Face Frame subassembly. Some variables were incorrectly referencing “L!” variable instead of it’s own local variable ("L!Right_Stile_Scribe_Amount").
- Face Frame attachment options have been added to the Drawer Stretchers in all drawer and door cabinets and drawer cabinets. It has also been added to the Drawer Stretchers in the Component Drawers FF and Component Door Drawer FF. Prompts were added to the Drawer Stretcher subassembly to turn on the face frame attachment options.
Microvellum Foundation Library Release Notes | Build 24.0119
The following release notes apply to Microvellum Foundation Library, Build 24.0119
Additions
- Added additional King Slide Ball Bearing Slides:
- King Slide 3J89
- King Slide 3M89
- King Slide 3J01
- King Slide 3M01
- King Slide 3J52
- King Slide 3M52G
- Added King Slide SIMLEAD Wood Drawer System Bottom-Mount Slides:
- King Slide 1X97 (Frameless)
- King Slide 1X97F (Face Frame)
- Added the ability for all cabinet doors to have up to eight hinges & plates (up from five). Added three new global variables:
- “Height To Add Sixth Hinge”
- “Height To Add Seventh Hinge”
- “Height To Add Eighth Hinge”
- Added Harn Impaz Drawer System (no graphics available).
- Added “Fixed Shelves with Dividers” mail slot interior component.
- Toe Kicks can now machine “up” into cabinet bottom, including Dado. Added global variable "Construction Method Toe Kick Top" to control desired machining method.
- Added a new global variable "Default Inner Drawer Setback". This has been linked to the inner drawer subassemblies and the inner drawers in the 1/2/3 Drawer cabinets. This can be used to push back the inner drawers a specified distance while also reducing the depth of the inner drawers.
- Added 3D Diagonal Line for drawer fronts (like 3D Door Swing).
- Added the ITEMNUMBER system prompt to all products. MV populates this special prompt with the product’s item number and can be used in various ways such as 2D drawing tokens.
- Added new data structure (tokens) to wood drawer subassembly for bottom mounted runners.
- Added “Division Quantity” prompt to most all cabinet products that could potentially have an interior component with divisions. This gives division quantity control from the parent product without having to drill into the component subassembly.
- Added “Drill Locator Hole” to the list of hinge machining options.
- Added global variable “Use Rail Notch” for better control over all rail notches at intersecting divisions.
- Added Special Product System Prompts to clipboard (only available in new install).
- Added the help text “Top” to all Bay 1 Options prompts tabs in all Vertical Designer cabinets.
- Added Confirmat Screws as an option to Screws table.
- Added extra tokens for machining dowels/screws from the division into the back and front top rails. This will eliminate the extra horizontal boring previously on the top edge of the divisions.
- Added hinge boring locations to Door and Drawer Front Fabrication Report.
If you have a custom Door and Drawer Front Fabrication Report, it is recommended that you unselect it during the Library update. - Open Corner End Cabinets - A Front Corner Square option has been added.
- Added “Shoe Shelf” insert as a standard cabinet insert (from the Closet expansion).
Modifications
- Modified the AutoCAD template drawing files (DWT). All layer colors are now Index Colors (no longer using True Colors). This should alleviate issues when printing all layers in black.
- Removed obsolete global variables: “RailWidth” and “MidRailCenterHeight” .
Resolutions General
- Blum Tandembox Antaro, Blum Tandembox Intivo, Grass Nova Pro Deluxe, & Nova Pro Scala – The Back Over Bottom feature will now function as expected.
- Wood Drawers - Undermount Holes will now move with Back On Bottom option.
- 2D “Finished End Text” will now appear regardless if "Display Product Description" is on.
- Base Door Drawer Blind Corner – Resolved a notch machining issue with the Front Stretcher.
- Blum Movento Drawer Systems will now display the correct locking device hardware on reports.
- Resolved an issue with Strip Lighting Insert. Now using Dado token instead of the ASSOCPolyline token to resolve periodic issues with incorrect rout direction.
- Resolved issues with Extruded Toe Kick Base. Parts and their locations will now be correct at radius conditions.
- 2 Door cabinets with locks will now respond correctly to the number of divisions inside the cabinet. No divisions or “even” number of divisions will automatically prompt a secondary lock (i.e. elbow catch). Odd number of divisions will cause two locks on each door to lock to the center division.
- Resolved Lock issue within Base/Tall/Upper 3 Door cabinets.
- Resolved issue with Global “Drawer Stretcher” set to “Locked Drawers” not activating the stretchers in locked cabinets.
- Blum LEGRABOX Inner Drawer hardware - added formulas to the front brackets and the front rail so the parts will not be drawn when using a timber front.
- Updated the Buyout Report:
- The Buyout Report filter has been fixed to filter only buyout Type 4 materials. Buyout Report Style 1 will no longer show products with no buyout part materials.
- Buyout Report will now show W x H x D of buyout drawers.
If you have a custom Buyout Report, it is recommended that you unselect it during the library update.
- Hettich Arcitech will now use the template hardware kit materials and not create project level hardware materials.
- Resolved issue with Richelieu Axial Drawer gallery rail machining.
- Upper Sloped Top product - Resolved material reference issues.
- Hanging Rail subassembly will now chamfer at rear when cabinet is set to chamfer.
- Hettich Avantech Drawer – corrected an issue with the finish color misspelling.
- Blum METABOX Inner Drawers– Resolved an issue with the Drawer Spacer option.
- Resolved an Adjust Shelf issue with Distance to Shelf Hole Front when using Shelf Edge option.
- Resolved an Adjust Shelf issue that would occur when using rear notch and fixing hole/slot machining.
- Shelf pin hardware quantity now correct when wide span shelves triggers the rear holes on the back.
- Resolved several issues with Internal Drawers with Faces subassembly.
- Resolved an issue with Crown Molding option. The option will no longer default with the rear crown “on”.
- Resolved several issues with Wall Oven appliance product/subassembly.
- Resolved 2D elevation issue with the Dishwasher appliance.
- Divisions internal insert will now only notch for top rails when it is appropriate to do so.
- Resolved an issue with Horizontal Designer products when using the Top Drawer option inside bays. Opening Heights now correct for inside components below the drawer.
- Resolved an issue occurring with Open Corner End Cabinets when the back has a different material thickness than side.
- Resolved issue with Lift-Up Door hardware when used in a face frame opening.
- Added Lift Up Door Cabinet FF.
- Resolved an issue with Base Applied Back Panel FF. Door Style changes will now pass down to nested door subassemblies.
- Resolved an issue with Drawer Front Calculator in Split Top Drawer FF cabinets.
- Added rounding functions to face frame subassemblies at Angled cabinets to prevent long decimal number dimensions when drawing in 2D Imperial.
- Face Frame Peninsula Cabinets – 2D Frame Drawings now supported.
- Strip lighting option will now break into two when hutch option is selected.
- Closet Corner Cabinet – Shelves will now adjust correctly in depth when changing the “Left/Right inset” variable.
- Closet Corner Parts – Resolved issue with pie cutout parts not deducting the same amount for edge banding than the regular straight closet parts.
- The dado for the toe kick has been updated to use the "Dado_Small_Part_Notch_Distance_To_Edge" when it’s under the "G!Dado_Small_Part_Threshold".
Year of 2023
This section lists all of the Foundation Library builds that released in the year of 2023.
Microvellum Foundation Library Release Notes | Build 23.1114
The following release notes apply to Microvellum Foundation Library, Build 23.1114
![](https://static.zohocdn.com/zoho-desk-editor/static/images/exclamation.png)
Special Note #1: Highly recommend updating Toolbox to build 23.1.1010 or newer as this library update zip includes new features only available to users running this TB version (or newer). Previous versions will not import categorized materials now included with the update.
![](https://static.zohocdn.com/zoho-desk-editor/static/images/caution.png)
Special Note #2: This update includes a potential
Breaking Change involving drawer runners for wooden drawers. This will only affect users who are updating vs installing a new library. The factory LookUpTable “LookUpTableSystemDrawerSlide” has been refactored to better accommodate undermount drawer runners. This also addresses issues when users are using varying material thicknesses for their drawers such as 12mm, 16mm, and 18mm. Any custom wood drawer subassemblies OR current existing projects will need their wood drawers updated to avoid errors. Any customizations users have made to this table will need to be restored.
Check under the Modifications section for more information on the new global variable created to circumventing this change.
Additions
- Added additional King Slide SIMLEAD Wood Drawer System hardware. 32 new Wood Drawer Slide Options have been added.
- Added new “EZ Level” cabinet leveling hardware to the Notched Toe Kick subassemblies. New hardware materials added for machining and reporting.
- “Post Laminate” option has been added to the Finished Faces subassembly. There are options to add it to the front and/or the back of the panel.
- To help with report filtering, we have added the bay numbers to Component Inserts’ subassembly comments in all starter products with bay openings (like the Component Doors).
- Added global "Drawer Stretcher Type" to control drawer stretcher types (Stretcher or Dust Panel).
- Wood drawers now have their own Hardware Array prompts, allowing a different hardware selection for the cabinet parts.
- Added 3D_BASE MOLDING layer to shipping drawing template (dwt). Assigned this to base molding parts in the library.
- Added global “Add 3D Grain Indicator” to control the 3D Grain Indicator option.
- Added Integral Toe Kick Hardware/Cutparts option. Added six new global variables to control:
- “Attached Toe Kick Sinks”
- “Attached Kick Height”
- “Attached Kick Cleat Deduct Value Single Door”
- “Attached Kick Cleat Deduct Value Double Door”
- “Attached Kick Deduct Value Single Door”
- “Attached Kick Deduct Value Double Door”
- Added Legacy Wall Paneling product.
- Several additions/improvements for the Finish Label feature:
- Added global “Finish Label Condition” to control whether to add the label per product or per finish face.
- The Finish Label has been added to the 2D Instructions subassembly.
- Added the 2D Instructions subassembly to all remaining Standard and Corner Cabinets, both in the Face Frame and Frameless (previously missing).
- Added Hafele Free Fold Lift-Up system.
- Added Richelieu Atmos aiR Lift-Up system.
- Added Finista Drawer system (minus the unavailable 3D graphics).
- Added an additional machine token to all handle hardware that can drill a hole into a drawer sub front (not available with library update). New global variable added “Drill Sub Front Handle Holes”.
- Added two new global variables to control the name of the 2D Instructions subassemblies. You can set this up with your company name, preventing it from being overwritten during library updates.
- “Drawing 2D Instruction Name”
- “Drawing 2D Corner Instruction Name”
- Added new functionality in the factory LookUpTable “LookUpTableSystemDrawerSlide” to better accommodate when some drawers require front and back notches (column 8 and 12).
- Added Master Double Sided Cabinet FF product.
Modifications
- Note for updating users only: To prevent issues with existing projects, we have added a global variable called “Use Legacy Wood Drawers” that can toggle between the legacy behavior and the updated behavior. If your project contains older versioned wood drawers, this variable can be selected to prevent issues. If you are running updated v23.1114 wood drawers and want the new functionality, uncheck this global.
