This document catalogs all versions of the Microvellum Foundation Library released between the years of 2021-2026. The current version is documented in its own category.
To download the Foundation Library in one of the builds listed in this document, visit the
Microvellum Portal.
Year of 2026
This section lists all of the Foundation Library builds that released in the year of 2026.
Microvellum Foundation Library Release Notes | 26.0929
The following release notes apply to Microvellum Foundation Library build 26.0929
Additions
The Furnware AERO drawer system has been added to the library catalogue for the AU, NZ, and All region options. Machining and reporting have been developed for this system. This drawer system is shipped without graphics. Items added in the hardware file include:
84, 117, 164, and 199mm drawer heights.
350, 400, 450, and 500mm lengths for all drawer heights.
35kg load capacity in White finish for all heights and lengths.
Inner drawer front brackets for all drawer heights.
The Zentra Slim drawer system has been added to the library catalogue for the AU, NZ, and All region options. Machining and reporting have been developed for this system. This drawer system is shipped without graphics. Items added in the hardware file include:
84, 116, 167, and 199mm drawer heights.
270, 350, 400, 450, 500, and 550mm lengths for all drawer heights.
40kg load capacity in Matt White finish for all heights and lengths.
The Nover Krome Premium Plus drawer system has been added to the library catalogue for the AU, NZ, and All region options. Machining and reporting have been developed for this system. This drawer system is shipped without graphics. Items added in the hardware file include:
90, 128, 175, and 239mm drawer heights.
35kg option in 300 to 550mm lengths for all drawer heights.
60kg option in 450 to 650mm lengths for all drawer heights.
90mm, 128mm, and 175mm inner drawers with an aluminium front panel.
The Hettich FGV Civetta single-wall drawer system has been added for the AU/NZ region. Graphics are included. Available options include:
15kg and 25kg capacities in both White and Grey.
53, 85, 117, 150, and 200mm heights.
250, 270, 350, 400, 450, 500, and 550mm runner lengths.
The Knape & Vogt (KV) 8810 Heavy Duty Slide has been added to the library catalogue.
A new global, "G! FE Scribe Visible", has been added, providing a "Draw Only" option for extended finished ends. When the global is unchecked, the finished end will continue to be sized by the scribe value for manufacturing, but the extension will no longer display in the 3D model or 2D section. Draw-only ROUTE tokens have been added to the Finished Faces, MV Profile Door, Solid Wood Door, Face Frame Left Applied End, and Face Frame Right Applied End subassemblies, and the 2D plan tokens within the Applied Panel and Applied Panel FF have been adjusted so the 2D matches the 3D model. Parameters 2, 3, 5, 8, and 9 of the ROUTE 5 token on the left and right ends have been updated accordingly. The global and its help image have been included in the Update file.
Layer control for dimensions on toe kicks and countertops has been added through four new globals:
"G! Elevation Dimension Layer Kick"
"G! Elevation Dimension Layer Countertop"
"G! Plan Dimension Layer Kick"
"G! Plan Dimension Layer Countertop"
Control over the 2D plan door opening angle has been added by product type, allowing the plan door swing to differ between base, tall, and upper cabinets without editing each door. Three new globals have been added:
"G! Door Opening Angle Base"
"G! Door Opening Angle Tall"
"G! Door Opening Angle Upper"
Cabinet modifications can now be represented in 2D plan and elevation views. Drawing tokens have been added to each modification subassembly to outline the selected modification, controlled by two new globals:
Dedicated material pointers have been added for the Wood Dovetail Drawer Box subassembly, allowing standard and dovetail drawer boxes to be used within a single project without a second specification group. The new pointers include:
"M! Drawer Box Dovetail Bottom"
"M! Drawer Box Dovetail Front Back"
"M! Drawer Box Dovetail Sides"
"M! Drawer Box Dovetail Bottom Wide Span"
The new pointers default to Baltic Birch Ply and have been kept consistent with the existing Drawer Box Wood pointers, so current setups will not be disrupted. Prompt values within the subassembly are trapped with IFERROR. The new pointers have been added to all 5 CutParts files and to the .ctpx update file.
Modifications
The machine points on cabinet parts have been modified so renderings display correctly with 1-sided material. Affected parts include:
Adjustable and fixed shelves.
Adjustable and fixed shelf edges.
Doors.
The right side of the Diagonal Angle and Open Diagonal Angle products (Frameless and FF).
The Hinge BLUM 125deg Half Overlay Knock In has been removed from the hardware library, as it no longer appears in Blum E-Services or the latest Blum product range.
The XML project-import sample has been updated to align with Foundation Library product names. The previous Component Library XML samples are being removed from the knowledge base.
Default render material assignments have been revised for a more presentable out-of-box appearance. Finished and open part pointers now default to a grained material, and the PL1 Grain render material has been set to Milkwood in both Imperial and Metric (2-sided and 1-sided). The Kick Face render material has been set to 2-Side in the default cut part files and Liner_PL1 in the sided files. PL1 Solid remains Dark Grey.
The Hettich hinge mounting plate category and plates have been renamed from Intamat to Intermat to match Hettich nomenclature, and the DWG graphics have been corrected. This change is only available in a new install.
The following material pointers have been changed to White Melamine 0.75in 2S across all spec groups in the Cutparts Default, Cutparts Default Sided, and FDM Imperial/Metric files:
"M! Base Open Top"
"M! Base Open Stretcher"
"M! Base Stretcher"
Resolutions
An issue within the 1-Door Frameless Base/Tall/Upper products that affected hinges and duplicated door parts when using "Right Swing" with a glass door, or "Pullout" as the component option, has been resolved. The Right Door subassembly has been updated accordingly.
Resolved an issue within base cabinets where the Finished End dimension did not respond to "G! Finished End Dimension From Side". New prompts, "Left/Right End Dimension Elv From Side" and "Left/Right End Dimension Plan From Side", have been added to the 2D Instruction and 2D Instruction Corner subassemblies for the drawing tokens to reference.
Resolved a grouping issue within the Point-to-Point nesting report. A Group Header on Parts. Filename has been added to the Parts Select P2P report so that parts sharing a name, but differing in file name and machining operations, are separated.
Resolved an issue with the LED strip light within the Under Panel Corner subassembly. The strip light location and drop light positions have been corrected.
An issue with the Inner Drawer with Faces calculator displaying an incorrect value has been resolved. The correct drawer front heights should now be displayed.
Resolved a divide-by-zero error within the Component Drawer and Component Drawer FF subassemblies that occurred when the drawer quantity was set to 1 with "G! Default Top Drawer Front Height Drawer Bank" enabled.
Resolved an issue that prevented hardware pricing from populating for the Finista Edge drawer kits. The inner drawer kit hardware has been renamed to match the other Finista systems (Inner Drawer Kit Low / High / Super High).
Resolved an issue with lock behavior on Sink with False Front / Top Facia products. When both "Add Top Facia" and "Add Lock" are enabled, the "Drawer Stretcher Facia" prompt is now available, providing a part to mount the strike plate to when using the "Lock To Top" global. This option is not available in a Horizontal Designer multi-bay scenario.
An issue affecting the 2D elevation placement of the right-most division, when "Face Frame Division Overlay Control" is set to "Double", has been resolved. The DRAWRECTANGLE token within the Division FF subassembly has been updated.
Resolved an issue within the Divisions with Fixed Shelves subassembly that caused construction hole machining to be removed from the wrong side of the division.
The Blum MERIVOBOX Slide 400mm Right graphic has been corrected in the Core Data and Update files.
Several issues have been resolved across the Nover Krome, Nover Krome Linea, and Nover Krome Premium drawer systems, including:
A gap between the drawer back and bottom when using backs thicker than 17mm.
Drawer back length and inset values within Nover Krome Linea not matching the Nover specification.
An incorrect length limit on the 35kg slide for Nover Krome Premium.
Gallery Rail and Inner Front molding graphics not scaling correctly for Imperial on Nover Krome Linea and Nover Krome Premium.
Resolved an issue where Quarter cabinets were missing sides. The "Valance Height Top" and "Valance Height Bottom" variables have been removed from the "Left/Right Side Full Height" prompt formulas.
Resolved an issue on 2-Door products where a secondary lock appeared off-product when "Add Top Facia" and "Add Lock" were enabled. The "Use Secondary Lock" prompt within the Finished Faces, MV Profile Door, and Solid Wood Door subassemblies has been updated.
Microvellum Foundation Library Release Notes | 26.0812
The following release notes apply to Microvellum Foundation Library build 26.0812
Additions
Added new global variable “Post Laminate Faces”. Previously, when using Post Laminate on Finished cabinet parts (but not doors), users had to change the Finished Faces subassembly or its prompts each time to prevent doors from using post laminate. This new variable solves that issue.
Resolved issue when “Valance Height Bottom” value was greater than 0. Previously, the cabinet bottom and sides were not adjusting when Valance Height Bottom >0.
Updated formula: =IF(AND(Add_Under_panel=1,Under_Panel_Include_In_Height=1,Valance_Height_Bottom>0),Valance_Height_Bottom,IF(AND(Add_Under_panel=1,Under_Panel_Include_In_Height=1),Under_Panel_Edge_Width,Valance_Height_Bottom))
Resolved an issue with the continuous holes setting not passing through to the shelf when it was a nested subassembly. Continuous Holes value were specifically not passing through to Nested Shelf Adj.
Resolved an issue with Toe Kick Assembly Box parts showing machining from carcase parts. This issue appeared when processing, as parts would be blocked from flipping during optimization, which created a secondary operation. A hidden prompt has been added to the Toe Kick Assembly Box, “Height Offset”.
Resolved issue with Drawer Division protruding below drawer fronts. Division(s) in 2 Drawer Suspended Cabinet were incorrectly sized when “No Bottom” is selected. The Division(s) protrude below product by “Dado Depth” value.
Resolved an issue with missing notch on Drawer Divisions when Shadow Line Finger Pull is selected. The PLINE virtual route had an incorrect formula format, which resulted in route not being activated. The formula is now fixed, which should eliminate manual machining process for shadow line rail notch.
Resolved an issue with the “Door Gap” prompt not having a visible control type in all corner cabinets. The control type for the “Door Gap” prompt has been changed in the Base/Master/Tall/Upper Corner Cabinet FF products.
Resolved an issue with occurring in the Wood Drawer Box when construction method was set to Hardware Array. When using the Cabinet Notch Center cabinet modification with Hardware Array as the construction method, the logic for the left and right Drawer Backs would mismatch. The formula for EDGEARRAY3 and 4 have been changed to prevent this issue.
Resolved a hardware reporting issue with the Bracket Single and Bracket Array products. Bracket Qty was reporting brackets twice, once in the product and once in the subassembly. Product level hardware has been removed from both, resolving the issue.
Microvellum Foundation Library Release Notes | 26.0729
The following release notes apply to Microvellum Foundation Library build 26.0729
Additions
Added Under Panel subassembly option for upper cabinets. This was to resolve an issue with the Under Panel product, which required manual insertion and adjustment each time.
“Add Under Panel” checkbox has been added to cabinet products.
Added Under Panel subassembly to cabinet products.
Added Under Panel Corner subassembly to corner cabinet products.
Enhanced the Under Panel subassembly to have many features:
Added New global “Under Panel Subassembly Name” so users can customize their own Under Panel subassemblies and protect them from update overwrite.
Added the ability to control 2D elevation cabinet height dimensions from a filler instead of a finished end. Previously, this only was able to be controlled with finished or applied ends.
Added the “G!Filler End Dimension” variable. The "Left/Right End Dimension Elv" will check this global, and if there is a "Left/Right Filler Width" > 0, it adjusts the actual dim line to start at the filler width value, -left and +right.
New global variable, “Filler End Dimension”, added.
Updated the "Left/Right End Dimension Elv" prompts in all products via Library Designer.
Updated the 2D Instructions and 2D Instruction Corner subassemblies to adjust the X locations of the DRAWDIM tokes for height dimensions to account for filler widths.
Created new help images for Filler End Dimension & Finished End Dimensions.
Added the Face Frame Separate Bead subassembly as a nested subassembly to the Left and Right Face Frame Applied End so they match the Face Frame subassembly.
Resolved a hinge issue within Horizontal Designer Face Frame cabinets, wherein concealed hinges and hinge plates did not align on divisions when Intermediate Stile was turned off.
Added "Prompt Value to Faces" subassemblies at product level. This affected the Master 2 Bay Horizontal Cabinet FF & Master Horizontal Designer Cabinet FF.
Adjusted calculator formula to account for “Add Intermediate Stile” prompt. Only subtract its width in the calculation when it is on.
Component Doors FF subassembly:
Added 2 new prompts
"Hinge Offset Left"
=IF(IS_Face_Frame=1,IFERROR(IF(AND(L!Add_Intermediate_Stile_1=0,L!Face_Frame_Division_Overlay_Control_Stile_1=“Double”),IF(AND(Left_Door=1,IS_Division_Left=1),Thickness_Division/2,0),0),0),0)
"Hinge Offset Right"
=IF(IS_Face_Frame=1,IFERROR(IF(AND(L!Add_Intermediate_Stile_1=0,L!Face_Frame_Division_Overlay_Control_Stile_1=“Double”),IF(AND(Right_Door=1,IS_Division_Right=1),Thickness_Division/2,0),0),0),0)
Changed formula for Hinge Dist from Side:
Resolved an issue with Master Horizontal FF Products miscalculating when Intermediate Stiles are off. Adjusted the prompt value pass through to populate the appropriate prompt if a bay face option is “Two Door” or “Left/Right Swing” on side of bay with no Intermediate stile.
