Toolbox Release Notes | Build 22.1.0712.641
The following Release Notes apply to Toolbox Build 22.1.0712.641
Workbook Designer
Resolutions:
Resolved an issue with Part Properties updating the wrong 2D Plan Token workbook cells.
Resolved an issue with saving formula materials through Workbook Designer.
Resolved an issue when canceling out of the “M” workbook that caused library level materials to be overwritten.
Resolved an issue in the Project Wizard that prevented “Find and Replace” changes to hold.
Resolutions:
Resolved an issue with some Weeke tool files that caused the last few vectors to drop off.
Resolved an issue with some Weeke tool files that caused them to ignore the “Edge Band After Machining” setting.
Settings
Modifications:
The “Annotative Scaling” option will now default to ON when installing the software for the first time.
Modified the ‘Unit Selection’ UI in the Configuration Manager to default as unselected instead of always Imperial.