- The factory LookUpTable “LookUpTableSystemDrawerSlide” has been refactored to better accommodate undermount drawer runners. This also addresses issues when users are using varying material thicknesses for their drawers such as 12mm, 16mm, and 18mm. Any custom wood drawer subassemblies OR current existing projects will need their wood drawers updated to avoid errors. Any customizations users have made to this table will need to be restored. See the Note for updating users only modification above or Special Note #2 above for more information.
- Updated the sample kitchen island product group that ships with new library installs. We have also added some bar stools.
- Base 2 Drawer Waste Bin product is now linked to the global "G!Default_Double_Waste_Bin_Pullout" to set an appropriate default waste bin.
- Cabinet carcass front edging on all left and right sides have been updated to account for finished ends. If a cabinet has a finished end, that side will reference “E!Open_Carcase_Edge” pointer instead of “E!Carcase_Edges”.
- “Shelf Qty” prompt control type for both adjustable and fixed shelves have been changed back to a 5 (visible). These prompts are sometimes controlled by the parent product they come in with (prompt value feature). So, keep this in mind when trying to control the shelf quantity from the subassembly prompts UI.
Resolutions General
- Resolved issues with the Richelieu 908 drawer system graphics.
- Resolved issues with Any Angle cabinets when using dado construction.
- Resolved an issue with Horizontal Designer Cabinets when selecting Top Drawer option within the bays.
- Resolved an issue with sink cut-outs into countertops for Imperial users.
- Resolved an issue with Component Drawer subassembly when placed within cabinets with vertical rails that caused the drawer locations to be incorrect. In doing this, we have made the “Vertical Rail” prompt visible in the Component Drawers subassembly. This can now be turned off when inserting drawers into a product that has a vertical rail. We have added a formula that will now only deduct the vertical front rail width when there is no top facia.
- Resolved an issue when selecting Cabinet Notch Center with Wood Drawers.
- “G!Dado_Notch_Distance_to_Rear_Edge” global variable has been added to all Any Angle Cabinets.
- Resolved issue when selecting Finished End option with cabinets containing a Wrapped Batten. Added IF statement to the screw machine tokens on the wrapped battens so they will turn off when attaching to a finished end. We have also changed the machine point from 7M to 2M.
- Resolved issue when using a cabinet filler and applied end within the Tall Fridge Cabinet. Updated the height and depth of the fillers so that they will be full height when you have an applied end.
- Resolved issue with fillers in Tall Fridge Cabinet and Master Enclosed Appliance Cabinet. Updated so that the fillers are at the correct height and size. Also updated the filler subassemblies to not include the bottom reveal when the cabinet has a full inset door. Added a prompt value "Product_Type;Upper" to the fillers in the product so they will look at upper filler properties.
- Resolved issue with Lock Strike Plates at Drawers. The rotation for the strike was not taking into account the Left and Right of Pull position options.
- Resolved issue with secondary lock origins at Door Drawer Cabinets. These will now associate to the drawer stretcher.
- Certain Pullout Bin systems have “Left/Right mounting Position” options and were not displaying the prompt option. This has been corrected.
- For thin backs, updated dado machine tokens to match consistency with other global variables. Instead of referencing “G!Dado_Clearance”, they now reference “G!Rebate_Clearance”.
- Resolved a dado construction issue inside Extruded Die Wall w studs.
- Resolved issue with wire chase holes and cutouts inside the Straight Die Wall.
- Resolved issue with extending sides to the floor for upper cabinets. They will now reference the HeightAboveFloor value to get the correct size.
- All cabinet products updated so that when using the Cabinet Void feature, the overlay tops and bottoms no longer run to the wall.
- Resolved issue with the Door and Drawer Front Fabrication Report. Added missing headers and improved some formatting items for better consistency between the different reports.
- Resolved/Improved Rear Cutout Dowel spacing issues for all drawer box subassemblies.
- Resolved lock position issue when Stretcher material was a different thickness than the top material. The value in the prompt “Door_Top_Edge_to_Top_Panel” has been updated to refer to the correct thickness depending on if you use rails or full top.
- Resolved inaccuracies with certain Undermount Drawer Slide drilling Locations.
- Resolved an issue when using shadowlines and the global variable “Drawer Box Fixed Location”.
- Resolved a machining issue with the Lemans II pull out.
- Resolved an issue with Toe Kick Base product when using the Left/Right Notch feature. Also updated the location of the sleepers when using notches.
- Resolved routing issues within the MV Profile Door using certain shapes.
- Resolved 2D/3D drawing issues when using FE scribes on applied ends.
- Resolved 3D graphics issue with the Hafele Matrix drawer system. Locking Device block separated from the slide blocks.
- Resolved an issue with the Internal Drawers With Faces component insert subassembly. Unchecking the divisions and fillers along with changing the left reveal value will now move the parts.
- Resolved an issue when processing products using the Tambour Door With Surround subassembly. This will no longer generate an error message.
- Resolved issues with several extruded products such as Extruded Toe Kick Base and Extruded Base Cabinet. These products are undergoing continual improvement and will see changes over the next few updates.
Additions/Resolutions Face Frame Cabinetry:
- Diagonal Angle Cabinet FF, Transition Angle Cabinet FF, and similar will now correctly display their 2D face frame images on reports and CAD (no longer oblique). A new nested subassembly was added along with a new CAD layer to facilitate this (updated the shipping dwt template).
- Resolved an issue with hinges not appearing in Frame products using the Generic Five Piece door type.
- Resolved issue with doors in the Blended Locker product.
- Edgebanding on top edge of sides will no longer appear when using an overlay top.
- Resolved issue with missing associative dado machining for backs in certain products.
Microvellum Foundation Library Release Notes | Build 23.1010
The following release notes apply to Microvellum Foundation Library, Build 23.1010
It is heavily recommended that users downloading this Foundation Library build update their Toolbox software to build 23.1.1010.641 or newer, as this update contains features that rely on improvements made in Toolbox build 23.1.1010.641.
Additions
- Added King Slide SIMLEAD metal drawer system & ULEAD Series undermount drawer runners.
- Added additional Lamello Fasteners:
- Bisco P-10 & P-15
- Tenso P-10 & P-14
- Added a Miter option for “Fixed and Adj shelf Construction Method Shelf Edges”.
- Added the ability to remove the rear stop dado. Added two new global variables “Dado Notch Distance to Rear Edge” and “Dado Small Part Notch Distance To Rear Edge” and linked to all relevant parts with DADO tokens.
- Added missing global variable “Lock Drop Front Distance”. Wood Drawers will now reference this instead of a fixed value inside the subassembly.
- Added Post Laminate feature to all cabinet products. Added new Post Laminate subassembly that activates when “G!Post_Laminate=1” and a face is selected as finished (Left, Right, Top, Bottom, Back). Global variables “Post Laminate” and “Plam Overhang” should now be visible in the interface.
- Added the ability to rebate (rabbet) cabinet sides for backs with clearance holes at each corner. “G!Rebate_Lead” will need to be adjusted (0.5mm). Added two new global variables:
- “Rebate Back Clearance Holes”
- “Rebate Back Clearance Hole Diameter”
- Added content to support a new Bathroom Partition expansion. 53 new global variables, 7 new material pointers, 5 new edge banding pointers, Metlam hardware material library, 12 profile drawings, and 1 new factory lookuptable. Also added new category of hardware materials. Please contact your account manager for more information about adding this expansion.
Modifications
- Updated Richelieu Drawer Slide .dwg graphics by reducing their file sizes, lessening performance impact when using.
- Drawer Division Machine Point has been changed to force machining to face 5.
General Resolutions
- Resolved an issue that occurred with Base 1 Drawer Microwave when set to Full Inset Door.
- Resolved an issue with Master Double Sided Cabinet. Rear bay components will no longer reference front bay depth.
- Resolved an issue with Master Under Stair Cabinet when using two doors.
- Resolved several issues with the “Hardware Array” construction feature.
- Divisions now use the same start/stop variables as Top/Bottom parts. All parts should now reference the hardware array table.
- Top Stretchers & Mid Stretchers will now use the Hardware_Array_Small_Part_Threshold to correct their pattern layouts.
- Mid Stretchers will now have hardware on the same face left/right.
- Hanging Rail Shelves now include Hardware Array tokens.
- Resolved a Lock Location issue at Door Drawer Cabinets when base locks are set to lock to top.
- Resolved a Lock Location issue at Upper Cabinets when lock location is set to “Lock to Bottom” and a bottom valance is used.
- Resolved a few items inside the ADA Sink Angled Frame product. The side routes will no longer reference the horizontal drawer gap.
- Resolved a sink cutout issue inside the Countertop with Substrate product.
- Resolved a hinge plate location issue with Door Drawer Blind Corner Cabinet(s) when using Use Blind Corner Hinge, Add Blind Corner Panel, and Overlay Blind Corner Panel.
- Resolved an issue with all toe-kick box assembly subassemblies and products, wherein the sub front did not account for any values placed into the Sub Front Height prompt.
- Resolved an issue with Upper Undermount Rangehood Cabinet when set to "Full Capture" back.
- Resolved an issue with rear internal inserts involving the line bore holes not shifting in relation of the cabinet modifiers.
- Master Double Sided Cabinet will now have Pullout Options front/back.
- Resolved an issue with cabinets using overlay top, dado construction, and top finished. Applying edge banding to cabinets with these settings turned on would lead to errors. If the settings are applied, edge banding will no longer apply to these products.
- Resolved an issue with MV Profile Door. The 3D drawing only tokens have been updated to properly represent what will be machined (using current MV versions).
- All Base and Tall Corner Cabinet toe-kicks will now have 2D plan drawings. Also, 2D elevation grain indicators and finish labels corrected.
- Resolved issues with the Elias Woodwork Doors’ center panel location. Elias Door wizard has been updated and included with the new .exe library install only (not included in the library update).
- Resolved issues with Titus Tekform Drawers. 113 height rear back brackets added and resolved issue with Back Over Bottom option.
- Resolved an issue with the Titus Tekform Slimline Drawer's back.
- Resolved an issue with Grass Nova Pro Scala that occurred when using Rear Cutout option.
- Resolved an issue with Blum Legrabox Inner Drawer (NZ region) that occurred when using K & C heights (graphics added).
- Resolved an issue with Krome Premium Drawers front drilling.
- Resolved an issue with the Wood Drawer Box when using a rear cutout.
- Resolved an issue in Costing Reports related to Drafting Labor.
Face Frame Cabinetry Resolutions
- Resolved an issue found in Vertical Face Frame cabinets, wherein the Fixed Shelf FF could collide with the side when using applied ends.
- Removed edge banding from certain drawer stretchers & fixed shelves when behind a face frame.
Office Furniture Resolution
- Resolved the issue of regular backs not rebating into sides.
Microvellum Foundation Library Release Notes | Build 23.0919
The following release notes apply to Microvellum Foundation Library, Build 23.0919
Additions
- Added new product Master Double Sided Cabinet.
- Added “Horizontal Handles Centered” global option to all doors. This is available for all tab pulls, handles, and knobs.