Resolved a graining issue with Solid Wood Door’s flat panel parts, wherein Solid Wood Door's flat panel parts were not nesting correctly with Perfect Grain selected.
A missing variable in the subassembly was found, Full Width Drawer, and broke the Perfect Grain Identifier formula. This variable has been added to both the Solid Wood Door and the MV Profile Door to be consistent with the Finished Faces and does not break the Perfect Grain Identifier value.
Resolved an issue with Component Doors FF subassembly not always calculating Door Width correctly. The Door Width prompt in the Component Doors FF and Component Door Drawer FF subassemblies was not accounting for the Intermediate Stile correctly when Full Inset Doors were selected. There was also a typo in the formula looking for “Two_Doors” instead of “Two Doors”. Changed the hidden "Door Width" prompt value.
Resolved an issue in Component Doors and Component Doors FF subassemblies. Blank hardware names were appearing with a qty when selecting “Top Hinge Only” for Door Stay.
Resolved an issue with Face Frame product 2D elevation width dimension incorrect when Right End Condition is set to Applied End.
Resolved an issue with the Internal Drawer With Faces subassembly, wherein the filler does not move and stays aligned with the inner drawer front. Internal Drawer Front Material and Internal Drawer Front Edge do not match.
For filler issue, changed the Y origin of the Finished Face nested subassemblies for the Fillers in the Internal Drawer With Faces. Added IF (Filler_Flush_With_Carcase =1, Thickness_Door+Door_To_Cabinet_Gap,0)
NOTE: Be sure to point an appropriate material to these new pointers after running a library update.
Added 2 new prompts in Internal Drawers With Faces subassembly, "Drawer Front Material" (changed value to incorporate new pointers) and "Drawer Front Edge" (changed value to incorporate new pointers). Changed column 13 of Lookup Table Bay Positions, bays 60-66, of the Finished Faces subassembly.
Resolved an issue with Inset Toe Kick in open cabinets, which would occur when placing an Open cabinet next to a cabinet with doors AND the “G!Cabinet Depth Include Doors” is off, the toe kick insets for the cabinets do not align. The Open Cabinet Toe Kick Inset is pushed back by Door Thickness + Door to Cabinet Gap.
Resolved an issue with no bottom cabinets and attached toe kicks. When selecting "No Bottom" in a product, the sides did not extend to floor and notch.
The issue was resolved by adjusting the formula for "Toe Kick Height", removing the reference to "No Bottom". Adjusted formula for "Toe Kick Assembly" to reference "No Bottom". Adjusted Use Front Toe Kick to turn off if "No Bottom" is selected. Added New prompt, "Use Attached Toe Kick", when "No Bottom" is selected. Adjusted the "Use Attached Toe Kick" prompt in the Notched Toe Kick subassembly to look for the "L! Use Attached Toe Kick".
Resolved issue with Hawa Concept III having the wrong prompt reference for "Part Lengths".
Resolved issue when using dowel construction for Wood Drawer boxes. The dowel fitting reported was the incorrect dowel. This was only noticeable if the drawer dowel is different than cabinet dowel.
Resolved machining issue with ADA Sink Angled Frame product.
Resolved issue with Solid Wood Door and the Reduced Rail feature. Will now work in Top Fascia (False Front) conditions.
Made many improvements to the Blum REVEGO Pocket Doors product which should provide a much closer output to Blum’s E-Services site.
Deleted several Redundant Handle Rod 2D Drawing files.
The following release notes apply to the Microvellum Foundation Library build 26.0630.
Additions
Added new Fixture product Die Wall Advanced. This product takes the legacy Die Wall products to a new level. More features and advanced parametric abilities:
Up to five individual unique subassembly segments, widths controlled via calculator.
Initial segment options include "Straight", "Bowed Front", & "Curved". Users can develop additional custom segments by developing additional subassemblies and updating the combo box list, allowing for endless customization options.
Left/Right Return options include None, Straight Segment, & Radius Segment. More can be developed and added by developing additional subassemblies and updating the combo box list.
Taper Options by Angle or Amount.
Removable inside panel option.
Countertop Recess options including notched studs.
Various cleating & plate options.
Wire chase holes, cutouts, & full center cutout.
Standard Foundation Library construction methods supported.
Drill or route relief options for the stud notches.
End Condition options for each segment (None, Finished, Applied, End Cap).
Added close to 200 new global variable help images. Reviewed many of the global variables that were missing help images and rendered new ones to help clarify what each variable is for.
Currently at this time the Library Update Utility cannot append the name of the new JPG file to your existing global variables. Because of this, the images will not appear in the Global UI until you enter the name of the JPG help image. Current work-a-round for this is to install the full library and copy/paste column “U” in the global workbook into your working library.
Added Halliday Fusion Drawer System.
Added Material Sheet quantity to Formula Driven Materials. This includes 4 new Wizard prompts:
"Material 1 Sheet Qty 1".
"Material 1 Sheet Qty 2".
"Material 2 Sheet Qty 1".
"Material 2 Sheet Qty 2".
Added 2 new columns to the LookUpTableFDM:
Resolved an inconsistency issue with global variable Default Top Drawer Front Height. Users can now apply "G!Default Top Drawer Front Height" to Drawer Bank products, not just Door/Drawer products.
Added new variable, Default Top Drawer Front Height Drawer Bank, to project wizard and global variables.
Updated all Drawer Bank products with the exception of 1 Drawer, FF and Frameless, and Waste Bin drawer products.
Updated the Component Drawers and Component Drawers FF subassemblies.
If you are updating your library with the Library Update utility, the old products will not be deleted, moved, or renamed. You will need to manually do this, otherwise you will have two of the same products with different names.
Resolved drilling issue with the Kessebohmer LeMans II. M Profile (Side mounted bracket) was drawn at 600mm but had machining matching the 500mm. Users can now use the 600mm bracket with none of the machining aligned.
Added a toggle for the M Profile selection, 500mm or 600mm in the Le Mans II subassembly. Separated the M Profile from the blocks of all graphics except the High board. Added 4 new Cut Parts and graphic files, M Profile 500mm Left and Right, M Profile 600mm Left and Right. Updated machining to reference M Profile selection (columns 22 & 27, rows 6-9 in Lookuptable). Updated the high board graphics and machining to correctly match the specs (columns 22 & 27, rows 10-13 in Lookuptable).
Resolved issue with Tall Split Corner Pantry cabinet when "Thick Back" is selected and the "Cabinet Split Qty" is set to 2. The Middle back now changes to qty 0 so there are not unneeded parts cut.
Resolved issue with Wood Drawer Box right back when "Rear Cutout" was selected. The "Right Drawer Back" now machines and reacts the same as the "Left Drawer Back".
ADA Sink Angled Frame: Added "ElvNoDim" and "ElvNoOutline" hidden prompts to supress the 2D elev dimension and product outline.
Resolved issue in Horizontal Opening Splitter FF subassembly that inadvertently added perfect grain data, which caused issues in the nesting of parts.
Resolved inconsistent Notched "Toe Kick Height" in Face Frame products. All Face Frame products now consistently reference the "G!Face Frame Toe Kick Difference Extended" variable. Toe Kick parts for FF products will now be consistent sizes.
Resolved issue with Division with Adjustable Shelves and Division with Fixed Shelves subassemblies where the Division text in Uppers was being placed above the product. Changed parameter 2 of the DRAWTEXT to be consistent with the Divisions subassembly at UCN(2.5, 75).
Resolved issue with the Drawer Bottom machining for the Blum METABOX drawer system
Resolved issue with Blum MERIVOBOX. Changing material thicknesses were causing incorrect bottom part cut sizes.
Resolved issues with incorrect lock locations when used with Upper Cabinet Valance and Lock to Bottom options.
Resolved 2D elevation issue when using scribe fillers and "Filler to Floor" option.
Resolved an issue with routing hinge cup holes on 3 Door Products. The Router hinge cup machining was being applied to the Division instead of the door. Divsion Part Names have now been added to the "G!Name Filter Hinges".
Resolved an issue with "Secondary Locks" when using a Center Fixed Shelf. When using a lock on a double door product with shelf below (like a tall 2 double door), the Z origin of the catch wasn't accounting for a shelf instead of a bottom. The Z origin now references "Door Bottom Edge to Bottom Panel" instead of from "Thickness Bottom - Bottom Reveal".
Microvellum Foundation Library Release Notes | Build 26.0527
The following release notes apply to the Microvellum Foundation Library build 26.0527.
Additions
Added the “L! Use Wide Span Shelf” to the Material Options tab in standard products. This is a multi-purpose addition, giving a user more control over shelf materials at product level and resolving an issue with Wide Span Shelf material being assigned to bays that do not meet the requirements for the Wide Span setting.
Added Appliance Options to all countertop products in both the Countertops and Extruded Countertops categories for better consistency between similar products. The one exception is the curved extruded countertop.
Added a new Product Prompt to most standard products, “Use Wide Span Shelf”. Users now have better control over the shelf material thickness at the product level for all shelves in the product. For differences in shelf material within a single product, the material would be changed at the subassembly level.
Added render material assignments to all sheet stock, solid stock, buyout, and edge band materials. * See the following article for more information.
Resolved an issue with Blum REVEGO Pocket Doors product where the Door Stabilizer machining wasn't working when using Uno Right as the Product Selection.
Resolved an issue with Master Curved Front Cabinet Finished Face quantity calculation.
Resolved an issue with Divisions, Division with Adj Shelves, and Division with Fixed Shelves when Through Dado Bottom was selected where the dado lead in and out were not calculating correctly and leaving a large gap.
Updated the DRAWDIM tokens for Cross Sections so all vertical dimensions align. Subassemblies updated:
Resolved issues in the Shelf Adj and Shelf Adj Glass wherein shelf pin drilling was not showing when Cabinet Modifications Notch Left/Right/Both Sides was selected and Back and Side Thicknesses were different.
Updated the Flatshot Instructions subassembly so that “Front Elevation” text location is consistent in all product types.
Resolved an issue with the Shelf Adj and Shelf Fixed where the PLINE tokens for Cabinet Modifications were not working due to Name Filter not including the “Bay Position” in the name.
Resolved an issue with Horizontal Splitter where the PLINE token for “Cabinet Notch Top/Bottom” was not working due to incorrect X and Z vector locations.
Resolved an issue with Adj/Fixed Shelf Material incorrectly looking to Wide Span pointers when Internal Insert was changed to Divisions With Adj/Fixed Shelves.
Resolved an issue with “G!<Product Type> No Bottom” variables not being changeable due to the control type. There is now an option to change all three product types at a global level.*
Resolved an issue with the misspelled global variable, “Defalt Inner Wood Drawer Slide”. This has been corrected to “Default Inner Wood Drawer Slide”. *Update Note: After running update, confirm your selection. The value formula did not change nor did the H! variable.
Resolved an issue with Shadow Rail selection not applying the correct Shadow Rail subassembly name when there were more than one Shadow Rail in a product. All Shadow Rail subassemblies in a product will not look to the same “G!Shadow Rail Name” variable. This issue was also resolved in the Component Drawers and Component Door Drawer subassemblies.
Items marked with * are not included in Library Update, only in the full install.
Microvellum Foundation Library Release Notes | Build 26.0430
The following release notes apply to the Microvellum Foundation Library, build 26.0430.
Additions
Added new options to Add Interior Label for cross section, plan section, and elevation section. New Global Variables include:
- “Add Interior Label Cross Sect”
- “Add Interior Label Plan Sect”
- “Add Interior Label Elevation Sect”
- “Finish Label Options Interior” (Select from Material Comments or new Wizard Variable.)
- “Finish Label Interior From Top”
- “Finish Label Interior From Back”
New Project Wizard Variables include (Located on new Interior Finish Labels tab):
- “Interior Finish Label Base”
- “Interior Finish Label Tall”
- “Interior Finish Label Upper”
Updated 2D Instructions, 2D Instructions Corner, and Angled Ends 2D Instructions subassemblies with new prompts:
- “Finish Label Interior”
Updated the 2D Instructions, 2D Instructions Corner, and Angled Ends 2D Instructions subassemblies with new tabs, including:
- Plan View
- Elevation View
- Section View
- Added the option to control interior hinge overlays in the Component Doors FF using 2 new prompts, “Door Overlay Hinge Left” and “Door Overlay Hinge Right”, only visible when Face Options is set to "Two Doors".
- Added new Edgeband categories, including PVC, ABS, and Misc to better organize the edgebanding materials.
- Added a new global variable “Upper Top Nailer Width”. This has been linked to a new local variable present in Upper cabinets to allow the top Nailer width to be different than the other Nailers.
- Added a new table to the Hardware (H) workbook, “LookUpTableShelfClip”. This can be used to manage all shelf support clips. When changing between the different clips, will automatically set the correct gaps and drillings. Includes columns for regular shelf clips and fixing shelf support for drill and slot installation in addition to Shelf Standard
Added additional shelf supports to the Hardware library:
- Futaba Shelf Support
- Richelieu Metal Shelf Support
- Hafele Fixing Plug Shelf Support
- KV 256
- Added the Diagnostic Machine Token Test Product to the Miscellaneous This product is useful for testing Microvellum machine/drawing tokens.
- Resolved an issue with Overlay Bottom receiving machining when Bottom Return on filler is selected.
- Resolved an issue with Angled Ends Toe Kick Assembly Box not aligning with the cabinet sides of the Master Angled Ends Cabinet product when Toe Kick Assembly is changed to Toe Kick Assembly Box.
- Moved the “Pelmet Stretch” and “Pelmet Width” prompts to the Legacy tab in Globals.
- Updated the Cost Based Estimating Report - Shop Quote Optimized Option report to show correct Material Name in the Optimized Sheet Stock Cost category when multiple sheet sizes for the same material are being used.
