Using Solids from 3rd Party Software with SMA (Overview)
Microvellum software contains the ability to consume 3D solids produced by other software applications, analyze them, and convert them to Microvellum products. This functionality is known as Solid Model Analyzer (SMA). The actual import function is found in the AutoCAD segment of Toolbox 2019 and AutoCAD 2019 Standard versions. Both of these versions support the import of many different types of 3D solids, among these are 3D solids produced by Autodesk Inventor, SolidWorks, SketchUp, Rhino, Autodesk 3DS Studio Max, and many others.
Once the Microvellum product has been produced, it may be processed as any product taken straight from your library.
See Using Solids from 3rd Party Software with SMA (Tutorials) in the Microvellum Knowledge Network for the procedure to use when importing solids from third-party software such as Inventor or SolidWorks.
    • Solid Model Analyzer - SMA (Overview)
      Description Solid Model Analyzer is a powerful tool included in certain product levels of Microvellum. The design and manufacturing industry is steadily moving closer to the adoption of 3D design for its verification and visualization abilities. The ...
    • Solid Model Analyzer - SMA (Tutorial)
      Description This document gives you a step-by-step tutorial on how to use the Solid Model Analyzer (SMA) to create a Microvellum product from a solid model. Before using this tutorial, you need to have a solid model in an AutoCAD DWG file. You may ...
    • Solid Model Analyzer - SMA (Reference)
      This article is a reference article explaining how to work with various types of products in the Solid Model Analyzer, also known as SMA. It also explains the commands and properties that apply to SMA. See Using Solid Model Analyzer - SMA (Overview) ...
      Solid Model Analyzer The Solid Model Analyzer allows you to select 3D solids and create a manufacturable product. It works very similarly to the save options when using the product builders. However, it does imply that you must use the product ...
    • How to import and analyze 3D solids from Autodesk Inventor using Solid Model Analyzer (SMA)
      Importing 3D Solids from Inventor® In this tutorial, you will learn how to import and analyze 3D solids from Autodesk Inventor using the Solid Model Analyzer features available in Toolbox. Create or open a Microvellum project and open a room. The ...
    • Microvellum Foundation Library Release Notes | Build 26.0527
    • Microvellum Release Notes | Build 26.1.0529.641
