What to Look for in a New Workstation for Toolbox & AutoCAD
When you need to run a program like Toolbox or AutoCAD®, there are many factors to consider when selecting your new desktop or laptop workstation. Not only are these programs robust on their own, but cabinet designers often have peripheral programs such as Solidworks®, Inventor®, Revit®, Bluebeam®, etc. running in the background. All told, these 3D Modeling programs can bog down lesser machines.
At Microvellum, our goal is to streamline all aspects of the woodworking process for our customers. We’ve demonstrated this through the Design, Estimating, Engineering, and Manufacturing modules included in our software. All of this power requires a powerful machine to manage. We’ve compiled a list of ideal specs for a machine that can handle all of your AutoCAD and Toolbox needs.
Processor
To handle 3D engineering tasks, you need a fast multi-core processor. Multi-cores make the rendering of 3D models faster and smoother. A dual-core processor does not have sufficient power to handle Toolbox or similarly heavy applications. We recommend a Quad-Core at minimum, or an 8 to 12-Core processor for higher performance.
RAM
The amount of RAM installed on your workstation impacts performance. 16GB of RAM is suitable to cover basic OS requirements and CAD work, but for complicated cabinet design, or intricate drawings, we recommend boosting your system's capability with at least 32GB of RAM. More RAM equals faster 3D model rendering and greater multitasking capacity.
Graphics
Having a dedicated graphics card helps to render files faster, with better graphics, and improves the overall performance of your workstation. For using Toolbox, you don’t need an advanced gaming graphics card, but a decent GPU should be selected for handling all of your rendering tasks. We recommend a GPU with at least 4GB of video memory.
Learn more about  Autodesk Certified Graphics Cards.
Storage
There are two kinds of storage space, SSD (Solid State Drive) and HDD (Hard Disk Drive). For our purposes, SSD is preferable. SSD provides reading and writing speeds greater than HDD. In general, an SSD boots Windows and launches Toolbox faster. NVMe (Non-Volatile Memory Express) is built for SSDs and can deliver a sustained read-write speed of 2000MB per second. Storage space comes down to your budget and needs.
Display
The display is also an important factor for working with Toolbox. We recommend a screen size of 15 inches or greater, with a 1920 x 1080 or better resolution. Depending on how much emphasis you put on the color in your design, we recommend full HD with IPS technology, which provides accurate color. This simply makes the cabinet design process that much easier and your designs that much clearer.
If you intend to connect external displays to a laptop workstation, make sure you choose a machine with an HDMI and/or Display Port connection.
Battery
If you are shopping for a laptop, the battery life should be taken into consideration if it’s common for you to be working away from a power source for hours at a time. Rendering processes are quite the power drain, so look for a battery with the highest Watt Hour Rating (Whr) you can get your hands on.
Check out our Toolbox Recommended Workstations for a list of laptop and desktop workstations with the performance and power needed to run Microvellum Toolbox.
    • Toolbox Recommended Workstations
      This article provides a list of laptop and desktop workstations with the performance and power needed to run Microvellum Toolbox and similar applications. All of these machines meet or exceed our System Requirements for Toolbox. See What to Look for ...
    • Recommended System Configuration for Microvellum Toolbox
      These system requirements include recommendations for Toolbox OEM and Toolbox AC (AutoCAD Companion) Operating System: Windows 11 Windows 10 Windows 32-bit is not supported. Processor: Minimum: 3+ GHz CPU or faster processor Memory: Minimum: 8 GB RAM ...
    • Microvellum Server System Requirements
      These are the minimum estimated system requirements to run Microvellum Server. Individual situations may vary based on your specific needs and the amount of SQL data stored. This article lists the system requirements for Microvellum Server. For SQL ...
    • What's New in Toolbox 2023 (OEM)
      Work smarter, faster with Toolbox 2023 (OEM). With an OEM Subscription, you’ll gain access to the latest toolsets and innovative features of Toolbox 2023. Improvements Floating Drawing Windows Right clicking the title bar and selecting Move to File ...
    • What's New in Toolbox 2022 (OEM)
      Work smarter, faster with Toolbox 2022 (OEM).  With an OEM Subscription, you’ll gain access to the latest toolsets and innovative features of Toolbox 2022. Toolbox 2022 (OEM) Improvements Processing and Performance Improvements Improvements to ...
    • Microvellum Foundation Library Release Notes | Build 25.0523
      Additions Added a new Master Curved Front Cabinet product. Added 282 Titus Hinges and 83 Titus Base Plates. NOTE: You will need to manually add this hardware brand into Hardware Wizard “Hinge Brand” combo box list if you are updating library. T-Type ...
    • Toolbox Release Notes | Build 25.1.0519.641
      The following release notes apply to Toolbox build 25.1.0519.641 Work Order Defaults Fix There was an issue reported with setting defaults on work orders. When one processes a work order, then modifies it afterward using the Modify Work Order ...
    • Adding a Font to Toolbox
      This article will explain the process of adding new fonts to Toolbox, both in drawing space and the Report Designer. Toolbox offers an array of fonts for users to customize their text in reports, documents, and drawings. New fonts can be added to the ...
    • Toolbox Release Notes | Build 25.1.0505.641
      The following release notes apply to Toolbox build 25.1.0505.641. Project Workbook Permissions Fix An issue was reported and resolved regarding the permissions of employee access to project factory workbooks. Users who do not have authorization to ...
    • The Microvellum Client Portal
      When logging into Microvellum’s Client Portal, several features are available to help ease the purchasing and management of Microvellum products, the ability to find accurate information in a convenient and timely manner, as well as keep track of ...