Updated the Hawa Concepta III:
- Corrected the “T1 Left/Right” references in the lengths of parts to look to the correct variable.
- Added warning message to show when “T1 Left/Right” – “Left/Right Door Protrusion” > depth of the subassembly.
- Resolved an issue with Drawer Front sizes and location when there are 2 Top Drawers and the Horizontal Gap was changed. Drawer Fronts now size and locate correctly.
Resolved issues with the Tall Fridge Cabinet FF:
- Resolved an issue with Applied Panel FF where the “Right Applied End” prompt was always on and set to a static 1.
- Removed the reference to “Finished Ends” and “Applied Ends” from the length of the left and right sides and added that logic to the “Extend Left/Right Side to Floor”. This automatically resolved the issue with the notch on the side when not extended to floor.
- Added “Extend Left/Right Applied End to Floor” prompts to the Construction Options. The default is now looking to the “G!Applied Ends To Floor”.
- Applied Panel FF - Added “Applied Ends to Floor”.
- Added Prompt Value to Applied Panel FF subassemblies to pass through to “Applied Ends to Floor” when "Extend Left/Right Applied End to Floor" is selected. The value looks to “G!Applied Ends To Floor” by default.
- The formula for "Face Frame Right Side Overlay Control" was incorrectly referencing Left Finished End, which was also affecting many other face frame products. This has been corrected.
Resolved issues with the Tall Fridge Cabinet:
- Adjusted width of the Fridge subassembly when “Left/Right Side Full Height” is selected to avoid overlap of part and fridge block.
- Added the Toe Kick options for cabinet side. Limited to “None” and “Notched Toe Kick”.
- Added the same toe kick controls that are consistent with other products.
Resolved an issue with Master Double Sided Cabinet where parts were not drawing or located properly.
- Updated the “Vertical Profile Left/Right Side” to reference Front Bay Face Options instead of Face Options, which doesn't exist in the product.
- Changed the Rear X Origin formula to include the “Applied End Thickness Left” variable when vertical shadow line options are selected.
- Updated the left and right sides “Width” and Y Origin to properly size and locate when vertical shadow line options are selected.
- Updated the Rear Shadow Rail subassembly to match the Shadow Rail subassembly with the “Vertical Rails X” location adjusted to be properly located.
- Resolved an issue with the DTC Smooth drawer system where the Rear Fixing bracket was not located properly. Updated the drawing names for the High Pot Rear and Interior Fixing Brackets.
- Resolved an issue with Division FF occurring when using dado attachment method.
- Resolved an issue with Extruded Diewalls when using multiple Inside Skin qty with a gap between. Inside Skins now work as Outside Skins.
Resolved an issue with shelf material when using Divisions With Adj Shelves and Divisions With Fixed Shelves where the material prompts were still looking to the Wide Span pointers.
- Added new local prompt “Use Wide Span Shelf”.
Microvellum Foundation Library Release Notes | Build 26.0327
The following release notes apply to Microvellum Foundation Library build 26.0327.
Additions
- Added new Formula Driven Materials (FDM) and accompanying special FDM project wizard. *
- New Specification Group “Wizard Formula Driven Materials [FDM]”.
- New Specification Group components:
- Project Wizard FDM
- Formula Cutparts Default
- Formula Edgeband Default
- New Wizard FDM Materials added for each category (Sheet Stock, Solid Stock, Buy out, Edge Band).
- Library Update Utility will not include this new feature as it cannot add specification group components to a user’s library. If you are an existing Foundation Library user, and want to explore FDM, we recommend installing the full install, exporting/importing a new project and all the new FDM material categories.
- Added Accuride CB1234 hardware to the hardware library. This hardware can now receive cost information.
- Added Blum MERIVOBOX F Height drawer systems to hardware library. This hardware can now receive cost information.
- Added Master Cabinet w Carcase product. This product can morph into any standard product (Base, Tall, Upper) and uses a Carcase subassembly instead of product parts.
- Added “G!Cabinet Carcase Subassembly Name”. This will allow users the ability to create their own Carcase subassembly and have it as the default in the new Master Cabinet w Carcase. product.
- Added new global variables and hardware wizard prompts to control screw diameter for backs.
- “H!Screw Fitting Backs”
- “G!Screw Diameter for Panel Face Backs”
- “G!Screw Depth for Panel Edge Backs”
- “G!Screw Diameter for Panel Edge Backs”
- Added global variables “G!Elevation Show Division Label” and “G!Section Show Division Label” for control of Division Text in elevation and section. Updated the elevation and section DRAWTEXT drawing tokens in the following subassemblies:
- Horizontal Splitter
- Divisions
- Division with Adj Shelves
- Division with Fixed Shelves
- Added “G!Finished End Text From Side Plan” to separate control from elevation “FE Text”.
- Added “FE Text From Side Left Plan” and “FE Text From Side Right Plan” to all products that currently have “FE Text From Side Left/Right”.
- Updated 2D Instructions and 2D Instructions Corner subassemblies.
- Added “FE Text from Side Left Plan” and “FE Text From Side Right Plan”.
- Updated existing drawing tokens to reference new prompts.
- Updated Plan token to be centered on depth instead of in front of cabinet.
- Added Text Layer for the FE text tokens so they are consistent with other annotation layers.
- Added global controls for top and bottom reveals with a new variable, “G!Section Dimension Reveals”. Updated 2D Instructions and 2D Instructions Corner subassemblies.
- Added “G!Section Dimension Reveals”.
- Added “G!Section Dimension Reveals Offset”.
- Added “Reveal Dimension” prompt to subassemblies.
- Added “Reveal Dimension Offset” prompt to subassemblies.
- Added DRAWDIM tokens for top and bottom reveals to the 2D Instructions Corner.
- Updated parameter 5 of dimension tokens to look to the new offset prompt.
- Added controls for Rear Notch when using Notched Toe Kick and “Use Rear Toe Kick” is on.
- Updated Notched Toe Kick and Notched Toe Kick Corner subassemblies to include rear notch options.
- Added rear option prompts with defaults following front options:
- “Notched Toe Kick Position Rear”
- “Toe Kick Notch Relief Left Rear”
- “Toe Kick Notch Relief Right Rear”
- “Amount to Extend Left Toe Kick Rear”
- “Amount to Extend Right Toe Kick Rear”
- Added 4 Virtual Routes:
- Left with Relief
- Left without Relief
- Right with Relief
- Right without Relief
- Added product prompts to control Overlay Top and Overlay Bottom extension amounts.
- Added Overlay Top Extend Left, Right, and Back.
- Added Overlay Bottom Extend Left, Right, and Back.
- Added “G! Overly Top Bottom Extend Scribe Filler Width” which will automatically extend “Overlay Tops” and “Bottom” the same as “Left” or “Right Filler Width”.
- Added global variable “Front Fixing Bracket Screw Hole Dia” to control the “Front Fixing Bracket Hole Dia” prompt in drawer systems.
- Added global variable “Section Text Layer” that was missed in a previous library update. (This will overwrite an existing value if you have updated it.)
- Resolved issues Blum MERIVOBOX Drawer System.
- Silk White drawer system. Removed the additional space at the end of the name so it now matches subassembly naming convention.
- Bottom length was incorrect when using Rear Cutout.
- Updated the help image for “G!Front Shelf Hole to Edge”. This now matches the help text and actual location of the front shelf holes from shelf edge.
- Resolved an issue with no dado being available for the bottom of the Wood Drawer Box subassembly when "Miterfold" is selected as the construction method.
- Resolved an issue with Hettich Inno Tech Atira subassembly occurring when the Quadro V6+ runner type is selected. The front holes from side bottom now shift up 5mm when this slide is selected.
- Resolved an issue with Applied Back Panel subassembly not receiving the edge selections from the parent product.
- Resolved an issue with Toe Kick Assembly Box subassembly where the Finished Back and Sides were not sized and located correctly when "Inset Back" >0.
- Resolved an issue with Solid Wood Door subassembly not drawing correctly in 2D elevation. The stiles and rails were looking to the D workbook instead of the parent product.
- Resolved issues with Blind Cabinets wherein the Blind Panel was not sizing correctly when “Use Blind Corner Hinge” was selected.
- Updated the Wood Drawer Box subassembly EdgeArray token locations to account for small part threshold set for "Hardware Array" construction method.
- Resolved an issue with all Corner and Diagonal products occurring when “Full Top” and “Full Captured” back was selected.
- Updated the “Hanger Notch Left/Right” prompts to turn off when Thick Back is selected or when "Full Applied" is set for back construction.
- Resolved an issue with King Slide SIMLEAD drawer system where the back and bottom were sized incorrectly.
- Resolved multiple issues with the Extruded Bench:
- “Left” and “Right Stud” locations on curve.
- Added logic in the “Elbow Widths” based on angle.
- Added the “Rail Gap” prompt to eliminate tight fit at rail notches.
- Resolved issues with Hinge Plates for Right Doors on Angled and Diagonal Cabinets.
- Resolved an issue with Doors not drawing in elevation for Master Diagonal Vertical Designer Cabinet.
- Resolved an issue with Applied Ends not drawing in elevation.
- Resolved an issue with MV Profile Door subassembly where when used as Left Applied End and Panel Insert is selected the panel was shifted to an incorrect location.
- Resolved an issue with Miterfold Wood Drawer Box where the route for the miter cut was not passing to the machine code.
- Resolved an issue with Face Frame products that would appear when “G!Face Frame Miter FE Joint” is on and “G!Face Frame Attachment Method” is set to “Dado”.
- Resolved an issue with Pocket Door products where the Division Material was not adjustable in the Product Prompts.
- Resolved an issue with Upper Microwave Cabinet top bay door not adjusting with the Face Reveal settings.
- Added a prompt value for the Component Doors subassembly that will change the "Bottom Bay Open" value to 1 and follow the product "Bottom Reveal" value.
- Resolved an issue with the Vertical Splitter occurring when using Cabinet Modification Notches.
- Resolved an issue in Master Horizontal Designer Cabinet FF where Bay Qty=1 and Bay 1 Face Options = "Two Doors" did not change the doors.
- Resolved issues with Extruded Base Cabinet which included shelf location and machining.
- Updated the CAD DWT files with suggested settings.
- FACETRES = 5
- VIEWRES = 15000
- ANTIALIASSCREEN = 5
- Purged old rendering materials.
- Reviewed and updated “Drawer Slide Clearance” values in the F workbook.
- Modified LookUpTableSystemDrawerSlide, adding additional “slop” to prevent drawers from being too tight.
- Resolved issues with Vertical Opening Splitter Component subassembly:
- Splitter 9 was incorrectly located.
- Updated Bay Qty to calculate with the "G!Max Shelf Spacing".
- Updated “G!Full Bottom Upper” and “G!Overlay Bottom Upper” to look the Wizard values. Changed the Control Types for all “G! Overlay” variables to be visible and not dimmed.
- Resolved issue with Toe Kick Base With Angled Ends product where parts were not located and sized correctly when Finished Ends and Back were turned on.
- Resolved the issue of Handles not being centered in X when "Double Drawer Handles" is selected.
- Resolved issue with a few subassemblies not inserting correctly when using Pick Corners. This was due to a 180 value in the subassembly Z rotation.
Microvellum Foundation Library Release Notes | Build 26.0220
The following release notes apply to the Microvellum Foundation Library build 26.0220.
Additions
- Added DTC Magic Pro and Magic Star Ultra drawer systems.
- Magic Pro
- Items added in hardware file
- 300 and 600 lengths for all drawer heights.
- Add 60kg option for all lengths and heights
- Black Matte for all heights and lengths.
- Reorganized folders. Separated by color for consistency in HW file.
- 3D Drawings added
- DTC Magic Pro Side C/F/K/M Height 300mm Left/Right
- DTC Magic Pro Side C/F/K/M Height 600mm Left/Right
- DTC Magic Pro Slide 300mm Left/Right
- DTC Magic Pro Slide 600mm Left/Right
- DTC Magic Pro subassembly
- Populated the Runner Hole Position 2 table for the 60kg option.
- Added the 300 and 600 to the Runner Hole Position 1/2 tables.
- Magic Star Ultra
- Added all available heights and lengths, sorted by color (black matte, grey matte, silk white), to hardware file.
- Created all drawings for sides and slides for all heights and lengths.
- Added option to miter the back edge of the Shoe Shelf.
- Added new global variables for more control of FE Scribe Route. "Added FE Scribe Tool" and "FE Scribe Route Offset" allowing user to control both Tool and Tool Compensation at a higher level.
- Added the new global variable "Finished End Dimension Plan" to break out a plan option vs the elevation option. Applied End options will now also trigger the "Finished End 2D" dimension features.
- Resolved issue with “Division Quantity” prompt not showing when using component inserts that contain divisions are selected. Added Top Division Qty to all relevant products, Frameless and Face Frame.
- Resolved issue with all drawer systems when using Wood Spacers.
- Modified the LeMans II Min Door Opening Width to match the specifications.
- Updated the Harn Alunan T 270mm Right drawing to correctly represent in model.
- Updated the "Bottom Hardware Array" token in the Pigeon Holes and Divisions subassemblies. The array now spans the full width of the part.
- Resolved issue with the Shoe Shelf subassembly. The hardware array is now on the correct edge and the 2D elevation is annotated correctly with ADJ or FIXED.
- Resolved an issue with Grass ZBox back machining.
- Resolved an issue with Grain Direction Indicator not showing up on Buyout doors.
- Resolved issues with Fixed Shelves and Dividers subassembly drawing incorrectly in 2D elevation.