- Added a new DRAWRECTANGLE 2D plan token to the door subassemblies. This will turn on if the global door opening angle is set to 0. This has also addressed the issue of no 2D plan token for lift-up and sliding doors.
- Added "Elevation_Door_Swing_Lines" to the global and linked to the door subassemblies. This can be used to turn off the 2D elevation “swing” lines.
- Added global option "Use_Blind_Corner_Hinge" and linked to blind corner products.
- Added control type 9 prompts to the Adj Leg subassembly. This will allow the user to change to decorative legs or casters.
- Wall and floor lines in 2D cross sections are now globally controlled. Added two global variables:
- “Section Add Floor”
- “Section Add Wall”
- Added global variables to control the rear corner notch and chamfer on Corner Cabinets:
- “Base Corner Rear Options”
- “Tall Corner Rear Options”
- “Upper Corner Rear Options”
- “Notched Corner Width”
- “Notched Corner Depth”
- “Chamfered Corner Width”
- “Chamfered Corner Angle”
- Face Frame Attachment options have been added to the globals and have been linked to machine tokens in the Face Frame products to attach the face frame to the cabinet body. Default three options are “None”, “Dado”, & “Hardware Array”. Added 17 variables:
- “Face Frame Attachment Face Top”
- “Face Frame Attachment Face Bottom”
- “Face Frame Attachment Face Sides”
- “Face Frame Attachment Face Divisions”
- “Face Frame Attachment Face Shelves”
- “Face Frame Attachment Hardware Edge Array”
- “Face Frame Attachment Vertical Spacing”
- “Face Frame Attachment Vertical Distance From Edge”
- “Face Frame Attachment Vertical Threshold”
- “Face Frame Attachment Horizontal Spacing”
- “Face Frame Attachment Horizontal Distance From Edge”
- “Face Frame Attachment Horizontal Threshold”
- Added the ability to select to have only one hardware piece on the hardware array tokens on rails, nailers, and kick faces. This looks at the “G!Hardware_Array_Small_Part_Threshold” and column 9 of the “H!LookUpTableEdgeArray”. If there is a 1 in this column, it will only add one piece of hardware in the center of the part.
- Face Frame Dado tokens have been added to divisions and shelves.
Modifications
- The "Drawer_Stretcher_1" prompt has now been hidden in Door-Drawer Cabinets, as this is controlled by “Drawer Stretcher” combo box.
- The 3D graphic drawings for the Shelves w Shelf Std product have been refactored. Removed “2D_” & “3D_” from the file names, as they are not using associative machining.
- Optimization reports and labels will now filter by processing station. “L” & “W” have been added to reports & part label dimensions. US displays dimensions (WxL). AU/UK display as (LxW).
- The prompt drawer order has been changed in the Component Drawers and the Master Cabinets so that the bottom drawer front height is now second in the calculator list. When changing the qty of drawers the calculator will no longer be disrupted.
Resolutions
- Corrected the handle location behavior of lift-up/dropdown doors. Also, the handle positions in the Component Door subassemblies have been linked to the Base, Tall, and Upper Door prompts so the correct prompts for the handle positions are visible.
- Added missing graphics for Richelieu RCS 165 hinges.
- F!LookUpTableSystemDrawerSlide has been updated to reflect the correct slide height from the bottom for certain Accuride runners.
- There was a reported issue with selecting a part to oversize: in the saw optimization processing station, enabling an oversized part would result in an inaccurate cut part size in the resultant saw optimization report, with the report failing to account for the differences in measurement between the basic measurement and the oversized measurements. This issue has been corrected but will require users to update their reports. Visit the Sawing Optimization Reports download page and import the new reports using the Database Management feature.
- Updated the “Drawer Stretcher” combo box prompt in the Door-Drawer Cabinets so the stretcher will turn on when “Add Lock” is enabled and “Drawer Stretcher” is set to "Lock Only".
- Resolved an issue in Door-Drawer Cabinets wherein the top-drawer lock location was different than Drawer Bank Top Drawer locks. Resolved several other related issues and differences.
- The “Internal Route” variables inside Finished Faces subassembly prompts will now unhide when a glass door is activated.
- Updated the Hettich Multitech Drawer to ensure it uses the correct library level hardware materials.
- The Component Folding Door subassembly in all folding door products has been updated to correct a Y origin issue.
Microvellum Foundation Library Release Notes | Build 23.0828
The following release notes apply to Microvellum Foundation Library, Build 23.0828
Additions
- The Lamello hardware below has been added to the hardware array as options.
- Lamello Cabineo 8 Flush
- Lamello Cabineo 8 M6x12.3 Flush
- Lamello Cabineo 8 M6x15.3 Flush
- Lamello Cabineo 8 Flush With Cover Cap
- Lamello Cabineo 8 M6x12.3 Flush With Cover Cap
- Lamello Cabineo 8 M6x15.3 Flush With Cover Cap
- Lamello Cabineo 8 Overlay
- Lamello Cabineo 8 M6x12.3 Overlay
- Lamello Cabineo 8 M6x15.3 Overlay
- Lamello Cabineo 12 Flush
- Lamello Cabineo 12 Flush With Cover Cap
- Lamello Cabineo 12 Overlay
- Lamello Clamex P-10
- Lamello Clamex P-14
- Lamello Clamex P-Medius 14-10
- Lamello Clamex P-Flexus 14-10
- Added several OVVO fixing hardware to the hardware array as options.
- OVVO OD830
- OVVO RD9 with V-0930RH
- OVVO RD12 with V-1230RH
- OVVO RD12 with DH1
- OVVO RN12 with DH1
- OVVO PN12
- OVVO RN12
- Added two new global variables to reduce full applied cabinet back widths & heights.
- "Back Width Adjustment"
- "Back Height Adjustment"
- Added a Cabinet Cutout subassembly to all base and master products in both the Frameless and Face Frame categories. This can be turned on through a prompt under the Construction tab called “Full Top Cutout”. This subassembly can create cutouts in the top, bottom, left side, and right side. The cutouts can be split into 1,2,3, or 4 cutouts for each side. A custom calculator is included to control the location and spacing of the multiple cutouts. A special 3D block is added to cabinets using this cutout (lower left of opening). The block can be used to quickly select the subassembly’s prompts for making changes.
- Added two new global variables to give users the option to omit the 3D drawing blocks for Drawers, Pullouts, and Waist Bins. This can be a good way to speed up Toolbox performance if you have large drawings with many products.
- "Draw Hardware Blocks For Pullout"
- "Draw Hardware Blocks For Drawers"
- Added a global variable "FE Flush To Door Face". When this is ticked on the Applied End subassembly will default to the "Thickness_Door+Door_To_Cabinet_Gap." When unticked the applied panels will look at the "FE Panel Overlay" for the front extension. "FE Panel Overlay" has been set to 0 as default in the template.
- Master Split Cabinet - Added the ability to add a double center shelf at the split. This has been achieved by adding a function to the vertical splitter to have a double shelf. Each shelf has the option to reverse the machining from the bottom face to the top face if needed such as cams or dados.
- The Bead Option for outside of Face Frames has been added to the Split Height Designer FF cabinets.
- Added the ability to specify the Splay Handle Position and J Profiles. This feature has been added to the finish faces and MV Profile door subassemblies. You can now select the top, bottom, or vertical edge.
- Added categories for Tall Corner Cabinet Accessories and Upper Corner Cabinet Accessories. Split the master Corner Filler With Cleats product into the Base, Tall, And Upper Corner Cabinet Accessories folders.
- Added global variable “Shelf_Support_Fixing_Drill_Front_Only” for conditions that only require a front fixing drill at adjustable shelves.
- Office Furniture Mobile Cabinets - The "Toe Kick Height" will now match the selected caster height. The formulas have been written to check the hardware to see if there is a size at the end of the name. This will then set the height to the castor height. For example: Twin Wheel Castor_67mm
Modifications
- All barcodes in reports have been changed to use the Barcode field. The product label has also been updated.
- Made a number of general improvements to the Dishwasher product.
- Gallery rails have been added to the Harn Ritma Cube drawer system.
- Changed how Inner Drawers (Rollouts) locations are calculated. Added a "Top Gap" variable for the distance between the top drawer and the top of the opening as well as a gap between the drawers. This is independent from the drawer heights.
- Updated Lockdowel hardware to include part numbers in their names.
- Applied Panel subassembly will now look at parent product for "Edge Top" & "Edge Bottom" prompts values.
- The Drawers subassembly has been updated to match the Component Drawers subassembly.
Resolutions
- Resolved an issue with the Z origin for the lift-up handle in all Door subassemblies for the 2D cross-section draw tokens.
- Resolved a hardware association issue that sometimes appeared when changing the door material to be a thinner material. Refactored the formulas affecting handle & lock associating to doors and drawer fronts. These now have a greater tolerance when drawer fronts are a different thickness than doors.
- Resolved a drilling issue inside the DTC Dragon Pro Drawer.
- Updated the imperial drawing template to prevent the inch symbol from appearing on angular dimensions.
- Added the missing dwg graphics for 249mm Richelieu Optimiz-R sides.
- Added E pure and F side graphics for Blum MERIVOBOX used in New Zealand region.
- "Left Filler Width" and "Right Filler Width" cabinet prompts will now display their help images.
- Resolved a machining issue that affected rear cabinet modification features in Open cabinets. Also resolved another issue that affected Divisions, Pigeon Holes, and the Horizontal Splitter subassemblies.
- Resolved an auto screw drilling issue within the Toe Kick Assembly Base.
- Resolved an issue with Cam Lock machining holes at drawer divisions. The rear machine tokens will now look at small part threshold for the drawer divisions.
- The "Bottom Hinge" prompt in the Component Doors subassembly was incorrectly hidden. This is now a visible prompt.
- Resolved a 3D origin issue with glass doors within the Generic Five Piece Door when used as a sliding door.
- Global "Name_Filter_Pulls” has been updated to prevent handles from associating to the incorrect parts in corner cabinets.
- Resolved an issue with the "J Handle Route" not appearing on the left swing tall doors.
- Resolved an issue with MV Profile Door’s Edge Profile Lead.
- Resolved an issue with Base Drawer Sink With False Front when selecting one drawer.
- The Component Drawer subassembly will now look at the local product for the drawer type setting. This previously affected a number of products such as Base 1 Drawer Microwave.
- Corrected a misspelling typo that caused an issue with the Pelmet subassembly.
- Resolved an issue with split back sizes within the Master Split Height Designer Cabinet.
- Resolved an issue with Front Rails when changed to a vertical rail and the material is a different thickness. Dado tokens will now look to "M!Sub_Front_Thickness" when the rail is set to vertical.
- Resolved an issue that caused solid wood drawer parts to appear in the face frame flat-shot feature & reports.
- Resolved an issue with Base Applied Back Panel product. "Applied Ends To Floor" feature will now function properly.
- Resolved an issue within the Base 6 Drawer Cabinet that affected the drawer calculator.
- Resolved an issue within the Master Any Angle Cabinet when using the "Cabinet Void" feature.