- Resolved an issue in Blind Cabinets when Right Blind Corner was selected. The machining for the filler is now applied correctly.
- Resolved issue with Master Double Sided Cabinet 2D Elevations. It no longer draws the rear elevation to the side of the front elevation.
- Updated all Sink Cabinets to report out the same part name for the Sub Front. These parts now have consistent naming for all sink products.
- Resolved an issue with incorrect machine points on the Corner Filler top and bottom parts. The parts were machined incorrectly if the "Filler Width Left/Right" were not equal.
- Resolved issues with Hinges and Door Buffers being placed incorrectly if the Top Reveal was set to a negative number. These hardware items should now position correctly in all door subassemblies.
- Updated all Blum LegraBox drawer systems. All standard systems include “Pure” in the name. All colors were changed to match the Blum specs, Orion Grey, Silk White, Stainless Steel. “Free” Style systems, height C only, have been added with all colors.
- Resolved issue with Double Top Drawer option having a static value and staying on in the Component Door Drawer FF subassembly. This now functions properly from the product prompts.
- Resolved an issue with Appliance Panel option in the Fridge product where it would crash during work order creation if Appliance Panel was on. *In the future, this product will receive additional updates to allow for Appliance Panels to draw and cut properly when used with the brands that are designated panel ready.
- Resolved an issue with missing back drilling in the Hettich Aventech YOU drawer system.
- Updated the control types of Corner Filler Type/Style to be visible in Blind Corner Cabinets, when "Use Corner Filler" is on.
- Resolved an issue with Shelf Adj subassembly shelf pin holes where both hole qty per shelf was on along with continuous shelf holes causing duplicated, overlapping holes.
- Updated Component Door, Component Door Drawer, Component Door FF, Component Door Drawer FF subassemblies to pass the correct material through to the Door Material prompt based on Product Type. This was an issue with Vertical Designer products and Double Door products where they defaulted to the Tall Door material.
- Resolved an issue inside the Wall Room Component that occurred when a Door subassembly was used. A static tool number “101” has been replaced with "=G!Default_Routing_Tool_CW" to prevent tool number errors. This correction cannot be applied with the library update tool. Shipping library has been corrected.
Microvellum Foundation Library Release Notes | Build 26.0112
The following release notes apply to the Microvellum Foundation Library build 26.0112.
Additions
- In accordance with Microvellum's new subscription changes, all Face Frame Expansion products and subassemblies, as well as the Range Hood Master product have been added to the full library install and library update zips (now included with base Foundation Library).
- Added a new Open Display Shelf product.
- Added the Top Scribe Return Filler product to the Upper Cabinet Accessories category.
- Added the option to have a 3rd door in the Component Sliding Door subassembly.
- Added the Shoe Fence subassembly option in the Shoe Shelf subassembly. This can be a nested subassembly. Current selection options:
- Kessebohmer CONERO
- Hafele TAG
- Added Rails Top and Rails Bottom options to the Extruded Soffit product.
- Added RPC 374 Institutional Hinges.
- Added the FIT SlimFIT drawer system to the options for the NZ region.
- Added the OVVO PD20 to the Invisible Fasteners options.
- Added control in the Hardware Wizard for Default Inner Drawer and Default Inner Wood Drawer Slide selections.
- Added option to toggle between Wood Spacers and Spacer Hardware in the Hardware Wizard. Also added Wood Spacer Height to the Hardware Wizard.
- Added the Ninka One2Five subassemblies to the Waste Bin Pullout options. This system can use multiple runner brands so there have been 3 options added:
- Ninka ONE2FIVE Blum TANDEMBOX Antaro
- Ninka ONE2FIVE Matrix Box S
- Ninka ONE2FIVE Grass Nova Pro Scala
- Added the Hafele Slido Fold61 25A/50A hardware to the options when Folding Doors is selected for Face Options.
- Added global checkbox to Show 2D Drawing Options. This will turn on the 2D drawing tab in products if checked.
- Added “Shadow Line Orientation” prompt in Tall Oven cabinets. This is to resolve issue when "Shadow Line Finger Pull" is selected in these products.
- Added Blum Legrabox Drawer Kit N 550mm 40kg and Blum Legrabox Drawer Kit M 550mm 40kg to the Hardware file. Also added the Blum Legrabox Side N 550mm Left/Right drawings.
- Added drawer slide graphics for the Finista Edge drawer system.
- Added the "Flatshot" subassembly and "Flatshot Token" prompt to all Extruded products.
- Added and updated multiple 2D drawing tokens.
- Added the new Extruded Bench product to the Extruded Fixture options. This product is currently in Beta and will be improved over time with feedback.
- Resolved an issue with Hafele Matrix Box Slim where the rear bracket holes were not correct for the 128mm height.
- Resolved an issue with Hardware Array machining on the bottom edge of the Division in the Component Pocket Door subassembly.
- Resolved an issue with part layer names in the Extruded Soffit product. All parts in all subassemblies used are now consistent.
- Modified the Hafele Alto Slim drawer system. The 64mm height has been removed and the 167mm graphics and hardware items have been added.
- Resolved an issue with Blum Merivobox where the Cutout Back parts were not sized or placed correctly when "Rear Cutout" and "Rear Cutout Use Metal Sides" were selected.
- Resolved an issue with Hawa CONCEPTA 3 where internal cabinet parts were not sizing correctly.
- Resolved an issue with Wood Drawer Box depth when Richelieu 818 or 828 drawer slide is selected. The drawer depth should be 10mm less than drawer slide nominal length for all drawers using the 818 and for all drawers, except the 270mm, for the 828.
- Resolved an issue Applied Panel when using MV Profile Door Applied Panel Type and selecting "Applied Panel Ends to Floor" and "Increase Applied Ends Bottom Rail At Floor" in the subassembly prompts. This is now controlled in the Applied Panel subassembly and flows to the nested MV Profile Door subassembly properly.
- Resolved an issue in Blind Corner products when using both "Shadow Line Finger Pull" and "Use Blind Corner Hinge". Parts now machine correctly for this scenario.
- Resolved an issue with Drawer Spacers not appearing in all designer and double door products.
- Resolved an issue in Master Die Wall where dado machining was not accounting for Toe Kick Inset value and extending too far.
- Resolved an issue when Shelf Support Fixing Options was set to slot. Both sides of the shelf now properly align with the shelf pin holes.
- Resolved an issue with 2D plan dimensions in corner cabinets not linked to the global Plan Width Base Point. This is now linked in the "2D Instructions Corner" subassembly.
- Resolved an issue with Back Center Notch option in Adj Shelf subassembly where the notch was off center when turned on.
- Resolved issues with Doors and Drawer Fronts extending too far down when No Bottom is selected. The Component Doors, Component Drawers, and Component Door Drawer subassemblies have been updated.
- Resolved issue with incorrect part size and location in Range Hood Master product.
- Resolved issue with Salice FF Hinges not drawing correctly for some of the Overlay options. Also updated the available options in hardware file.
- Resolved issue with Wood Drawer Box when Rear Cutout is used with screw construction method where the Screw machine token was assigned to wrong part edge.
- Resolved an issue with Leg Leveler Base hardware drawings rotating incorrectly.
- Resolved an issue with Toe Kick Assembly Box not being represented correctly in 2D Plan and Elevation.
- Resolved an issue with 2D plan and elevation representations of Waste Pipe and Tap Outlet options in the Wall room component product. This will only be available with a new install or a transfer of the Wall product via Database Explorer.
- Resolved an issue with prompts not showing when adding a single door to the Wall room component product. This will only be available with a new install or a transfer of the Wall product via Database Explorer.
- Updated 2D section Top and Bottom Reveal dimensions to align with other dimension lines.
- Modified the drawing tokens for Adj Legs and Toe Kick Assembly Box to draw lines top and bottom. It will only draw lines for left and right if it "Left/Right Finished End" is on or if "Left/Right Toe Kick" prompt is on in subassembly.
- Added the "LED Strip Lighting" prompt and subassembly to the relevant FF products.
- Added Divisions with Adj Shelves and Division with Fixed Shelves as options in the Horizontal Splitter FF and the Vertical Splitter FF.
- Resolved an issue in Master Split Vertical Designer Cabinet FF when the global Face Frame Miter FE Joint is checked. Applied Ends and Face Frame parts now miter correctly.
- Resolved issues in Master Split Height Designer Cabinet FF where the proper drawer quantity was not passing through correctly when selecting "Drawers for the Face" option in any bay.
- Resolved an issue with FF product drawing tokens where the Right Stile size annotation was incorrect. This has been resolved in the Face Frame, Rear Face Frame, Face Frame Quarter Round, Face Frame Open Corner, and Diagonal Angled Face Frame Drawing subassemblies.
Year of 2025
This section lists all of the Foundation Library builds that released in the year of 2025.
Microvellum Foundation Library Release Notes | Build 25.1121
The following release notes apply to the Microvellum Foundation Library build 25.1121.
Additions
- Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category.
- Added the Nesting Optimization Report Select Processing report to the list of available reports.
- Added 2D elevation representation for Crown and Base Moldings.
- Added an additional column, 2D Profile Lines, to the Molding table and input line locations for existing moldings.
- Created Left and Right End blocks for each existing molding for return representation.
- Added new Master Split Blind Corner Cabinet product.
- Added “Top/Bottom/Both” option for "Push Catch" in the MV Door, MV Profile Door, and the Solid Wood Door subassemblies. This will default to “Bottom” in base cabinets when Vertical rail is selected. This was causing an issue with the catch rotating.
- Added option to have center legs in Corner Adj Leg subassembly. Additionally:
- If “Width” or “Depth” is greater than “Width to Add Center Legs”, center legs will be added to the backs.
- If the “Pie Cut Distance Left/Right” is greater than “Width to Add Center Legs”, center legs will be added at the front.
- Added the new Extruded Soffit product. This is a rules-based parametric extruded product.
- Added the Hettich Slimline M sliding door hardware to the Component Sliding Door subassembly. Includes all 3 track options for inset doors, Press In, Screw On, and Glue On.
- Added the Richelieu 908 and Richelieu Optimiz-R Drawer Kits to the hardware file. These additions match the subassemblies and graphics that were already available. Pricing can now be added to these kits at the Library level, if needed.
- Updated the “Left/Right End Dimension” prompt in all products. These prompts will now read the “G! Finished End Dimensions” variable and the product’s “Left/Right Finished End” prompt before turning on the drawing token.
- Modified standard DWT files:
- Updated the settings for both Hidden and Conceptual visual styles so that it appears and plots correctly in Paper Space.
- Updated the Layout Tabs to open zoomed to extents.
- Modified the Drawer Division subassembly “Double Division” prompt. This will now grey out if the prompt is present in the product prompts.
- Modified the Component Doors subassembly “Symmetrical Door” prompt. This will now grey out if the prompt is present in the product prompts.
- Resolved an issue with the Drawer Division height not calculating correctly when “Drawer Stretcher Offset” value was changed.
- Resolved an issue with top and bottom plates of the Die Wall w Studs product occurring when the “Bulge” calculation was “-“.
- Resolved an issue with Extruded Part Vertical product’s “Height” prompt. It now has the UCN formula to work in both metric and imperial correctly.
- Modified the “Mounting Position” prompt in the Kessenbohmer Wastebin Pullout subassembly to grey out if that is not an option for the Waste bin model selected.
- Resolved an issue with the Nikol Teramo Bin subassembly where the side drilling was incorrect.
- Resolved an issue with the right-side slide drilling in the Blum LEGRABOX subassembly. It will now drill through on the right side if there is a division, if selected.
- Added the Illumination design element to the Hettich AvanTech YOU drawer system.
- Updated the names for the Rev-A-Shelf 5349 Bottom Mount Waste Bin hardware items and drawing names. They now say “Waste” instead of “Waist”.
- Resolved a pair of issues in the Wall room component product:*
- Dimensions will now appear for Window 2 when "Dimension Openings" is checked.
- Outlets 1-4 Type will now appear correctly in 3D and 2D plan and be spaced apart by default instead of having the same distance for all.
- Note: This will need to be manually added, if updating.
- Resolved an issue with 2D plan drawings of the Extruded Master Countertop when using the Butt Join option for "Left/Right Join Type" prompts.
- Resolved issues with the “Strip Lighting Left/Right Distance” from “Top” prompts value in the Strip Lighting Insert subassembly.
- Resolved an issue where selecting “Panel Insert” on a right-swing MV Profile Door caused the panel to be positioned incorrectly. The panel now inserts in the correct location.
- Updated the construction method in Scribe Filler subassembly and products to look to the “Construction Method Scribe Filler with Cleats” global.
- Resolved issue with Intermediate Stile being offset when adding Double Drawer in Face Frame products.
- Resolved issue when adding Cabinet Modification and selecting “Cabinet Notch Left” or “Cabinet Notch Both sides”.
- Updated the Applied Panel subassembly drawing token for part thickness dimension in plan view. It now follows the global “Plan Width Base/Tall/Upper Point”. If the global is set to "None", the Applied Panel thickness dim in plan turns off.
- Resolved an issue within Master Split Cabinets wherein the nailer was not extending the full length needed.
- Resolved an issue with the “Shadow Rail” in the Tall Pantry product. This now works on drawers and has options for the “Vertical Shadow Rail” when a single door.
- Resolved an issue in the Finista drawer system. The runner holes and back fixing bracket machining now drill in the correct locations.
- Resolved an issue with the Master Upper Split Height Cabinet FF where the sides would not draw in model.
- Updated Face Frame Rail Modifiers to work when Face Frame Option is set to “Single Panel”.
- Added the “Intermediate Drawer Stile” option to Drawer Division FF subassembly.
- Added global “Face Frame Top Scribe Amount”, as well as the “Extend Left/Right Stile Up Amount”, “Extend Top Rail Up Amount”, “Top Scribe Amount” prompts to the Face Frame subassemblies.
- Top Rail and Stiles will extend up the “G! Face Frame Top Scribe Amount” on Tall and Upper products. This can be controlled at the subassembly prompt level for individual cabinets.
Special Note:
- The “Unitless Decorative Laminate” Specification Group has been removed from the library as well as the Formula Cutparts and Edgeband component files. Most of the associated formula materials have also been removed to make way for a new soon to be released group of formula materials in beta at the time of this release.
Microvellum Foundation Library Release Notes | Build 25.1024
The following release notes apply to the Microvellum Foundation Library build 25.1024.
Additions
- Added Face Profile Options to the Door Wizard for enhanced design flexibility. Users can now apply decorative visual profiles to doors, drawer fronts, applied panels, and fascias. This feature uses the Carving Token which is added to the display decorative face profiles. Available Profiles:
- None
- Reeded (6.35mm – 1/4in)
- Reeded (12.7mm – 1/2in)
- Reeded (19.05mm – 3/7in)
- Cove (6.35mm – 1/4in)
- Cove (12.7mm – 1/2in)
- Cove (19.05mm – 3/4in)
- Added options for Double Top Drawer to the Master 2 Bay Horizontal Cabinet and the Master Horizontal Designer Cabinet.
- Added Front Bay Double Top Drawer and Rear Bay Double Top Drawer options to the Master Double Sided Cabinet.
- Added new Hettich Drawer Slides:
- Quadro 5D V6
- Quadro 5D
- Quadro 25D
- KA 3320
- Added new Hettich Hinges with 45mm drilling pattern:
- Intermat
- Optimat
- Sensys
- Veosys
- Added Finista Edge Drawer System.
- Added Servo-Drive for Blum Aventos as an option in the LiftUp Doors.
- Added “Construction Method Thick Back FE” to the global and project wizard. This will allow more control over construction methods.
- Added “Filler Align with Door Top Gap” global. This will allow the user to choose whether the filler is flush to carcase top or aligns with the top of the door.
- Added “Extend Vertical Front Rail Amount” global. The amount added will be in addition to the already calculated width of the Vertical Front Rail in the Sink cabinets with False Fronts.
- Added new drawing tokens in the "Shelf Adj" and "Shelf Fixed" subassemblies that are used when the “Shelf Edge Type” is set to Face Mounted Lip Down, Face Mounted Lip Up, or Mitered. If either of these options are selected, the drawing token for the shelf turns off and the new token turns on.
- Added Mirrored version of button-fix fasteners to resolve issue with incorrect machining when the machining face is changed :
- Added button-fix type 1 flush Mirrored, button-fix type 1 metal Mirrored, button-fix type 1 bonded Mirrored.
- Updated the hardware machine tokens for button-fix type 1 flush, button-fix type 1 metal, button-fix type 1 bonded.
- Resolved an issue with Upper 2 Door Glass Door product where Door Stiles and routes for glass did not align properly.
- Resolved an issue with the Master Any Angle Cabinet, occurring when Shadow Line Finger Pull was enabled:
- The full top will now cut and draw correctly.
- The Shadow Line Rails will now be sized and placed correctly on the right side.
- Resolved an issue that occurred when “Cabinet Modification Options” and “Cabinet Void” were enabled simultaneously:
- Top, Bottoms, and Shelves are all machining correctly in this scenario.
- Resolved issues with the Hettich Multitech Drawer System.
- “Softclose Right” prompt was always on but is now set to be off by default.
- “Front Fixing Brackets” are now rotated and located correctly.
- "Inner Front Wood" part will now look to the drawer height and as well as the top and bottom overlays.
- "Wood Drawer Spacer" is now in the correct Z location.
- Resolved an issue wherein “Toe Kick Notch” was not turning off when “Inset Toe Kick” was set to 0.
- Resolved an issue with the Drawer Box List Report, wherein the incorrect Drawer Width would be displayed on the report.
- Resolved an issue with Harn Alunan T Drawer System.
- Size T Depth 270 right slide is now rotated correctly.
- Resolved an issue with Corner Filler with Cleats product.
- Associative machining (Screw, Dowel, Cams) applied to the width of the cleat parts now reference the relevant "G!Small Part Threshold” variables for correct machining.
- Resolved an issue with hardware machining on Fixed Panel when set to Full Inset. The following hardware machining has been updated:
- Button-fix type 2 Fixed Panel
- Keku AS Ush-In Fitting Fixed Panel
- Keku EH Suspension Fitting Left Fixed Panel
- Keku EH Suspension Fitting Right Fixed Panel
- Keku EHS Suspension Fitting Left Fixed Panel
- Keku EHS Suspension Fixing Right Fixed Panel
- Resolved issues with Master Double Sided Cabinet product:
- Applied Ends now size correctly when "Flush with Face" is on.
- The back being missing in product should be resolved.
- Push Catch hardware now rotates correctly when selected.
- Resolved an issue with the Wall component not placing the Tap Outlet in the correct location. If “Tap Outlet 1 From Right Side” is selected, it will be placed at correct location from right.
- Resolved an issue with the “Fridge” subassembly and the Fridge appliance product.
- When selecting both “Appliance Panel” and “Add Handles”, the handles will now be located correctly on the panel.
- Resolved an issue with the Bracket Single product. The bracket will now be drawn in the correct Z location.
- Resolved a name error issue in the global “Default Waste Bin Pullout.” This now correctly looks to the Hardware Wizard.
- NOTE: This will overwrite the existing value for this global.
- Resolved an issue with the face machining for the Rev A Shelf 5349 Waste Bin. The face machining now aligns with the specifications and the 3D Graphics.
- Resolved issue with “Drawer Qty” not passing through to the subassemblies in the Master Split Height Designer Cabinet.
- Resolved an issue that would occur in Front and Rear Undermount Notch sizes when using Hettich Undermount Drawer Slides.
- Resolved an issue with the Master Split Corner Cabinet with Thick Back selected. The product will now turn off the middle back when Split Qty is set to a value of 2.
- Resolved an issue with Hinge Plates, wherein Liftup Doors and Drop Down Doors would move to the outside face of the top and bottom when the Top/Bottom Reveal values were increased. The hinge plates now stay correct located on the inside face of top and bottom.
- Resolved an issue with the Tall Fridge Cabinet when selecting Liftup Door as the Face Option and adding a value to the “Valance Height Bottom” prompt. The door now sizes and locates correctly.
- Resolved an issue wherein the Electric Cooktop appliance was not placed correctly in Countertop products. The default value of the "Appliance Distance from Left" prompt now has the appliance centered.
- Resolved an issue with incorrect routing on Any Angle Cabinet when Inset Door Sides or Full Inset was selected.
- Resolved an issue with Corner Diagonal Cabinets and hinge plate location when Right Swing or "Two Door" was selected in Face Options. The right hinge plate now associates and is placed correctly on the right side.
- Resolved an issue with Wall product when Door and/or Window qty was changed to 3 or 4 and the wall was not showing the cutout for these. All Door and Window cutouts now appear in wall with all quantity selections. *
- Resolved the hardware association issue when Lockdowel E3259BM Channel Lock is selected in the Hardware Wizard as the Hardware Edge Array hardware. The incorrect edge offset was updated in the Look Up Table.
- Changed layer colors in all dwt drawing templates to be index instead of true colors. *
- Resolved a machining issue with the Extruded Base Cabinet. The dado notch in the top has been corrected.
- Resolved a machining issue with the Extruded Die Wall products. Shortened the dado on the bottom plate when using a toe kick to prevent the rout from hitting other parts in a nest.
- Renamed the BLUM CLIP top 95deg Knock_In hinges to Knock-In for consistency in naming convention.
- Removed prompts and machine tokens related to Saw machining from the Thick Panel subassembly.
- Updated the three Extruded Molding products – Extruded Base, Extruded Crown, Extruded Valance. Products have been refactored to match other extruded products in the library.
- Updated the Hardware Array machine tokens in the Wood Drawer Box subassembly so that it places the hardware correctly and references “H!LookUpTableEdgeArray” column 9 to determine if a single hardware item is required or not.
- Updates were applied to the Blum REVEGO Pocket Doors product.
- Fixed multiple bugs of component sizing & location.
- Hardware & machining has been updated to reflect Blum's forthcoming release.
- Updated help texts & images to make cross referencing Blum's documentation clearer.
- Countertop height options have been added.
- Updated the baseline of REVEGO hardware 3D graphics.
- Resolved an issue with the Finished End 2D drawing text not turning off with global or prompt controls.
- Resolved an issue with the Face Frame Base and Upper Split Height Cabinets. The face frame elevation will now draw correctly with or without “Show 2D Elv Face Frame Parts” selected.
- Resolved an issue in Diagonal Corner Cabinet FF products with the top and bottom front angle when Width and Depth are not equal.
- Resolved issues with 2D Elevation representations in FF products.
- When adding a value to Extend Bottom Rail Down Amount this will not show correctly in elevation.
- When selecting Face Frame as the “Left/Right End Condition” will not show the inset panel in elevation.
- When selecting Applied End as the “Left/Right End Condition” will no longer show the thickness of the applied panel or the dimension of the thickness in elevation.
- Resolved issue where stile/rail joint lines were still showing in elevation when stile was turned off.
- Resolved issue with parts not drawing in the Master/Base/Tall/Upper Open Corner End Cabinet FF products.
Microvellum Foundation Library Release Notes | Build 25.0919
The following release notes apply to the Microvellum Foundation Library build 25.0919.
Additions
- Added Harn Alunan T7 Drawer System.
- Added “Left” / “Right” to Drawer Front part names at double drawer conditions.
- Added Vertical Shadowline to all 1 Door Cabinets, Vertical Designer Cabinets, and Master Cabinet.
- Added "Shadow Rail Name" and "Corner Shadow Rail Name" to global variables. This will allow users to create custom Shadow Rail subassemblies.
- Added Global prompts “LED Strip Lighting Insert Name” and “LED Undermount Strip Lighting Insert Name”. This will allow users to create custom LED Strip Lighting subassemblies.
- Added Blum 95 Deg Thick Door Hinges.
- Added "Drawer Dividers" to the Wood Drawer Box and Wood Rollout Three Sided Shelf subassemblies.
- Added "Leg Leveler Base Finished At End" prompt in the Hardware Wizard.
- Added Finished End Leveler Base in the Adjustable Legs subassembly.
- Added triangular base plates for the Hafele Axilo plinth system (adjustable legs).
- Added more Face Options to the Counter Height 1 Door and Counter Height 2 Door products. Sliding Doors and Folding Doors are now options in these products.
- Added additional functionality to Crown Molding placement.
- Added global “Crown Molding Front Offset” to set the distance away from the face or side of cabinet
- Added “Crown Molding Height Offset”. This will replace “Crown Molding Height Above Floor" (Now in the Legacy tab). Crown Molding will now follow the height of the cabinet +/- this offset value.
- Added Project Wizard variable “Construction Method Scribe Filler with Cleats”.
- The mv2DTemplate.dwt file in the root MV Data folder has been updated. This is used whenever a 2D part drawing or nest drawing is generated by MV. *
- Removed all text styles and dim styles except Annotative and standard.
- Removed unused fonts.
- Added both a metric and imperial dim style as this template file is used for both metric and imperial installs.
- The majority of all dwg graphics (blocks) have been cleaned and standardized to ensure consistency and compatibility (Approximately 18,000 files). The result of this work has reduced the overall size on disk by about 1.7GB. Here's what was done: *
- Removed all layouts except Layout1 to simplify the drawing structure.
- Reassigned all text objects (Text, MText, Attributes, MLeaders) to use the Standard text style.
- Deleted all text styles except "Standard” and updated "Standard" to use the Arial font.
- Deleted all dimension styles, keeping only the default Standard dimstyle active.
- Purged unused content, including blocks, layers, layer filters, and registered apps.
- Audited each drawing to fix any database errors.
- Saved and closed each file after cleaning.
- Resolved issue with Hinge locations not appearing in the Door and Drawer Front Fabrication Report.
- Resolved issue with all Die Wall products not drawing parts and/or drawing on incorrect layers.
- Resolved multiple issues with Extruded Base Cabinet:
- Dados for Top and Bottom parts should appear as specified.
- The Z location for adjustable shelves should now apply correctly.
- Adj Shelf support holes machining on left and right ends should now generate correctly.
- The back edge radius on Adj Shelves when extruded on a curve should appear with the correct shape.
- Resolved an issue with Integrated Dishwasher product when Applied Ends to Floor to floor is selected.
- Resolved an issue with size and position of the Component Doors subassembly in the Tall 1 Door Double Door and Tall 2 Door Double Door when adding Top/Bottom Valance heights.
- Resolved an issue with the position of the bottom connectors in Hawa-Concepta III Pocket Doors.
- Updated Runner Hole Locations in the Kessebohmer Conero Pullouts.
- Resolved an issue related to Perfect Grain containers in Double Sided Cabinets.
- Changed the "Grain Matching Identifier" prompt value to be the first number of the item number instead of entire item number.
- Added a warning message that this value cannot equal the entire item number.
- Resolved issues in the Upper Rangehood Cabinet.
- Added a Prompt Value for Hinge Location Bottom that will reference the Rangehood height.
- Resolved an issue with a typo in formulas.
- Resolved an issue with the 3D graphics for the Vauth Sagel SUB Side Saphir 200mm Pullout Shelf and the Vauth Sagel SUB Side 150mm Shelf. They will now position correctly.