- Resolved an issue with the Component Pocket Doors subassembly. Parts will filter in accordance with the face option selected ("Left Swing", "Right Swing").
- Resolved an issue with the Component Door Drawer FF that sometimes caused incorrect door sizes.
- Resolved an issue within the Internal Drawers with Faces subassembly insert that could cause incorrect drawer locations.
- Resolved an issue within the Component Drawers subassembly that triggered when the split drawers feature was used. The vertical gap will now be correct when it’s different from the horizontal drawer gap.
- Resolved an issue in solid wood door so center panel 2D elevation tokens will not draw when "Door_Construction"="Single Panel".
- Corrected the help image for the Vauth Sagel Cornerstone Maxx Blind Corner Pullout. Also created a help image for the Kessebohmer LeMans II pullout.
- Office Furniture Master Desk - The left and right pedestal parts are now correctly turning off when selecting the left or right leg. An issue with the kick face origin has also been corrected.
Microvellum Foundation Library Release Notes | Build 23.0810
The following release notes apply to Microvellum Foundation Library, Build 23.0810
Additions
- The Richelieu 908 Drawer System has been added to the library catalogue.
- Richelieu RCS Hinges (qty 13) and plates (qty 12) have been added, in a separate file. To download this file, contact Microvellum.
- A prompt has been added in the Blind Corner FF Cabinets, giving the option to add a drawer mid-rail in the blind corner opening. The Face Frame subassembly has been updated to accommodate this extra rail.
- A new prompt, "Rebated_Blind_Corner_Panel" has been added to the Blind Corner cabinets prompts on the main tab. This will sit the blind corner panel on the front of the cabinet with no rebates into the top and bottom panel.
- A global prompt has been added that enables control over the adj shelf position relative to the shelf holes. The logic has been added to all adj shelf subassemblies.
- Added “Shelf Support Route Machining Feature”. Shelf pin slots have been added to the adj shelf subassemblies and can also specify a drill hole.
- A new option has been added to the Lift-Up Door list: "Top Hinge Only".
- A small assortment of sample Flush Recessed Pulls (Oval, Rectangle, Round) has been added.
- Added legacy generic Lazy Suzan pullouts for corner cabinets. Includes Corner Round and Full Round trays in numerous sizes from 12” to 32”.
- Additional Metric Rebated Tab Pulls have been added in.
Modifications
- Machining for notches and chamfers on Corner Cabinets has been modified to only machine on face 6 when necessary.
- A new variable has been added: a mid-drawer overlay for the Master Cabinet FF and the Door Drawer FF Cabinet. When using a double-top drawer you can now control the overlay on the mid-stile.
- Farmhouse Sink Face Frame- added a full sink rail prompt so that the top rail will be the height of the farmhouse sink.
- Any Angle Cabinets now have angle validation codes to limit what's possible (110° -179°). Also added additional validation when the angle is less than 110° and the depth is greater than the “Back_Width_Left” and “Back_Width_Right”.
- Added a search function for Shelf Adj and Shelf Fixed in the control types for all prompts relating to Adjustable Shelves and Fixed Shelves. This will allow for custom subassemblies for adjustable and fixed shelves.
- Upper Microwave Cabinet – this appliance now has a Radius Control variable for Extended Bottoms.
- The default location of Hanging Rails inside closet products has been modified. When creating closet products, the system will now reference the entered global variable instead of calculating “Inside_Width/2”.
![](https://static.zohocdn.com/zoho-desk-editor/static/images/file.png)
For the search function to allow for custom subassemblies, custom shelves are required to have the shelf type in the name for this function to work properly: "Shelf Adj" for adjustable shelves and "Shelf Fixed" for fixed shelves.
Resolutions
- The hardware materials kits for the Formed Javabox Drawer System have been added, in addition to minor issues being resolved.
- The Grass Dynapro 40-70kg Soft-Close has been made available to clients in the UK region.
- Lift-Up Doors now have 2D plan drawings available.
- The Base Island Box End product has had several minor issues resolved, and in addition to a rendered image being added in for the product.
- Blind Corner products had a noticeable issue involving the drawer box depth. This issue has been resolved, and to ensure it is not an issue in the future, the prompt "Drawer_Cabinet_Modification_Deduction" has been added into the data.
- An issue within the vertical starter cabinets (such as Tall Wall Oven) that affected bay opening component Z origins in certain conditions has been resolved.
- An issue in the Base 3 Door product that affected hinge plates and their associating to appropriate parts.
- Resolved Metric/Imperial issue in solid wood doors that affected the 3D representation of cathedral shaped doors.
- Dado tokens on partitions have been updated with “Thickness_Division” instead of using “Thickness_Left_Side” for parameters 5 and 6.
- For all Corner Cabinets, the screw machining tokes have been updated on the thick backs to drill from the other side when the “=Construction_Method="Dado"” or “Construction_Method="Dado&Screw".
- Issues have been resolved with the MV Profile Door. The groove 10-20 machine tokens for the grooves on all panels have been updated.
- Cabinet top and bottom screw machining in the thick backs has been updated to turn off when using finished tops and bottoms.
- Resolved a lock issue within the Office Furniture 1 Drawer Cabinet.
- Resolved an issue with Office Sliding Door Credenza involving the inset doors and the size of the sides.
- An issue with crown molding miters at transition Angle Cabinets has been resolved.
- Resolved a reported issue with Rollouts/Inner Drawers colliding with the face frame bottom rails. If the rollout insert is in a face frame opening, then the "Bottom_Drawer_Position" value will increase by an equal amount as the “Face_Frame_Bottom_Overlay” value.
- An issue within the subassembly insert Inner Drawer With Components Above was noted, wherein the Z origin for the nested insert subassemblies was incorrect, due to failing to account for the fixed shelf thickness. This issue has been resolved.
- An issue in the Wooden Drawer Box that appeared when the Rear Cut Out feature was used has been resolved.
- An issue was noted with drawer stretchers, in certain circumstances, causing unwanted machining in a nest. It’s been resolved- the drawer division and the blind corner hinge panel have been modified to be one part. This was achieved by adding a corner cutout in the Horizontal Splitter, controlled by a prompt value in the product. A new subassembly prompt has been added: "Blind_Corner_Hinge_Panel_Notch_Height".
- Rear cam machining tokens on all fixed shelves and divisions have been updated. They will now respond to “G!Cam_Drill_Through_Backs”.
- Resolved an issue within Blum LEGRABOX, which prevented the F height from populating the subassembly automatically.
- Resolved an issue within certain closet products, which prevented the “Add Hanging Rail Right” prompt from appearing.
- Resolved an issue with Nover Krome Premium drawer. The brackets and back drill now function correctly.
- Resolved issues with the Blum TANDOMBOX Antaro drawer system.
- Resolved an issue with the Hettich Innotech Atira’s inner drawer option.
- An issue with the Grass Nova Pro Scala Inner Drawers has been resolved.
- Resolved an issue with DTC Dragon Pro drawer system missing fixing bracket graphics. The graphics have been added and will display.
- Resolved an issue with the Harn Ritma Cube drawer system.
- There was a noted issue with the Integrated Dishwasher appliance not being placed correctly with applied ends. This issue has been resolved.
- Resolved an issue with Adjust Shelves subassembly that occurred when inserting the shelves with “Pick Corners” as the method. In certain cases, the continuous linebore holes would not appear on the right.
- Resolved an issue with the Access Panel subassembly insert. The innerworkings of the subassembly have been simplified using the OFFSETPOLYLINE function.
- Resolved an issue with drawer front locks appearing when “Lock Drawer” prompt was not enabled.
Microvellum Foundation Library Release Notes | Build 23.0623
The following release notes apply to Microvellum Foundation Library, Build 23.0623
Additions
- Added new Hardware Bracket product for use in countertop support or other applications. There is a single bracket version and an array version for multiple spaced brackets.
- Added new Formed Javabox Drawer System (UK region)
- Added additional columns in global lookup tables "CustomSpacedDowels", "CustomSpacedScrews", "CustomSpacedCams" to accommodate a different hole pattern for cabinet finished ends.
- Inserted additional rows into the three global lookup tables "LookUpTableCustomSpacedDowels", "LookUpTableCustomSpacedScrews", "LookUpTableCustomSpacedCams". Some rows will now be spaced every 16mm instead of 32mm for greater accuracy. The formula for the Custom Spacing hole patterns has also been improved to use the new global variables listed below.
This change will only appear if you install a new library as the Library Update tool will not insert these additional rows or change your hole pattern formula.
- Added new global variables to provide additional controls over Custom Spacing bore patterns (below).
- "Screw Min Distance To Last Hole Custom Spacing"
- "Screw Use Last Hole Custom Spacing"
- "Screw Last Hole Divisible By Custom Spacing"
- "Screw Finished End Target Spacing"
- "Cam Min Distance To Last Hole Custom Spacing"
- "Cam Use Last Hole Custom Spacing"
- "Cam Last Hole Divisible By Custom Spacing"
- "Cam Finished End Target Spacing"
- "Dowel Min Distance To Last Hole Custom Spacing"
- "Dowel Use Last Hole Custom Spacing"
- "Dowel Last Hole Divisible By Custom Spacing"
- "Dowel Finished End Target Spacing"
Modifications
- Removed the formula multipliers to Target Spacing columns in global "LookupTableTargetSpacingScrews", "LookupTableTargetSpacingCams", "LookupTableTargetSpacingDowels". This was done to encourage users to specify their desired behavior for hole spacing at small & large parts.
- Updated Countertop With Waterfall Ends product. Added panel quantity options and a tab with the Applied Back Panel options.
Resolutions
- Corrected issue within Base Door Drawer Blind Corner cabinets with full line bore holes going into the drawer area.
- Resolved Imperial/Metric issue in certain appliance products.
- Resolved "Opening Lites" feature inside the MV Profile Door. Corrected the calculator for the panel heights. The calculator will now display only panel 1, panel 3, panel 5, and panel 7 when selecting the "Door with Lites" option.
- Resolved issue with "Wrapped Batten" feature when used in cabinets with divisions.
- Resolved issue with "Cam Auto Spacing" that caused an incorrect number of cams in certain conditions.
Microvellum Foundation Library Release Notes | Build 23.0609
The following release notes apply to Microvellum Foundation Library, Build 23.0609.
This update includes many changes, additions & resolutions to the Microvellum Face Frame, Closet, & Office Furniture expansions. Not all users will have access to these special products. Contact your account manager for more information.
Additions
- Added additional Hettich hinges and plates.
- Sensys 8631i 95 hinges and Cross Direct Plates
- Added new Harn Ritma Cube drawer system for the AU/NZ region. Note: Not all drawer heights have graphics at this time.
- Added two Lockdowel Drawer Slides:
- Lockdowel LDSCU-3D Undermount
- Lockdowel LDSMSC45
- Added new (beta) Lockdowel Channel Lock wood drawer box subassembly. This is an initial release for testing only at this time.
- Added the Timberline CompX Double Door Latch
- The Box End & Box End FF products greatly enhanced with new dynamic features and abilities.