- Resolved an issue with the Strike Plate rotation with Right Swing 1 Door scenario.
- Updated the Base/Tall/Upper Overlay Top global variables. Their value looks to the correct Project Wizard variable.
- Note: This will append the existing value for the variables. *
- Updated the Back Fixing Screw Type and Bottom Fixing Screw Type in all Drawer Systems to now look to the “Default Drawer System Screw” instead of the “Default Drawer Wood Screw”.
- Updated the “Applied End Type” prompt in the Applied End product to reference the correct “Product Type” Applied End from the door wizard.
- Resolved an issue with Hafele Axilo Mounting Plate Press In hardware machine token.
- In some instances, the Distance Between Holes parameter will convert to an imperial value that is minutely different than the added X or Y start and end values.
- The resolution is to add the numbers in a formula instead of putting just the total.
- Note: This will append the existing value in the hardware machine token. *
- Resolved an issue in Corner Cabinets where the backs did not draw in 2D Elevations when Elevation Show Hidden Carcase Layers was turned on.
- Resolved an issue with the Italiana Libra H2 & H1 hardware machine tokens. These now match the specs for these hardware items.
- Updated the “Depth” prompt in the Upper Pocket Door product to a depth that eliminates the hardware association error.
- Renamed the Hinge BLUM 120deg hardware to Hinge BLUM CLIP top 120deg for more consistent nomenclature.
- Note: If using the Library Update utility, this will create duplicate hardware. *
- Updated the Extruded Product Builder dwt templates:
- Metric – dimensions scaling properly.
- Imperial – Left and Right model space views changed to be consistent with previous version of the template.
- Resolved issue with Full Right Rail in the Master Corner Cabinet having incorrect dowel machining.
- Resolved issue with "Stop Dado" and "Dado Notch" machining appearing outside of the part border.
- This occurred when the "Dado Notch Distance" variables were set to 0 but the "Dado Stop Gap" variable has a value.
- Resolved an issue with drawer box location when selecting Top Drawer in a Blind Cabinet.
- Resolved an issue with Blum REVEGO Pocket Doors product where the track hardware was placed incorrectly.
- Resolved an issue with the hanger notch in the wrong location when Rebate Upper Top Nailer is on and Back Construction is “Full Captured”.
- Resolved an issue with an error being generated when Use Shelf Standards/Shelf Standards Fixed Lengths were selected and the height of the cabinet was reduced below the available lengths. The machine token will be disabled when the length of the Shelf Standard falls outside the valid range defined by the lookup table.
- Resolved an issue with the three Extruded Molding products. Selecting “Produce Individual Parts” will now prevent the full-length part from being cut listed.
- Improvements were made to Designer Cabinet products when selecting a different material for Doors vs Drawer Fronts. The Drawer Material prompt should now be reference by any drawer front parts inside the product.
- Back Construction options in the global now include “No Back” and “Removable” as options. This cannot be added to the library update. *
- Resolved issues with the Titus Vitek drawer system.
- Resolved issue with the Generic Five Piece door style “Framed Glass 5pc” when used with a Full Inset FF cabinet.
- Refactored the Wood Drawer Box Lockdowel subassembly:
- An issue was fixed with the drawer slide machining rotating 90° when in a Double Drawer config. This issue was resolved with "Part Name" filtering and the creation of a new set of machine tokens.
- All the machining parameters for the LD keyway used to reference globals that looked to the H! LookUpTable, those have all be changed to lookup directly in the formula.
- E900BP-Mini Channel Lock has been added per the manufacturer's product guidance to their customers.
- The drawer using Lockdowel construction will automatically switch from the standard channel lock to the mini one when drawer box side/subfront material thickness is less 18mm.
- A new series of keyway machine tokens were added for these at the drawer fronts.
- Added help images for subassemblies such as:
- “Undermount Strip Lighting Insert”
- “Shoe Shelf”
- “Double Hanging Rail”
- Added new global variable “Hinge Location from FF Opening”. Select this to measure the top and bottom hinge locations from the inside edge of the face frame opening (i.e. the cabinet opening). Leave unchecked to measure hinge locations from the edge of the door instead.
- Added “Face Frame Rail 1 Control” and “Face Frame Rail 1 Overlay” prompts to the Base 2 Door Farmhouse Sink FF product.
- This will give more control over the placement and spacing above/below the rail below the sink.
- Added “Add Blind Corner Panel” prompt to the Blind Corner Face Frame products.
- This will shorten up the face frame and a panel to enclose the blind end.
- This will set the Face Frame Overlay Control Left/Right (depending on blind side) to Outside and the Left/Right stile width will be controlled with the Face Frame Blind Corner Stile Width.
- Added the option to “Add Intermediate Drawer Stile” to the Drawer Division FF subassembly.
- Added the option for a “Double Top Drawer” to the Component Door Drawer FF subassembly.
Additions/Changes to the DWT Template Files
Key Changes Implemented *
- Fonts & Text Styles
- All fonts in Imperial template set to Arial.
- Attribute text style changed to REMARKS.
- Annotative MLeader style added to Metric template and updated in Imperial template.
- Linetypes & Layers
- Multiple 2D and 3D layers had linetypes updated from CONTINUOUS or DASHDOT to DASHED2 or DASHDOT2 (depending on template).
- Final adjustments made:
- Imperial: 2D_DASHDOT → DASHDOT2; 3D_DUMMY DOOR ELEV & PLAN → DASHDOT2.
- Metric: 3D_DUMMY DOOR ELEV & PLAN → DASHDOT.
- Hidden and operation line linetypes standardized, with LTSCALE set to 13 for metric.
- Layout & Plotting
- Layouts renamed (e.g., SH01 → A101).
- Plot style table set to Monochrome for all layouts.
- Plot area changed to Layout.
- Imperial sheet size updated to ANSI full bleed b (11" x 17").
- Metric templates include both A4 and A3 sheet sizes intentionally.
- Dimension Styles
- Imperial Dimstyle text offset adjusted from 0.09" → 0.035".
- Dim styles updated in both Imperial and Metric templates for consistency.
- Other Fixes
- Removed old fonts from layout labels.
- Sheet numbers dynamically linked to drawing labels.
- Typos corrected.
- Blocks updated (e.g., section blocks moved to TITLE layer).
- Default model space scale in Imperial template set to 3/4" = 1'0".
- Resolved EPB template that caused an issue when using with AutoCAD.
Microvellum Foundation Library Release Notes | Build 25.0813
The following release notes apply to the Microvellum Foundation Library build 25.0813.
Additions
- Added Metafile Rail Support Bracket as a hardware material, including associative machining tokens.
- Added the Richelieu Knock-In Assembly Fitting as a Hardware Array connector option.
- Added the Blum Tandem Rear Mount Brackets, including 3D images and associative machining.
- Added a selection option in the Drawers section of the Hardware Wizard.
- Updated all Wood Drawer Boxes and Pullouts with the selection options.
- Added Grass Base Mounted drawer slides.
- Added Base/Tall/Upper Pocket Doors products.
- Added the new Ladder product.
- Added the new Toe Kick Platform product.
- Added the new Hawa Concepta Pocket Doors product.
- Added global variable controls for “Drawer Bottom Max Span” and “File Drawer Bottom Max Span”.
- Added a new global variable, “Construction Method Scribe Filler with Cleats”.
- Added a new global variable, “Filler to Floor”.
- All Filler products and the subassembly “Filler to Floor” prompt have been updated to reference this new global.
- Added “Cleat to Floor” prompt in Scribe Filler with Cleats product and subassembly.
- Added drawing tokens to the Blum Space Step for the face to show in plan and elevation drawings.
- Added an Electric Cooktop option into the Countertop Appliance Options in the F Workbook.
- Added Fisher Paykel induction cooktops to the Electric Cooktop options.
- Added a control for Splay Edge Top Width to the Door Wizard. Connected the Finished Faces and MV Profile Door subassembly prompts to new variable for higher level control.
- Added a prompt to the MV Profile Door "Face_5_Only_Trigger". If TRUE the machine point will change from a 4 to a 3M, and the glass and panel insert cutouts and rebates will be placed on face 5.
- This condition is triggered when the internal profile is 'None' or its route passes (Column 2 in the Door Wizard) equal 0, and the Edge Profile is 'None', and either Glass Door equals 1 or Panel Insert equals 1.
- Added the FGV Unilux drawer system.
- Added new Glass Shelf subassemblies, including new material pointers and the following added to the list of available inserts:
- Shelf Adj Glass
- Angled End Shelf Adj Glass
- Angled Shelf Adj Glass, Any Angled Shelf Adj Glass
- Diagonal Angled Shelf Adj Glass
- Shelf Adj Glass Angled Ends
- Corner Shelf Adj Glass
- Added four new CAD Templates (DWT) files for Toolbox BSB. *
- BSB Metric Annotative Drawing Template
- BSB Imperial Annotative Drawing Template
- BSB Extruded Product Builder Metric
- BSB Extruded Product Builder Imperial
- Updated the size and position of the Component Doors in the Tall 1 Door Double Door and Tall 2 Door Double Door products. Also resolved door hinge and bumper hardware locations.
- Resolved an issue Top and Bottom Valance not working in Full Inset Doors.
- Resolved an issue with top hinge location on Sink Cabinet products with vertical rails.
- Resolved an issue in the Diagonal Vertical Designer Cabinet when selecting 2 Door as a Face Option.
- Updated the Post Laminate subassembly.
- Updated the overall size of subassembly to account for options that extend the sides and back to the floor.
- Added additional prompt in subassembly to better control the size of the post laminate parts.
- Updated all Toe Kick Assembly Box subassemblies to follow the global "Construction Method Toe Kick".
- Resolved an issue with Cabinet Modification Options in the Upper Rangehood Cabinet. “Center Ducting Box” is now the default selection and shows up in the drop-down options.
- Resolved an issue with location of Vauth Sagel COR Wheel pullout in Base, Tall, and Upper Corner Cabinets.
- Resolved an issue with drilling on Full Applied Back in Tall Fridge Cabinet.
- Resolved an issue with Wine Rack Trellis X having missing parts.
- Updated the Corner Filler with Cleats products with additional prompts to control Left and Right Filler Widths. Previously, there was on prompt, Filler Width, that controlled both sides.
- Resolved an issue with Shelf Adj drilling when "Continuous Shelf Holes" was selected.
- Updated the help text for Construction Method Left, Construction Method Right, Construction Method Top, and Construction Method Bottom for better clarity of the application.
- Resolved an issue with placement of Blum Aventos HF Top hardware.
- Updated Box End and Base Island Box End with the following:
- Left/Right Infill Panels – follow the Applied End Type selection
- Added 2D Elevation tokens to draw properly with the applied panel selections
- 2D Elevation width dimension token added.
- 2D Elevation height dimension tokens added.
- Resolved issues with Shelf Adj Angled Ends subassembly when shelf edge type is set to mitered:
- Adjusted the Z origin.
- Added miters to the ends so the edge aligns with shelf.
- Resolved issues with Shelf Adj and Shelf Fixed involving association with “G!UseMiterfold” turning on miterfold shelf part. Updated to only turn on with “G!UseMiterfold” and “Shelf Edge Type” set to mitered.
- Resolved an issue with Applied End Type not drawing in 2D elevation when set to Generic Five Piece.
- Resolved an issue with 2 Door Microwave Upper Cabinet section drawing. The pull was not accounting for the Appliance Opening.
- Updated the grain marker block to rotate properly on Solid Wood Door subassembly.
- Resolved the issue of Hawa Concepta III Doors missing doors with Door Type was set to MV Profile Door.
- Resolved an issue with Diagonal Angled Shelf Fixed being placed in the wrong location when construction method was not set to dado.
- Resolved an issue with Solid Wood Doors missing panels when adding mid stiles to door.
- Resolved the issue of 3 Door Cabinets not having equal doors when Double Mullion was selected.
- Resolved an issue with door/drawer front cutouts when Single Panel was selected for Face Frame Option.
- Resolved an issue in the MV Profile Door with No Profile Handle not following the Door Wizard selection.
- Updated the 2D Instructions subassembly to represent elevation correctly when Elevation Show Hidden Carcase Layers is checked on.
- Resolved issues with back heights for the Furnware Symetra drawer system.
- Updated Cabinet Chamfer Bottom, Cabinet Chamfer Top, and Cabinet Chamfer Top and Bottom subassemblies. The angles and positions have been corrected.
- Updated the Range Hood Master product. Applied several corrections.
- The below products will now respond to selecting “Shadow Line” global variable to on:
- Master 2 Bay Vertical Cabinet
- Tall 1 Door Double Door
- Tall 2 Door Double Door
- Tall Pantry With Drawers
- Tall Wall Oven
- Tall Wall Oven Full Box
- Tall Wall Oven With Microwave
- Tall Wall Oven With Microwave Full Box
- Master Wall Oven Cabinet
- Added additional functionality to the Mid Rail Extension options to include bays with Top Drawer selected.
- Added Face Frame dimension token for the opening size in Blind Corner Cabinets.
*Not included in Library Update, only in the full install.
Microvellum Foundation Library Release Notes | Build 25.0703
The following release notes apply to the Microvellum Foundation Library build 25.0703.
Additions
- Added a rebate (rabbet) to the bottom edge of top Nailers to create a notch that functions as a Hanging Cleat. This feature is globally controlled and can be enabled per cabinet type (Base, Tall, Upper). The depth and width of the rebate is globally controlled as well. Added five new Global variables:
- “Top Nailer Rebate Width”
- “Top Nailer Rebate Depth”
- “Rebate Upper Top Nailer”
- “Rebate Tall Top Nailer”
- “Rebate Base Top Nailer”
- Added a new product, the Master Diagonal Vertical Designer Cabinet.