- Added new products:
- Base Applied Panel Surround FF
- Base Island Box End
- Office 4 Drawer Mobile pedestals
- Office 2 File Mobile pedestals
- Office 2 Drawer & 1 File Mobile pedestals
- Added a new hardware “Twin Wheel Castor_67mm”. When used in a mobile pedestal product, the value after the underscore will be used as the castor height, used to calculate the space distance required.
- Added the "Strip Lighting" subassembly insert to all Closet products with a prompt check option to add strip lighting for each bay. We have also added it to the Foundation Master Cabinet and the Master Open Cabinet.
- Added a "Miter/Butt" Option for Face Frame Pie Cut Corner frame parts.
Modifications
- Cabinets with drawers will now reduce their drawer depths accordingly when using the rear modification options. Note: Not supported with designer cabinet products.
- Fillers & Applied End cabinet parts will now have edge-banding applied to bottom or top edges when the global variables "G!Upper_Bottom_Finished, G!Base_Bottom_Finished", etc. are selected on.
- The “FE” text 2D plan view draw token has been moved out of the countertop subassembly and into the 2D Instructions subassembly. We have also moved the Filler “F” 2D Plan view text away from the product description to avoid collisions. Lastly, we have moved the finished end “F” 2D plan view text away from the cabinet to avoid collisions with other cabinets.
- Component Doors subassemblies now have handle prompts to link the handle settings from the parent product down to the nested subassembly doors. Changes such as horizontal handles will now pass down to the nested finished faces subassemblies.
- Global variable “G!Applied_Ends_To_Floor” will now affect the Base/Tall Applied Panel Products.
- Added to all Office Desk products the "OpenID" prompt and set the Product Type to "Base Open". This will now link all the CAD layers to the rendering.
- "LookupTablePosts" has been added to the Factory workbook for greater control when using these within products (such as the Box End).
Resolutions
- Resolved issue with Master Vertical Designer Cabinet, Tall Double Door cabinet, and similar - issue with Upper Pull location at cross sections.
- The Wood Drawer Box now correctly using the global variable "G!Drawer_Box_Construction_Holes_Z_Value".
- Access Panel subassembly insert will now create a cutout when used in a cabinet with the "Overlay Bottom/Top" option selected.
- Resolved several issues with rear modification options within the face frame cabinets.
- Resolved issue with Base Corner Cabinet FF - Front Stretchers were giving bad default dado machining.
- Resolved issue with Face Frame Blind Corner cabinets when using beaded frames. Top/Bottom Rails now have the correct part length.
- Resolved machining issue in very wide cabinet thick back parts that were using dowel construction.
- Resolved issue in the one-piece face frame when using different split heights. The center stile will now be removed if the bay next to it is at the same height.
- Resolved issues with the Face Frame Rail Modifiers.
- Resolved issue with Base Molding feature within Face Frame cabinets that prevented them from drawing in 3D.
- Resolved issue with glass panel locations within the profile doors when pantry door was selected with more than two panels.
- Resolved issue with Corner Cabinets and adj shelf line bore holes into thick back when also using a notched rear corner.
- "Hinge Location Bottom" variable in Component Doors subassembly now visible.
- Resolved issue within the Office Open Hutch product that prevented the adj shelves to appear.
- Resolved issues with Office Credenza products that involved the top & bottom reveals when changing top & bottom overlay variables.
- Resolved Office Furniture issue with the 2D elevation tokens. Will now look correct when having an overlay top or bottom. The top and bottom will now draw on the hidden layer only when they are not overlayed or not open.
- Resolved issue with Office Chair product that prevented them from appearing in 3D.
- Removed legacy "Activity Tokens" from the Blended Locker Door subassembly.
- "Osborne Wood Product Legs" and "Base Moulding" preview help images will now appear in the prompts UI.
- Resolved issue in Closet products related to the "Opening Z" being incorrect for the single closet products. Also resolved an issue with the placement of the center shelf when the bay height is less than the height.
Microvellum Foundation Library Release Notes | Build 23.0517
The following release notes apply to Microvellum Foundation Library, Build 23.0517.
![](https://img.zohostatic.com/zde/static/images/exclamation.png)
This update includes many changes & additions to the Microvellum Face Frame expansion. Not all users will have access to these special products. Contact your account manager for more information.
Additions
- Added new drawer system Rocheleau R13 EVO (available in Canada)
- Added new undermount drawer slides Richelieu 818 and 828 EVOLUTION (available in Canada/US)
- Added Hettich Novisys 8848i 105 hinges and Cross Oblong Plates.
- Added Peka Magic Corner Comfort Blind Corner Pullout.
- The Master Cabinet product now has an option to add a Bottom Drawer.
- Added an option for Toe Kick Drawer to all standard base and tall cabinets. It can be turned on by selecting from the "Toe Kick Assembly" prompt dropdown menu. Selecting this will automatically change the sides to extend to the floor.
- Added global variable to control the alignment of the bottom rail in applied ends to the bottom rail in the face panels.
- Align Applied Ends Bottom Rail To Face.
- Added automation to reduce drawer depths when cabinet rear modifications (notches) are turned on.
- Added Face Frame Only category with 10 new products.
- Updated the Master cabinet FF, all Blind Corner FF cabinets, 1, 2, and 3-drawer FF cabinets, and all Corner FF cabinets to work with the new pull-outs from the previous update.
- Added "Drawer Division FF" and included it to the Base 2 Door 2 Drawer FF, Base Open 2 Drawer FF and the Master Cabinet FF. It will turn on when the "Top Drawer" and "Double Top Drawer" prompts are ticked.
- Added an additional face frame inset hinge condition to better support the different types of hinge applications. There is a new column added to the hinge and plate tables in the hardware lookup tables and a new global prompt "Face Frame Inset Hinge Option B Inside Overlay Threshold" added to control when option B is used.
- Added “Bottom Rail Three Sided Notch With Arch” Face Frame Rail Modifier. Can be used in conjunction with the global “Face_Frame_Extend_Bottom_Rail_To_Floor".
- Added two global variables to control allowances for FE scribes on applied ends and floor scribes.
- Applied Ends increase Rear Stile at FE Scribe.
- Increased Applied Ends Bottom Rail At Floor.
Modifications
- Corner Cabinets with Two Doors will now default to use 180-degree hinges.
- Starter Panel product has been modified to better support the miter edge options. Polyline depth on all miter edges will be the panel depth less 0.01.
- Drawer comments inside the Inner Drawers Subassembly changed from Bottom Drawer, Second Drawer, etc. to Bottom Drawer Box, Second Drawer Box, etc. so the Drawer Box List report filters correctly and displays these as Drawer Boxes.
Resolutions
- Resolved additional issue with Door Buffer locations when using aluminum handles.
- Resolved issue when frameless cabinet door reveals increased enough to require a half overlay hinge/plate.
- Resolved issue with the Microwave appliance subassembly. The origin will now be correct when used inside cabinet products.
- Resolved issue with Horizontal Designer Suspended Cabinet. Instead of using the component drawers, it now uses individual drawers and finished faces subassemblies for each bay. We have also reduced the number of bays to 5 to keep the product simplified and cleaner. We have also resolved an issue with the bay origins to account for the double-drawer division option.
- Resolved an imperial/metric conversion issue affecting the closet hang rails when drawing in 2D elevation.
- Resolved 3D graphic issue for Grass Elite Undermount 16 drawer runners.
- Resolved 2D plan view issue in the Wall product when using the Bulkhead feature.
- Missing Grain Direction data added to cabinet fillers
- Resolved issue with glass panel locations in the MV Profile Door.
- Resolved issue with the "Opening Z" being incorrect for the single closet products. Also resolved an issue with the placement of the center shelf when the bay height is less than the height.
- Resolved issues with rear modification options with Face Frame Cabinets.
- Resolved issue with Vertical Opening Splitter FF. The "Double Shelf" option will now locate the shelves correctly in Z. Also added the virtual routes for the cabinet modifiers to the shelves.
- Applied Ends with 5 Piece Panel or MV Profile Door will now miter to the face frame when this global option is selected. Resolved issues with the side face frame as well when using miter and side clip modifications.
Microvellum Foundation Library Release Notes | Build 23.0502
The following release notes apply to Microvellum Foundation Library, Build 23.0502.
This update includes many new kitchen accessories & hardware products that may not be available in every country or region.
Additions
- Added three new Hettich Veosys hinges.
- Added the ability for separate Left/Right hand swing doors in Corner Cabinets.
- Blind Corner Cabinet- Added option to match the Blind Facia Panel to the "Door Height".
- Added feature to MV Profile Door to look at small pocket tool when the panel size is under a set size.
- Added a Universal Hardware Subassembly Insert. Also added additional hardware items that can be utilized by this new subassembly.
- Hook ceiling epco 301 2c
- Hook ives 201 double coat
- Hook ives coat & hat 571
- Grommet 3 hole mockett xg
- Pants Rack Left
- Pants Rack Right
- Trousers Holder
- Trousers Swivel Pull Out Left
- Trousers Swivel Pull Out Right
- Clothing Carrier 12 inch
- Clothing Carrier 16 inch
- Swinging Hanger
- Valet Rod Left
- Valet Rod Right
- Belt Rack 4 Peg 10 Inch
- Belt Rack 5 Peg 12 Inch
- Belt Rack 6 Hook 12 Inch
- Belt Rack 6 Peg 14 Inch
- Belt Rack 7 Peg 13 inch
- Belt Rack 7 Peg 16 Inch
- Belt Rack 10 Peg 19 Inch
- Tie Rack 12 Inch
- Tie Rack 19 Peg 20 inch
- Tie Rack 27 Peg 14 inch
- Closet 16mm Oval End Support
- Closet 19mm Oval End Support
- Closet 25mm Oval End Support
- Closet 25mm Round End Support
- Closet 35x15 Oval End Support
- Pole Cup Epco 850 1p0625
- Closet Rod Cup 32mm
- Closet Rod Full Cup 32mm
- Added/updated additional Appliance products/subassemblies including 309 new 3D & 2D elevation/section drawings. The below appliance categories have all been improved with a new structure that allows for brand name filters and regional availability considerations.
- Dishwashers
- Dryers
- Freestanding Ranges
- Fridges
- Microwaves
- Rangehoods
- Washing Machines
- Wall Oven
- Added Pullout options to all frameless Corner Cabinets, Blind Corner Cabinets, and Master Cabinets.
- Added “Drawer Component Options” to frameless drawer cabinets that allows users to specify each drawer to alternatively be a Waste Bin Pullout or Base Pullout. These two new options will have their own list of options.
- Added five new cabinet products:
- Base Pullout
- Tall Pantry Pullout Cabinet
- Base 1 Drawer Waste Bin
- Base 1 Drawer Waste Bin With Top Drawer
- Developed and added a number of new subassembly structures to accommodate additional cabinet inserts. These include new user definable LookUpTables to store each item’s technical details such as machining and 3D blocks for visual representation. The tables are also used to filter out regional and size limitations. 421 new CAD drawing blocks have been added to the Graphics\Hardware directory. See below for new items utilizing the new structure.
- Added a number of Kesseböhmer product lines
- Portero lift out baskets
- WASTEBIN pullout
- LeMans blind corner storage pullouts
- MagicCorner blind corner storage pullouts
- Added a number of Peka product lines
- Pinello Board Pullout
- Pinello Bread Pullout
- Pinello Cargo Pullout
- Pinello Internal 150mm Pullout
- Pinello Spice Pullout
- Pinello Towel Pullout
- Snello Pullout
- Pleno Plus Larder Pullout
- Pleno Standard Larder Pullout
- Added a number of Vauth Sagel product lines
- Corner Storage pull-outs
- COR Wheel 3-4
- COR Wheel Pro 3-4
- Blind Corner Storage pull-outs
- COR FOLD
- COR FOLD G
- COR FLEX
- CORNERSTONE MAXX
- Tall Cabinet pull-outs
- TAL Gate N
- TAL Larder
- TAL Gate
- Side mounted and front mounted base pull-outs
- SUB Side 90
- SUB Slim 90
- Added a number of Rev-A-Shelf product lines
- Base Pullouts
- Base Pullout With Knife Block & Utensil Bin
- Two-Tier Cookware Organizer
- 5349 Bottom Mounted Waste Bin
- Updated Salice Vibo Pullout Waste System (and others) to conform to new structure
- Added a 3D warning message “block” that will appear when user selects a pullout/waste bin insert that does not meet the minimum inside opening size. This block can be used to select the insert when opening the subassembly’s prompts UI.
Resolutions
- Resolved issue(s) with Frameless Drawer Bank Cabinets that affected the drawer front calculator and default drawer front heights.
- Added "N" to Number/Dimension in all prompts that are not dimension values as this was affecting certain results in reports.
- Resolved Corner Shelving Shaped Front issue when opening was too small.
- Drawer option prompts will now show in Master Cabinet when drawers are selected.
- Added Missing N Height Blocks for Blum LEGRABOX drawer system.
- Applied End Products are now looking to the correct default door wizard variables (Base/Tall/Upper).
- Resolved issue with Door Buffer locations when using aluminium handles.
- Resolved misspelling of "Pantry Pullout" in Global variables file.
- "Drawer Handle Type" prompt in Door/Drawer Cabinets will now always be visible when top drawer is present.
Microvellum Foundation Library Release Notes | Build 23.0320
The following release notes apply to Microvellum Foundation Library, Build 23.0320.
- Master Single Carcase Designer Closet
- Closet Aluminium Sliding Door Frame (with new Dias Sliding Door subassembly)
- *Added additional Closet Subassembly inserts:
- Hettich Duo Lift System insert.
- Peka Shoe Pull-Out.
- *Added two new Face Options to certain closet products:
- "Folding Doors"
- "Sliding Doors"
- *Added "Base" and "Crown Moulding (Cornice)" options to closet products. These can be found inside the advanced options tab.
- *Added Dynamic Part Names to match each closet Bay Opening. This will be useful for identifying individual parts and knowing which opening they belong to.
- *Added "Shaped Front Shelves" option for closet corner subassemblies.
- *Added the ability for L and U shape closet layouts to switch their overlay tops/bottoms to run full length of the width or the depth.
- *Added the ability for all closet products to have "Finished Ends Left/Right". This will accommodate when a different material is desired at exposed finished ends.
- *Added full toe kick options to all closet products. This includes Kick Face, Toe Kick Assembly Box, Adjustable Legs, and Notched Toe Kick. These span the full width of the closet layout.
- *For multi bay closet products we added a prompt for each bay so users can change the bottom options within each individual bay. Options are "No bottom", "Full Bottom" and "Full Bottom with Kick".
- *For multi bay closet products we needed the ability to have the base and top of each bay to line up with system 32 when changing the bay height. We have added prompts for each bay to calculate the bay height when using system 32. Each bay now has a "Required Bay Height" prompt. The user can enter the required height and the height of the bay will be calculated by the "Bay Height" which will calculate to the nearest derivative of 32mm.
- *Previously you could only change the height of the bays to be less than the closet height which would rase the bays off the floor for a wall hung closet. We now have the ability to make the bay height greater than the closet height, which will increase the bay height above the closet height.
Modifications
- Modified the Drawer Options List. Waste Bins and Pull-Outs have been removed from the drawer options list and are now on their own individual lists. Five new rows have been added to the LookUpTableListOptions table inside the factory workbook. Additional options will be populated within these rows in future library updates.
- Waste Bin Pullout Options
- Base Pullout Options
- Pantry Pullout Options
- Blind Corner Pullout Options
- Corner Cabinet Pullout Options
- *Made improvements to Closet products’ prompts to prevent users from selecting items not possible (error trapping).
- *When changing Closet products to System 32, the default construction method will automatically be changed to Cams. Also, cam lock hole locations will use "G!Front_Shelf_Hole_to_Edge" instead of "G!Cam_Distance_to_Front_Edge".
Resolutions
- Resolved issue in Work Order Summary Report. Designer products will no longer show door swings for each bay.
- *Resolved issues with Closet products using system 32. Inserts will now properly line up with systems holes when changing the bottom options for each bay. Also have added prompts to calculate the positions and hole positions of parts within the subassemblies to line them up with the system holes of the partitions of the closet.
- Added missing N height dwg blocks for Blum LEGRABOX.
- Resolved issue in Drawer Stretcher subassembly that was causing inconsistent dado machining at the right side.
Microvellum Foundation Library Release Notes | Build 23.0210
The following release notes apply to Microvellum Foundation Library, Build 23.0210.
Additions
- Added a new global variable “Hinge Offset From Edge” to provide easier control without needing to update the finished faces subassembly.
- Added a sample Hafele Aximat 300 Institutional hinge.
- Added a new global variable “Corner Cabinet Carcase Radius” to enter the radius in the corner of the pie cut cut-outs on the tops and bottoms of corner cabinets.
- Added the Canadian door supplier Elias Woodwork Door Wizard Component to give additional solid wood door options. Visit Elias Woodwork's official website to view their catalog.
- Added three new rollout/pullout shelves (best used with the Inner Drawers component):
- "Wood Rollout Flat Shelf"
- "Wood Rollout Flat Shelf Lip Down"
- "Wood Rollout Three-Sided Shelf"
- Added four new cut part material pointers for the above new rollouts. If updating your library, please verify that the desired materials are associated.
- "Rollout Shelf"
- "Rollout Open Shelf"
- "Rollout Sides"
- "Rollout Open Sides"
- Added 12 additional Edgeband material pointers for greater control over top and bottom edges on cabinet sides and backs (Finished vs. Unfinished). If updating your library, please verify that the desired materials are associated.
- Added an option to turn on and off the bottom cut-out for the Upper Undermount Rangehood Cabinet.
- Added a prompt in the rangehood products for "Removable Front". This will situate the front panel in-between the top and bottom so the panel can be removed. This can be added to any product using the center corner notch.
- Added a global option “Cam Sides Inside” so that the drilling for the cam pin can be drilled on the opposite side for backs to keep all machining on the same face.
- Added global option “Elevation 2D Drawer Front Lines” to control if you want 2D diagonal elevation lines on drawer fronts.
- Added Hafele Matrix UM A Syncro drawer slides.
- Added the ENKO Drawer system for the NZ market.
- Added two Estimating products to the Miscellaneous category. These can be useful for creating project estimates and/or when needing to add additional line items to the Costing Reports.
Modifications
- Cabinet sides now point to “Carcase Edges” for their edgebanding. The prompt "Side_Edges" has been removed from all products. This has created some confusion, as the sides should look at the carcase edge.
- The machine point of Tops, Bottoms, and Fixed shelves of corner cabinets has been changed to the back corner of the parts. This will better accommodate the correct orientation of parts on doweling machines. Also, in the fixed shelves, there has been a prompt added to change the side of the mortise if needed.
- Wood Drawer Box & Dovetail Drawer Box now have the same “wood block spacer” feature that other drawer systems have.
- Drawing templates have been updated to improve the lineweights in viewbase. Layers have been added, and lineweights have been set to default.
Resolutions
- Resolved issue with drawers associating with sides in Face Frame Designer cabinets.
- Resolved issues with the "Face Frame FE Miter" option at Applied Panel end conditions.
- Resolved an issue with the Base, Tall, Upper, Cabinet Accessories Filler with Cleats products.
- Resolved an issue with the Hafele Alto drawer system. There was a name error in the hardware name. Also updated the hardware materials in the hardware file.
- Extruded Molding Products will now have the proper right-click menu option in Toolbox (Pick Points for Extrusion).
- Resolved an issue with shelf support holes when changing the machining origin prompt to "Top."
- Wire handle pulls will no longer associate with the Upper Corner Diagonal cabinet bottoms.
- Under Stair Cabinets will now draw properly in 2D elevation.
- Numerous other small, reported issues have been resolved.
Microvellum Foundation Library Release Notes | Build 23.0113
The following release notes apply to Microvellum Foundation Library, Build 23.0113
Additions
- Implemented a "Push Catch All Doors" option in the Hardware Wizard.
- Added the "Magnetic Catch Liberty" hardware option as an alternative choice for push catch.
- Introduce "Product Version" and "Subassembly Version" fields as a new prompt to help users keep track of the version of each product and subassembly they are using in their library.
- Incorporated a new "Shelf Clip Gap" variable in all adjustable shelf subassemblies, giving users more control over the fit of the shelves.
- Added hardware materials for Hafele Matrix Box S and Matrix Box Slim.
Modifications
- Updated the Default Push Catch option to include catches at the top and bottom of Tall Cabinet doors.
- Blind Facia and Corner Filler parts inside Blind Corner Cabinets will no longer be affected by the top/bottom reveal variable as the doors do and will now remain at the height of the cabinet.
- Enhanced the shelf and 2D instructions subassemblies to search for the word "Glass" in the product description and use this information to determine which parts to show or hide in 2D elevations.
- Adjusted the countertop/benchtop products so that the part widths will now be the product depth, and the part lengths will now be the product widths, to improve compatibility with grained materials. Additionally, refactored and updated all mason miter polyline tokens to use VECTOR and PNT functions.
- Renamed the majority of Office Furniture products to make them easier to distinguish from regular Foundation Library Frameless products. To update Office Furniture products, it's recommended to delete the existing products first.
Resolutions
- Fixed an issue with the cabinet Nailer dowel machining.
- Fixed an issue with the quantity of shelves in Open Diagonal Angle Cabinets.
- Resolved an issue with the Drawer Front Calculator within the Component Drawers FF subassembly.
- Fixed an issue with the location of drawer slide holes in the Wood Dovetail Drawer Box subassembly.
- Addressed an issue with the Z origin location of Dovetail Drawers when used as rollouts with spacers.
- Fixed an issue with door/drawer cabinets when the "Use Rail Notch" option is unselected.
- Enhanced the global variable "Drill Through at Division for Shelves" to now control the Division with Adj Shelves subassembly.
- Tall and Upper Corner cabinets are no longer controlled by the global shadowline option.
- Addressed an issue with certain face frame cabinets when using the "Tall Face Frame Sides Full Height" feature, which now extend to the floor when using the "Notched Toe Kick" option.