- Added a new Miterfold Edge option to Adjustable and Fixed shelf interior components.
- Added Drawing Icon for easier access to “2D Instructions" subassembly prompts.
- Added five new global variables for additional control over CAD Dim Styles and Section Text Layers:
- “Dimension_Style_Options”
- “Plan_Dimension_Style”
- “Elevation_Dimension_Style”
- “Section_Dimension_Style”
- “Section_Text_Layer”
- If any of the above are set to "Template", the corresponding 2D drawing token will default to the dimension style specified in the drawing template (e.g., MV Annotative).
- Text styles are currently setup throughout the 2D drawing tokens. Many of the subassemblies had hard values for the layer. We have gone through most of them and fixed this.
- “Filler Text Alignment” and “Finished End Text Alignment” have been changed to a dropdown Options: “0|1|2”. This has been corrected as before we had it as an offset.
- Added several new enhancements to the Wall room component:*
- Added the ability to have up to 4 windows and 4 doors per wall.
- Added plumbing for waste pipes and tap outlets in the wall.
- Added the option to have up to 4 electrical outlets in the wall.
- Added elevation dimensions to the wall and elevation label. Users can either use the system wall variables or turn them on in the Wall product for better control.
- Added Rakks Vanity Brackets to the ADA Sink Angled Frame product.
- Added features to the Bracket products:
- Added A & M Concealed Support Brackets to the Bracket subassembly. New materials added.
- Bracket Array and Bracket Single products now both use the Bracket subassembly for easier maintenance.
- Improved the structure to support both generic brackets and name branded brackets via a LookUpTable.
- Added Electric Cooktop option to counter tops. There are two default Custom Cooktop options and 5 new branded models with DWGs. Plan views are also created.
- Added additional leg lever, Hafele Axilo Adj Feet 35mm.
- Added additional fastener, Hafele Zipbolt UT 35 Mini.
- Added new Kessebohmer Magic Corner subassembly pullout.
- Added a new global variable “Blind Corner Hinge Plate Distance From Edge”. This allows control of hinge plate locations from edge, specific for blind corner conditions.
- Add the ability to count screw quantities for the Cabinet Connector feature. Added new hardware wizard variable “Cabinet Connector Screw Fitting”. Updated the global “Connecting Hole Diameter” to point to the appropriate LookUpTable. Note that previous diameter you have set may be changed after the update.
- Added a “Slide Setback” prompt variable to the wood drawers. This will allow specific drawer system adjustment or specific user calibration.
- Added Blum Tandem Slide Spacer hardware.
- Added grain matching feature to all Scribe Filler products and subassemblies.
- Added features to the Valance product:
- “Cleat On/Off option”
- “Cleat Width variable”
- “Valance Top” vs “Valance Bottom”
- Added two new global variables to better accommodate hinge placements for small doors:
- “Small Door Threshold” - Defines the maximum height at which a door is considered "small."
- “Hinge Location Small Doors” - Specifies the reduced distance from the top and bottom edges for hinge placement on small doors.
- If a door’s height is less than the "Small Door Threshold", the hinge positions will be calculated using the Hinge Location Small Doors value instead of Hinge Location Bottom and Hinge Location Top.
- Added new global variable “Dado Clearance Position Regular Dado" to provide better control over dado clearance gaps and which direction they go. The settings below determine how the clearance is oriented relative to the cabinet part receiving the dado:
- Outside – Applies the clearance to the outer side of the panel (away from the cabinet's interior).
- Inside – Applies the clearance to the inner side of the panel (facing the cabinet interior).
- Both Sides – Applies an equal clearance on both sides of the dado, centering the cut.
- Updated all door and drawer subassemblies by populating the Hide On Reports column for prompts that are unlikely to be used in reporting. This will reduce the amount of data populating the work order database and potentially decrease processing time.
- Resolved an issue with Undermount Rangehood Cabinet. The product now utilizes the Undermount Strip Lighting Insert subassembly, which resolved an issue.
- Resolved a regression issue with the Shelves with Shelf Std product. The “Product Type” prompt has been added.
- Improved the formula logic that determines when a shelf exceeds the global max span distance, no matter the shelf location. Center fixed shelves will now follow the max span rule and change to a wide span material as required.
- Added groove machining to the Grass ZBox drawer bottom.
- Resolved an issue with the “Splay Edge” feature on drawer fronts.
- Resolved several issues with the Cabinet Faces Only product:
- Added missing “Product_Type” variable.
- Corrected drawer front calculator issue.
- “Use Aluminium Handle” prompt added.
- Resolved the following issues with Five Piece Door subassembly:
- Flat center panel will now have the correct Y origin.
- 2D elevations will now show the door outline when door construction is set to “Single Panel”.
- Resolved an issue with Peka Base Pullouts. When changing from Right to Left hand, the drilling will now be correct.
- Resolved an issue with the LeMans II Pullout related to regional and face frame differences.
- Updated the remaining waste bins to include the 2D help text warning showing why it does not fit.
- Updated the Kessebohmer Magic Corner II and graphics. The hardware will no longer have front drilling, as this is behind doors.
- Added the Kessebohmer Magic Corner to the blind corner pullout list.
- Resolved a naming issue for the Kessebohmer Conero 72H Comfort Tray Pull Out and Kessebohmer Conero 72H Internal Pull Out. The product names now align with both the drawing DWGs and the associated hardware names.
- Resolved an issue with Wastebin Pullout prompts. The issue was caused by the Control type date using data from “G!Default_Double_Waste_Bin_Pullout”, when it should have been using “G!Waste_Bin_Pullout_Options”.
- Resolved an issue with Upper cabinets. Selecting the Lift Up face option will now always work.
- Resolved an issue with 2D Plan Dimension tokens involving Applied Ends and Fillers.
- Resolved an issue with 2D Elevation tokens for cabinets with Applied End option.
- Resolved regression issues with several subassemblies — including Any Angled Shelf Fixed, Angled End Shelf Fixed, Diagonal Angled Shelf Fixed, Angled Shelf Fixed, and Open Corner Shelf Fixed. These issues arose following updates made to the Shelf Fixed subassembly during the implementation of the magic wire options. At that time, prompt information was copied into these additional subassemblies, even though they do not support the magic wire feature.
- Improved Institutional Hinges so they now respond to the “@” symbol (with distance value) in the hinge name. If the symbol is not there, the “Hinge Distance From Side” will be 0.
- Simplified control for Double Division in 3-Door Cabinets. The "Double Mullion" prompt is now the primary control for enabling the double division feature in 3-door cabinets. When selected, it will automatically activate the double division option within the Horizontal Splitter subassembly. Previously, the feature was controlled through the "Double Division" prompt, which was also linked to the “Double Mullion” setting. This setup created confusion, as users had to check both prompts to confirm the feature was turned on.
- The Component Folding Doors subassembly will now draw correctly in 2D Elevation.
- Resolved an issue with the Access Panel subassembly. The "Access Panel Depth" was hidden instead of the "Access Panel Width" when using "Place Left Side" or "Place Right Side". Front to Back should use "Access Panel Depth", Left to Right should use "Access Panel Width", and Bottom to Top should use "Access Panel Height".
- The ability to resize drawer parts with a rebate if they exceed 16mm has been added to other runners such as Blum MOVENTO.
- Resolved an issue with the Titus Tekform Slimline drawer system. “Space Required Under Drawer Bottom” changed from 32mm to 26mm to match manufacturer specs.
- Updated the Harn ALUNAN T and Harn Ritma Cube to include new and accurate bottom drilling as provided by Harn.
- Resolved an issue with Wood Drawer Box subassemblies when using the “Plant On Bottom” feature. Slide holes will now remain in the correct location.
- Improved drawer rear cutout feature so drill machining remains on face 5 only.
- The “Screw Construction” for the Horizontal Splitter subassembly has been updated to accommodate the small part threshold.
- Changes and improvements made to the Internal Drawers With Faces component insert:
- The drawer material is now linked to the OpenID. This ensures that when the insert is placed into a standard cabinet, the drawer fronts will automatically default to the carcass material.
- A new “Filler Material” prompt has been added, providing control over the side filler material directly through prompts.
- In the Finish Faces subassembly, a “Finish_Faces_Layer” prompt has been introduced. This allows the layer assignment to be controlled via prompt values.
- Improvements made to the Drawer Box List Report.
- Resolved an issue with cut size values appearing incorrectly on Part Labels when the processing station Premill Type is set to “Edgeband Thickness”. All labels have been updated to use the Adjusted Cut Part sizes so the size will account for the correct premill value.
- Altered the way Mitered Side Front Edges behave on Corner Diagonal cabinets. When this option is selected, the left and right cabinet depths now reflect the outside edge of the mitered sides. Side widths now include the angular projection.
- Resolved issue in Corner Cabinets involving the rear corner notch. Parts will now avoid face 6 machining for the drill holes.
- Added missing graphics for Olympus 700S locks.
- The prompts in the Project Wizard for “Base_Door”, “Tall_Door”, and “Upper_Door” have been updated to represent a buyout material when ticking the “Buyout_Door” prompt.
- Updated the Chamfer Cabinet Modifications for the left, right, and both sides to work correctly when checking the finished Chamfer Left or Right. This will now work with different thickness sides vs the back.
- The “Edit Part Materials” prompt has been fully removed from all products and subassemblies. This was a legacy prompt that no longer served a meaningful function in the current product structure. Historically, the prompt was used primarily to disable the material prompts, and the thickness prompts would look directly at the material pointer when it was unticked. However, it was inconsistently applied—none of the face frame products utilized it, and most thickness prompts did not reference it. As part of this cleanup:
- All control types and material pointer references still relying on “Edit_Part_Materials” have been updated.
- Thickness prompt formulas were simplified as part of this removal, improving overall clarity and reducing unnecessary dependencies.
- Resolved machining issues and added improvements to the ADA Sink Angled Frame product.
- Angled Route Polylines: Polylines have been updated so that when the corner radius is set to 0, the associated corner radius vector is now fully removed from the route. Previously, a 0-length vector remained, which caused issues during machining or toolpath generation.
- Independent Radius Control: All corner radii in the polyline can now be toggled independently.
- Toe Kick Radius Option: A new prompt has been added to control the internal radius where the bottom of the panel meets the top of the toe kick. This was previously tied to the general corner radius, but now you can adjust it separately for more precise detailing.
- Added new products Master Corner Vertical Designer Cabinet FF & Master Diagonal Vertical Designer Cabinet FF. Along with the new designer products, several subassemblies have been created:
- Component Corner Doors FF
- Component Diagonal Doors FF
- Face Frame Shelves - These shelves have been created as bay splitters behind the face frame mid rails. They act the same as a vertical splitter, with a small difference; they are designed to be placed behind mid rails. With the ability to change the fixed shelf condition behind the rails, with options: No Shelf|Centered|Top|Bottom|Double
- Corner Shelf Fixed FF
- Diagonal Angled Shelf Fixed FF
- You can control the position of the shelf using these conditions:
- No Shelf: Disables the face frame shelf entirely—no splitter is placed.
- Centered: Places the shelf centered directly behind the mid rail.
- Top: Aligns the shelf to the top edge of the mid rail.
- Bottom: Aligns the shelf to the bottom edge of the mid rail.
- Double: Places two shelves—one at the top edge and one at the bottom edge of the mid rail.
- The Diagonal Angled Face Frame, Corner Face Frame, and Diagonal Face Frame have been updated to accommodate the mid rails in the new designer cabinets.
- Improvements made to Component Drawers FF:
- Draw Intermediate Rails: Enables drawing and machining of each intermediate rail. If unchecked, rails are omitted, but drawer spacing remains intact.
- Intermediate Rail Extension Left / Right: Extends the intermediate rail into adjacent bays, allowing alignment or bridging across openings.
- Resolved a Face Frame overlay issue in the Master Split Height Designer Cabinet FF. The Component Drawers subassembly in the first bay had an issue with the “Face_Frame_Right_Overlay”. When using “Face_Frame_Division_Overlay_Control_Stile_1” ="Right", it was not deducting the “Thickness_Division”. All the other bays are correct.
- Resolved an issue with Master Horizontal Designer Cabinet FF. Interior components will now properly follow the correct Face Frame Division Overlay Control for each bay.
- Resolved an issue with the 2D Draw tokens in the Base Corner Cabinet FF. The depth dimension was accounting the “Applied_End_Thickness_Right” value. When used in the face frame products, should just be the depth.
- Updated all FF Drawer Bank Cabinets to have the same drawer calculator order as the frameless cabinets. (Top, Bottom, 2nd, etc.). This order will ensure accuracy should the user change the number of drawers after calculating.
Microvellum Foundation Library Release Notes | Build 25.0523
The following release notes apply to Microvellum Foundation Library build 25.0523.
Additions
- Added a new Master Curved Front Cabinet product.
- Added 282 Titus Hinges and 83 Titus Base Plates.
NOTE: You will need to manually add this hardware brand into Hardware Wizard “Hinge Brand” combo box list if you are updating library.- T-Type 95° Thick Door
- T-Type 110°
- T-Type 110° Pie Cut Corner
- T-Type 110°/15°
- T-Type 110°/30°
- T-Type 110°/45°
- T-Type 110°/90° Blind Corner
- T-Type 120°
- T-Type 170°
- T-Type Mounting Plates
- Added new hinge hardware, the Blum CLIP top 120° hinges.
- Added a new global variable “Include Reveals In Hinge Offset From Edge”. Select this to include the door reveals when calculating the hinge cup offset from the edge of the door for full overlay conditions. Variable is located under the Hardware tab, Hinge Settings.