- Improved Mitered Shelf product to respond correctly when using the Mirror Product feature.
- Fixed issues with the Shelf Edge feature when using the Hardware Edge Array connecting option.
- Resolved notch issue when selecting a rotated "Wrapped Batten".
- Fixed an issue with certain router bit drawings caused by extra line entities (Ogee 12P7 TW7506.dwg and Bead Cutter 3P2 TBB4 half.dwg).
- Addressed an issue with captured backs in Any Angle Cabinets.
- Resolved an issue with the Cabinet Faces Only product, the Drawer Front Calculator now functions properly with all drawer quantities.
Year of 2022
This section lists all of the Foundation Library builds that released in the year of 2022.
Microvellum Foundation Library Release Notes | Build 22.1207
The following release notes apply to Microvellum Foundation Library, Build 22.1207
Additions
- Added a new subassembly called Decorative Routing which can be added to any product to produce parametric decorative routing to any face. To demonstrate, this has been added to the Valance product and the Box End product.
- Added a generic 2D Leg Leveler section drawing to represent leg levelers in 2D cabinet sections. Updated the hardware drawing “Leg Leveler Section.dwg” to match your desired leg leveler.
- Added new global variable “Cabinet Depth Includes Door”, located inside the User Preferences category. Select the checkbox to include the Finished Face (Door) thickness and the Door to Cabinet Gap as the product depth for open cabinets. Otherwise, the Depth of all cabinets will only be the carcass box.
![](https://img.zohostatic.com/zde/static/images/file.png)
Added a new subassembly, 2D Instructions, to facilitate a new location for storing 2D draw tokens (see Modifications below).
Modifications
- Moved the location of all 2D Plan view, Elev view, Cross Section, Elev Section, & Plan Section draw tokens for most regular Frameless cabinets. They are now inside a single new subassembly called 2D Instructions. At this time, the Corner, Angle, Closet, Face Frame, & other specialty products remain unchanged.
![](https://img.zohostatic.com/zde/static/images/info.png)
The reason the location of the draw tokens was moved is to encourage users to customize their own 2D text, dimensioning, and other annotations. After this update, users can exclude updating the “2D Instructions” subassembly, preventing their customizations from being overwritten.
- The default Depth value of all open cabinet products will no longer include the door thickness & gap. Select the new global option “Cabinet Depth Includes Door” to revert to the previous behavior.
- Selecting "Screw Construction" for Nailers will automatically switch to "Dowel Construction" at Finished Ends.
Resolutions
- Resolved origin issues in certain cabinets when the finished end was a different thickness than the unfinished end. This occurred in double drawer & blind corner with drawer cabinet products.
- Resolved issue in the Internal Drawers With Faces subassembly. Drawer Depths will now calculate correctly.
- Resolved issue with certain Tab Pull 2D elevation drawings.
- Resolved issue with Aluminum Handle Door 2D elevation at Upper cabinet conditions. Also, the handles will now be on the HWR layer.
- Resolved issue with Blind Corner Mounting plates. Plate Location From Door Edge (X Origin) was not correct for Right Swing conditions.
- 2D Cross Section drawing of Countertops will now follow the parametric depth of the cabinet product instead of a global depth value.
- Resolved a Fixed Shelf Dado thickness issue inside the Vertical Splitter subassembly.
Microvellum Foundation Library Release Notes | Build 22.1102
The following release notes apply to Microvellum Foundation Library, Build 22.1102
Additions
- Added Processing Station information and sorting to the Nest and Saw reports.
Added Nover Krome Premium drawer system for the AU/NZ region.
- Grass Dynapro 40kg Soft-Close and Grass Dynapro 70kg Soft-Close is now available in the US region.
- The Wood Drawer Box now has a prompt option to turn off the front notch for undermount runners.
- Added Perfect Grain Containers (per bay) to Master Horizontal Designer Cabinets and Master Vertical Designer Cabinets. Prompts were added to give control of grain matching across bays from within the product.
- Added global variables to control the fixed shelf edge type and banding options. Previously the fixed and adj shelves looked at the same global.
- Added three Profile Door Handle options to the Door Wizard:
- No Profile Handle
- Add Splay Handle
- Add J Handle
Modifications
Updated Misc Panel product to have Machine/Base Point of 1.
Renamed Krome and Krome Linea drawer systems to Nover Krome and Nover Krome Linea.
- Aluminum Handles options moved to the Hardware Wizard.
- Lift-up hardware now has its origin attached to the cabinet sides and the following details have been modified:
- All the lift systems have had their insertion point changed so that the 0 point is now the setback from the front edge to the first pin or screw mount.
- All blocks have been updated and machine tokens updated.
- In the lookup table for lift systems, in the hardware file, the last blank column is now used for the setback of the hardware from the carcass edge.
- Face Frame applications are now possible.
- Improvements made to the Toilet accessory product.
- Updated the Drill machine token in the Handles/Pulls to look at the "L!Thickness_Door instead of the M!Base_Door_Thickness."
- Upper Rangehood Cabinet now uses the Component Door Subassembly For lift-up Doors.
- Pocket cut-outs within MV Profile Doors will now pocket from the IF(Region="US","center","centre").
Resolutions
- Resolved issues in Frameless Blind Corner Cabinet products.
- Resolved issue in the Blum Legrabox drawer system. Back drilling was not accounting for the bottom notch.
- Resolved issue in the Component Drawers subassembly that prevented grain direction selections from passing down to the nested Finished Faces subassembly.
- The Corner Suspension Brackets subassembly updated to match recent changes to the regular suspension bracket subassembly.
- Extruded Bar Die Wall will now draw the foot rail.
- Resolved machining issue with Shadow Rails when the Overlay Top option was selected.
- Resolved missing/incorrect machining with certain Handle Rods.
- Fixed issue with Door Buffer placement on Rangehood Cabinets.
- Resolved issue in Lift-Up door cabinets where the profile handle option was on the wrong edge. Also corrected an issue with lock locations.
- Resolved issue when using Wood Drawers with the Inner Drawer (Rollout) option. The bottom drawer was positioned too low and would sometimes collide with the opening bottom depending on which runner slides were selected.
- Wood Drawers now point to the Hardware Wizard for default drawer spacer height selection.
- Titus Tekform Slimline drawer system "Front Fixing Bracket Hole Dia" is now 8mm (not 10mm) per manufacturer’s specifications.
- Free Standing Range now has width dimension on the 2D Elevation.
- The dishwasher's (and other appliances) width dimension is now in line with other base cabinet dimensions in the 2D Elevation.
- Corrected location of 2D Elevation grain symbol on the Sink False Front.
- Resolved issues with all style type reports to use MVValueFormat instead of Round in the Length x Width fields.
Microvellum Foundation Library Release Notes | Build 22.1005
The following release notes apply to Microvellum Foundation Library, Build 22.1005
Additions
- The Global Variable “Plan Finished End Text” was added to optionally add plan view text at each cabinet finished end condition. Enter zero or leave blank to disable.
- Improved the automatic “Drawer Spacer at Hinges” feature.
- Added global control with new variable "G!Drawer_Spacers_At_Hinges".
- Updated the two Inner Drawer subassemblies by adding "Left_Drawer_Spacer, Right_Drawer_Spacer" prompts, and moved the controlling logic there instead of the Prompt Value column. (Turning on left/right division will also disable the spacers.)
- A new Hardware Wizard variable “Default Drawer Spacer Height” was added to give users control of the spacer size (height).
- The Hardware Wizard variable “Dowel Fitting Wood Drawers” was added to give users the same control over drawer box dowels as with cabinet dowels.
- Imported Valance product from the legacy Component Cabinet library.
- Added “Diagnostic G Code Test Product” to assist with diagnosing g-code & machine connections.
Modifications
- Dowel tokens were updated in Nailer parts to check if the width qualifies as a small part based on the “G!Dowel_Small_Part_Threshold” variable. This can change the dowel location/pattern used.
- Certain prompt variables that could controlled by both the parent product and the subassembly prompt have been adjusted to only allow changes from the parent. If you see a subassembly prompt, such as "Adj Shelf Qty", greyed (dimmed out), these will need to be changed from the parent product cabinet.
- Hardware Array option for Lamello Cabineo will now default to face 5, not 6 for general cabinet parts like the bottom. This is now a variable controlled inside column 7 of "H!LookUpTableEdgeArray".
- "Finished Top" option will now turn off Countertop Fixing holes.
- The global variables listed below have been updated to now look to the Hardware Wizard for their values. This was done to match the cabinet dowel settings. Updated the 5mm dowel row inside "LookUpTableDowels". If you are running the update utility, please verify the values are still correct for your setup.
- "Drawer Box Dowel Edge Depth"
- "Drawer Box Dowel Face Depth"
- "Drawer Box Dowel Diameter"
- "Drawer Box Dowel Edge Diameter"
Resolutions
- Resolved issues with the 2D plan and elevation views of countertops/benchtops in cabinet products. The overhang variables will now correctly reflect changes, including the back splash parts.
- 2D Elevation of corner cabinets will now show carcass parts at open conditions.
- An issue in the Vertical Splitter Subassembly that caused opening height problems in cabinet openings was resolved. The prompt "Position of Shelf" value should remain set to zero as default.
- An issue in Hettich Quadro V6 IW20 & Hettich Quadro V6 drawer slides was resolved. It will now calculate the correct drawer box depths.
- Blum Metabox drawer system will now include machining holes for the Soft Close feature.
- The bullnose detail within Countertops/Benchtops will now correctly be displayed in 3D in Imperial.
- The cabinet modification option, Cabinet Notch Center, will now correctly pass the center distance to drawers when they are a nested subassembly.
- A lock dowel rotation issue inside the Wood Drawer Box was resolved.
- An issue in the Cabinet Faces Only product that prevented the display of Door Type was resolved.
- The Component Doors subassembly now has the "Add Lock" prompt.
- Face Frame Reports were updated to correctly display the part item# to match the Face Frame Rear picture.
- Face Frame Split Height Cabinets - Mid Stile chamfer tokens are now only active and on when set to "Haunched".
- Numerous other small issues that were reported by users have been resolved as well.
Microvellum Foundation Library Release Notes | Build 22.0902
The following release notes apply to Microvellum Foundation Library, Build 22.0902
Additions
- Added Titus Tekform & Tekform Slimline Drawers.
- Updated/added EMF labels for all types. Metric sizes have the AU/NZ flag turned on, so the W x L dimensions are reversed.
- Added Finished Leg & Finished Leg w Radius products from legacy library.
- Added Dovetail Drawer option.
- Added Product Group Kitchen Island Group.
- Added "Finish Face Edges" prompt to all cabinet products to aid with the XML import tool.
- Added 44 new global variables and six new material pointers to support a future
- expansion.
- Added “Lock Dowel E3259BM Channel Lock” as a new Hardware Array option.
Modifications
- Updated the Sawing Optimization Report.
- Made numerous changes and updates to most of the drawer systems to match manufactures’ specifications.
- Updated the list of available drawer options.
- Inner Drawer (Rollouts) Spacers will now automatically turn on to avoid door hinges.
- “Lock Drop Front” option in Wood Drawers will now automatically activate with locked drawers.
- "Vertical Front Rail" option will now use the new material pointer "Sub Front" for the Front Stretcher parts. This will now allow a different material to be used for the "Vertical Front Rails (Sub Fronts)".
- Added two global variables to separate control of Overlay/Full bottoms for Upper cabinets vs Base/Tall.
- Updated Hardware Array machine tokens to support a Mirrored hardware item such as Lock dowel.
- Drawers in Face Frame Cabinets now set to frame opening width instead of carcass opening (Face Frame Expansion).
- A new global variable was added to set the threshold amount for the Inside Face Frame Overlay. This allows the drawer slides to tuck behind the face frame and bump the Cabinet Side or Partition.
- Updated the factory table “LookUpTableSystemDrawerSlide” to contain values more “friendly” to imperial users.
- Updated the factory table “LookUpTableDrwSlideAccuride3834” to match manufactures' product codes.
Resolutions
- Resolved issue within the Sawing Optimization Reports.
- Resolved issue within Drawer Box List Report to correct drawer box size problem.
- Resolved issue with slide hole locations at inset drawer condition.
- Resolved Issues with Drawer Dividers when used with the Shadowline Feature.
- Resolved issue when using the Generic Five Piece doors, the door parts no longer get included in the 2d face frame images (Face Frame Expansion).
- Resolved issue with Intermediate Rail 1 Z Origin in Face Frame cabinets. Issue triggered when a value was added to Face Frame Top Overlay (Face Frame Expansion).
Microvellum Foundation Library Release Notes | Build 22.0729
The following release notes apply to Microvellum Foundation Library, Build 22.0729
Additions
- Added “No Back” options to the dropdown list under the “Back Construction” prompt. This will remove the back from the product.
- Vertical Splitter subassembly - Added options for a timber lip to the front of the shelf.
- Added Support for CutRite Perfect Grain to relevant products.
- Added “LibraryName” prompt to all products.
Modifications
- Inner Drawers subassembly – Changed the calculator so that it calculates from the top down to keep it in line with the standard drawer cabinets.
- Changed the way we search for wood drawers to just search for wood in the name, this way we can add more types of wood drawer subassemblies and the relevant prompts will appear when needed.
Resolutions
- Countertops Left L and Right L shape – Resolved an error with the mason mites creating name errors in the product.
- Master Wall Oven Cabinet – Resolved an issue with the top cabinet being out of position when changing the fixed shelf material.
- Tall double door cabinets – Resolved an issue with the shadow rail being placed in the incorrect position between the top and bottom doors.
- All Cabinets – Resolved an issue with back disappearing when selecting overlay Tops due to a name error in the “Top_Capture_Deduction” prompt.
- Resolved an issue where the “Pocket Toe Kick” prompt was not looking at the global prompt.
- Resolved an issue where the top and bottoms are coming out short if the nailer and back materials were different thickness.
- Resolved hard values in the lookup table of the Sink subassembly.
- Resolved an issue where the Mirror function was only working on left doors not right doors.
- MV Profile Door - Resolved an issue with the profile cut-outs coming out incorrect size.
- Inner Drawers subassembly – Resolved an issue with the bottom drawer being added twice.
- Countertop With Substrate – Resolved an issue with the “Substrate_Setback“ Prompt hard valued metric value.
- Resolved issue in Drawer Box Report. Width and Depth are now the actual drawer box size, not the subassembly size.
Microvellum Foundation Library Release Notes | Build 22.0625
The following release notes apply to Microvellum Foundation Library, Build 22.0625
Additions
Added Access Panel Subassembly (from legacy component library)
Added the prompts "Extend Left Side To Floor" and "Extend Right Side To Floor" to all cabinets. Also have added a global to turn this on as default for every cabinet.
Solid wood doors will now show the 3D door swing.
Added opening calculator for Inner Drawers.
Add the ability to change "Continuous Shelf Hole Condition" in Subassemblies. Added the prompts "Continuous Shelf Hole Condition" and "Continuous Shelf Offset". You can now change the "Continuous Shelf Hole Condition" from Fixed to Centered in the subassemblies. When Centered is selected the "Continuous Shelf Offset" is used, as the offset from the top and bottom will be the same. When it is set to Fixed, "Continuous Holes Distance From Top" and "Continuous Holes Distance From Bottom" are used.
Added Diagonal Crown Molding for Diagonal cabinets.
Added a global prompt to control if we want a corner notch relief or not on applied toe kicks with notched ends.
Added the option to have a finished end with a notched toe kick when using adjustable legs (or other type of toe kicks) by default.
Added Under Stair Cabinets:
Under Stair 1 Door
Under Stair 2 Door
Under Stair Vertical 2 Bay Cabinet
Modifications
Updates & improvements to Metric & Imperial DWT files.
Cleaned out (simplified) Imperial Dim Styles and text styles.
Updated Appliance layer names to match data (3D_STAINLESS APPLIANCE to 3D_STAINLESS STEEL APPLIANCE).
Corrected default imperial zoom factor.
Glass layers should now have transparency values.
Line types should be by layer instead of by block.
Moved three categories out of Frameless Cabinetry: Countertops, Miscellaneous, Parts.
Sink subassembly Finish Options now to be "BLACK|WHITE|STAINLESS STEEL" to match layer naming convention.
Part & Product Labels now include the Project Level Prompt called “Region”, which flips WxL to LxW for AU and NZ.
Resolutions
Resolved an issue with Tall Wall Oven and Tall Wall Oven With Microwave: Side turning off when selecting "Applied Ends".
Resolved an issue with Master 2 Bay Horizontal Cabinet, Master Horizontal Designer Cabinet: Top drawer was not drawing when "No Door" is selected
Resolved issues with Upper Undermount Rangehood Cabinet:
Under Panel and Vertical Splitter parts not adjusting in Z for bottom valance.
Rails option for the top type will have a full top and a front rail.
Under Panel Overhang Left/Right prompts still visible when under panel is disabled.
Resolved an issue with Diagonal Corner Cabinets: crown moulding doing both pie cut and diagonal shapes.
Resolved an issue with MV Profile Doors - The pattern selection for all 8 panels will change to a square pattern if the pattern is under 2x the pattern height.
Resolved issues with Corner Base moulding when using Running Toe Base.
Resolved an issue with incorrect hinge selection on angled right-hand doors.
Resolved issues with Blind Corner Cabinets - Incorrect Bay Position number for Upper Right Door Using a Blind corner Hinge.
Resolved an issue with Drawer Spacers Z origin when using Wood Drawers.
Resolved an issue with Cabinet Modifications - Chamfers not cutting chamfer on sides for open cabinets.
Resolved an issue with Open Upper Cabinet missing crown moulding option.
Resolved an issue with Plants product in Accessories - not all blocks were scaling correctly in Imperial.
Resolved an issue with Work Order Summary report. Updated data & columns to reflect proper formatting for edgebanding LinFt or LinMeters.
Resolved an issue with Product Detail report and all Product Labels. Adj Shelf Values are now to count the Adj Shelf from the Parts table instead of prompts.
Microvellum Foundation Library Release Notes | Build 22.0520
The following release notes apply to Microvellum Foundation Library, Build 22.0520
Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial.
Additions
- Added lighting options to the under panel in the Upper Undermount Rangehood cabinet.
- Added Edge Bore Parameters to Hardware Array.
- Added “Top & Bottom” as a placement option for secondary lock location.
- Added the ability to individually adjust the top and bottom door heights in the Aventos HF Liftup Door system.
- Added a countertop with sink option to the ADA Single Angled Frame product
- Added a subassembly called A New Subassembly to be used when needing to build a new subassembly from scratch.
- Added sample horizontal bore Toolfiles.
- Added additional drawing blocks category for "Wood Products".
Modifications
- Upper Scribe Filler bottom return is now pointing to Filler_Material as the material.
- Renamed the default sample toolfiles to include Metric or Imperial.
Resolutions
- Resolved an issue where the Master Cabinet with 1 Drawer selected draws 2 Drawers.
- Resolved an issue where Tab-Pull Handles with Rebate would not machine past the edge of the associated part.
- Corrected the tool compensation for the Italiana Libra H1 wall hangers.
- Resolved an issue where the 2D elevation and cross-section of “Pull Knob” and Handle Hettich Alumus Knob were not scaled correctly in Imperial units.
- Resolved an issue where the Hafele Cabinet Hanger Short 3D block graphics were rotated incorrectly.
- Resolved an issue with Drawer Divisions where the rail notch machining was being offset incorrectly.
- Resolved an issue where some base points in the MV Profile Door were incorrect for bay positions 77 and 80.
- Resolved an issue that affected some hinge plates on some drop-down door conditions.
Microvellum Foundation Library Release Notes | Build 22.0407
The following release notes apply to Microvellum Foundation Library, Build 22.0407
Additions
- Added the ability to change lock type for drawers in Door-Drawer Cabinets.
- Added "Rear Cutout" option for Wood Drawer box.
- Added Pointers to the material files for the applied shelf edge.
- Added "Grain Direction" prompts to the Applied Back Panel products.
- Added K height sides to the Tandembox Antaro drawer subassembly.
- Add Secondary Locks to door subassemblies (elbow catches, etc.).
- Added Krome Linea Drawer System
- Added DTC Smooth Drawer System
- Added file options to the Wood Drawer Box
Modifications
- Changed the way the "Left Applied End" and "Applied End" prompts in the subassembly are getting turned on by the local product. Now using bay positions instead of the prompt values. This stops the issue of getting two panels when saving subassembly to project.
- The countertops that are drawn on products have been remastered; the countertop's overhangs are now calculated in the subassembly instead of the local product. In the local product the countertops now just equal the product width and depth. Also, X and Y origins are set to 0.
- All drawings related to the rod handles have been updated.
- The global "Text_Style_Options" list has been updated with text styles from the drawing templates.
- Updated Reports & Labels.
Resolutions
- Updated all Wire Curved and Straight Pulls 2D graphics file names to match the updated database names. This was preventing them from showing in 2D.
- Resolved an issue with the Profile Doors - the Perfect cornering was hard valued to metric.
- Reduced the 2D Plan dim lines in the Fillers as they were coming from the front of the cabinet. They now line up with the cabinet width dim lines.
- Resolved an issue with the machining on the Straight Blum Expando Mounting Plate. The hole diameter was 10mm and should have been 5mm.
- Resolved an issue with the MV Profile Door Subassembly where the profile would not show in 3D when all edges of the panel had a profile.
- Resolved an issue where the drawer boxes were not offsetting in the Z when using the global prompt "G!Drawer_Stretcher_Offset".
- Resolved several issues with the Suspended cabinets.
- Resolved a 3d graphics issue with the Solid Wood Door when using Arched Raised Panel.
- Resolved several issues with the 2d drawings when using tab pull handles.
Microvellum Foundation Library Release Notes | Build 22.0317
The following release notes apply to Microvellum Foundation Library, Build 22.0317