- Added a new global variable, “Back Capture at FE”. Enable to always have the cabinet backs captured at a Finished End. Disable to prevent the backs from being captured at Finished Ends.
- Added a new option, "Pullout Behind Door", to the “Component Option” prompt.
- When "Pullout" is selected, the face panel behaves like a drawer front—no hinges are applied.
- When "Pullout Behind Door" is selected, the face functions as a standard hinged door.
- The "Horizontal Handles Centered" prompt has been added to all blind corner products. Selecting "Pullout" now automatically applies horizontal handles and centered handles.
- Added the new Component Pullout subassembly insert. This can be used to add a pullout to any opening with a finished face attached.
- “Mullion” prompts are now visible and placed on the Construction Options tab for all 3 door cabinets and blind corner cabinets, as well as the fixed and adjustable shelves. A prompt has been added to control the width of the cutout depth and the clearance: Mullion_Width_Clearance and Mullion_Width.
- Added the “Shelf Qty Left” and “Shelf Qty Right” prompt variables to the Division With Adj Shelves and Division with Fixed Shelves subassemblies. This will make it easier to have different shelf quantities in each opening.
- Added the “Magic Wire” feature to all subassemblies with Fixed Shelves and Divisions. For Divisions, an option was included for continuous holes to be added tops & bottoms.
- Added the new Wire Management hardware: Cabiseal Pestblock (available in Australia). This can be best utilized with the Universal Hardware Insert subassembly.
- Added the Blum Tip-On feature to the Wood Drawer Box & Wood Dovetail Drawer Box subassemblies.
- Added two new hardware wizard prompts to separate the cabinet Screw Fitting pointer from the screws used on a wood drawer box and wood drawer box bottom:
- “Screw Fitting Wood Drawer Box”
- “Screw Fitting Wood Drawer Box Bottom”
- Added A & M ADA Hardware Brackets to the ADA Sink Angled Frame product.
- Added a new global and door variable, "Vertical Rail To Hinge Minimum Offset". This has been added to improve control when the top hinge needs to be offset to accommodate a vertical front rail. Previously, the top hinge offset was calculated as the sum of Vertical_Front_Rail_Width + G!Hinge_Location_Top, which often resulted in an offset not required for some vertically aligned doors. This has been refined—now the hinge is offset only by Vertical_Front_Rail_Width + Vertical_Rail_To_Hinge_Minimum_Offset, providing a more accurate adjustment.
- Added new options to the Suspension Brackets subassembly. The left and right suspension brackets can now be independently toggled on or off.
- The Wall Rail product has been updated to support different profiles and multiple length calculations:
- The rail part now references a lookup table to apply the appropriate DWG profile dynamically.
- A thickness column has been added to the lookup table to apply the correct thickness of the profile.
- The calculation logic for wall rail lengths has been improved to dynamically determine the required quantity and sizing based on the product width and available profile stock lengths.
- Added the “Plan Width Base Point” prompt to all relevant products and linked to the global variable. This allows local control at the cabinet level to position the 2D plan width dimension None, Back, or Front.
- Added two new door summary and fabrication reports that sorts by the subassembly and door style, showing total quantities:
- Door And Drawer Front Summary Report
- Door And Drawer Front Fabrication Report Style 2
- Added new set of global prompts to provide greater control over which doors receive a lock in a double-door cabinet:
- “Lock Side Double Door Base”
- “Lock Side Double Door Upper”
- “Lock Side Double Door Tall”
- The below global variables have been moved to the “Legacy” tab due to no longer being used:
- “Lock Left Door Base”
- “Lock Left Door Tall”
- “Lock Left Door Upper”
- When “Both Doors” is selected for “Lock Side Double Door Base”, the lock position will automatically change to "Lock To Top". For “Lock Side Double Door Upper”, the lock position will automatically change to "Lock To Bottom". For “Lock Side Double Door Tall”, it will stay looking at the global “Lock Tall Location”. For all options, the Lock Location can still be manually changed in the door subassembly.
- Updated the Under Panel product. Strip light parts have been removed and replaced with the Undermount Strip Lighting Insert subassembly, which has more features and is easier to maintain.
- Resolved an issue with Fillers in suspended cabinets.
- Resolved an issue with right hand Return Fillers option.
- Resolved issues with Component Drawers subassembly. Using “Add Top Facia” will now function properly and the drawer stretcher for the facia will now be placed in the correct X location.
- Cabinet Connector Holes will no longer automatically appear on cabinet sides with a filler.
- Resolved a route priority machining issue with the Blum Aventos HKi lift-up hardware.
- Updates have been applied to all shipping DWT template files. Outdated font types have been removed.
- Updated the Hinge BLUM 170deg Full Overlay Knock-In hardware to include machine tokens for machining.
- Updated the Fixed Shelves w Dividers subassembly to include the proper number of dividers with 10 fixed shelves.
- Several reported issues with the Blum SPACE STEP toe-kick drawer subassembly.
- Updated the Wood Drawer Box & Wood Dovetail Drawer Box so all “File Drawer” prompts are now visible and more accurate. Added File Bar Clip graphics. Added a prompt to activate the machined slot.
- Resolved an issue with Farmhouse Sink Single Bowl type. Sides will now be the same thickness.
- Resolved an issue with the Mitered Shelf product. When using the global “Miter on CNC” option, routes will now be the full depth of the part instead of the miterfold depth.
- All system drawer subassemblies have been updated to work with the reduced back and bottom rebates (routes) when using materials thicker than 16mm. Many internal formulas have been reformatted for better consistency and accuracy involving the drawer backs and their 3D positioning.
- Resolved issues with the Wood Dovetail Drawer Box when using the Rear Cutout feature.
- Resolved an issue with the Fixed Panel option in Master Horizontal cabinets.
- Resolved the missing graphics for the Titus Tekform Slimline when used as an inner drawer.
- The LEGRABOX Kit has been removed from the hardware list of the Gollinuci Evo 580 bin subassembly.
- Drawer subassemblies’ prompts “Bottom Fixing Screw Type” and “Back Fixing Screw Type” now point to H!Default_Drawer_Wood_Screw instead of H!Default_Drawer_System_Screw.
- The following hardware wizard variables have been moved from the “Additional Hardware” tab to the “Drawers” tab:*
- "Dowel Fitting Wood Drawers"
- "Default Drawer System Screw"
- "Default Drawer Wood Screw"
- "Hardware Edge Array Wood Drawers"
- Resolved an issue in the MV Profile Door subassembly. The “Panel Insert Clearance” prompt will now correctly reference D!Panel_Insert_Clearance.
- Resolved an issue with Solid Wood Doors when using Glass Lites openings. Mullion parts will now have the correct Y origin location when door is a nested subassembly.
- Resolved an issue in the 2D Instructions subassembly that caused issues with the 2D plan view showing “FE” text when it shouldn’t.
- Resolved an issue with Top Scribe/Filler Panels on cabinets not correctly perfect grain matching.
- Resolved an issue with right hinge plates on Angled End Cabinet and Transition Cabinets using “Angle Right”. Plates will now properly associate to the right sides.
Additions/Resolutions Closet/Wardrobe Expansion
- Resolved machining issues with the Kessebohmer Conero Clothes Lift TOP and Kessebohmer Conero Clothes Lift subassemblies.
- Hanging Notch and Wall Hanger options have been integrated across all closet products for improved installation flexibility and configurability.
- Closet Carcase and Corner Closet Carcase subassemblies have been updated to include hanging notch features.
- The Suspension Brackets subassembly is now nested within to support wall hanger hardware.
- The following global variables have been introduced to manage these enhancements:
- G!Closet_Hanger_Notch_Type – Selects the type of hanging notch required to create a notch at the back of a closets, allowing a hanging cleat to run through. None, Standard, or French Cleat
- G!Closet_Hanger_Notch_Distance_From_Top – Sets the vertical position of the notch from the top.
- G!Closet_Hanger_Notch_Width – Controls the width of the hanging notch.
- G!Closet_Hanger_Notch_Depth – Controls the depth of the hanging notch.
- G!Closet_Add_Wall_Hangers – Toggles the inclusion of suspension brackets.
- A new Closet category has been added to globals: Closet Hanger Notch Settings.
- Created a Closet Wall Cleat product and included it a new closet expansion category: Closet Accessories.
- Updated the hanging notch tokens in closet products to accommodate a French Cleat cutout option.
- Resolved an issue with “Separate Bead” option when used with the global “Face Frame Extend Bottom Rail to Floor”.
- Resolved an issue with the global "Face Frame Miter FE Joint” when used in conjunction with cabinet Applied End feature.
- Resolved a major issue with Master Upper Split Height Designer Cabinet FF that was caused from a typo inside a formula.
- Resolved an issue with Transition Angle Cabinet FF when side condition is set to Face Frame. Applied FF panels will now miter correctly and respond to "G!Face_Frame_Miter_FE_Joint".
Modifications/Resolutions Staircase Expansion
- Made several changes to enable 3D visualization of the nosing radius for imperial:
- Added global LookUpTable: LookupTableStaircaseNosing
- The Global Prompt “Staircase_Nosing_Radius” is now linked to the lookup table for the available radii and has been changed to a dropdown list.
- Nosing on the treads have been changed from a Profile token to a polyline token. The polyline will now look at the lookup table for the tool to be used and if it’s to be machined or drawing only.
- The Global "Staircase_Stringer_Finish_Tool" prompt is now linked to the lookup table. This is the route that is used for the finish cut on the stringer notching rebate.
Microvellum Foundation Library Release Notes | Build 25.0418
The following release notes apply to Microvellum Foundation Library build 25.0418.
Additions
- Added a new Cost Based Estimating Report, “Shop Quote Optimized Option”. Instead of using the square footage plus waste, this will use the actual optimized sheet quantity.
- Added the new Magic Wire Removable Shelf System for the Shelf Adj Component Insert:
- Added new global variable “Use Magic Wire”.
- Lookup Table added to the Hardware file LookUpTableMagicWire.
- Also added to the Angled Shelf Adj subassembly.
- Hardware Materials added:
- Magic Wire 257
- Magic Wire 320
- Magic Wire 128
- Magic Wire 160
- Magic Wire 197
- Added the ability to perfect grain match the raised and flat panels within the Solid Wood Door door type.
- Added a new global variable and prompt to the Shelf ADJ subassembly, "Shelf Hole Min Depth Back Notch". This will add shelf supports to the notched panel when the Adjusted_Depth_Back_Right>Shelf_Hole_Min_Depth_Back_Notch for the right notch and vice versa for the left notch. This was achieved by adding an additional shelf token with an offset in parameter 8, which is the width of the notch. In the original SHELF token, the rear hole placement has been increased to fall off the panel (Depth+M2U(50,G!Accuracy).
- Added the ability for users to create their own uniquely named custom toe kick subassemblies and still have associated prompts displayed correctly. Formulas will now be written to check for one of the following text strings (below) to be included in the custom subassembly name:
- “Notched Toe Kick”
- “Adjustable Legs”
- “Toe Kick Assembly Box”
- “Toe Kick Drawer”
- Added additional global variables (below) for more control over the Invisible Fasteners construction method:
- “Invisible Fastener Pline Bulge List” - Linked to Column 14 of H!LookUpTableInvisibleFasteners.
- “Invisible Fastener Vector Feed Speeds” - Linked to Column 15 of H!LookUpTableInvisibleFasteners.
- “Invisible Fastener Pline Options” - Linked to Column 16 of H!LookUpTableInvisibleFasteners.
- “Invisible Fastener Tool Compensation” - Linked to Column 20 of H!LookUpTableInvisibleFasteners.
- Added the ability to have up to six hinges for the Component Folding Doors subassembly.
- Added 2D cross section tokens for Countertop product’s depth and thickness.
- ADA Sink Angled Frame – Refactored the entire product:
- Simplified the product prompt options.
- Added a “Use ADA Default Settings” check box.
- Added product prompt help images for the ADA options.
- Renamed certain ADA prompt names for better clarity.
- Resolved issue with the machining & edgebanding for the sides.
- Added additional material prompts for greater control:
- “Toe Kick Material”
- “Sub Front Material”
- “Apron Material”
- “Bottom Material”
- “Top Material”
- Added three new global variables to allow greater control over screw, dowel, and cam spacing at corner cabinets & corner closet products. When checked, these options calculate the custom spacing for the top and bottom panels of corner (pie-cut) cabinets from the front edge rather than the machine origin at the back:
- “Screw Corner Custom Spacing From Front”
- “Dowel Corner Custom Spacing From Front”
- “Cam Corner Custom Spacing From Front”
- Added the G2 Runner option to the Hafele Matrix Slim drawer system.
- Added two new global variables to provide an option to offset to the hinge placement on one side of a shared division panel when doors are mounted on both sides. It helps avoid hardware interference by shifting the hinge position slightly:
- “Hinge At Division Control” (None|Left Side|Right Side)
- “Hinge At Division Offset”
- Added two new prompt variables to Blind Corner cabinets to control the amount the shadow line is extended into the blind panel. If set at 0 then no notch will be added to the blind panel:
- “Shadow Line Extension Left”
- “Shadow Line Extension Right”
- Added new drawer system Titus Vitek.
- 25kg, 35kg White.
- Heights 79mm, 114mm, 150mm.
- Runner Lengths 250, 300, 350, 400, 450, 500, 550 mm.
- Added hidden elevation lines for all wood drawer box & system drawer subassemblies. Added global variable “Elevation Hidden Drawer Lines" to turn on or off the drawer box hidden lines.
- All DWG graphics files have been purged of extra annotative scales and saved in the 2018 AutoCAD version. This was done to prevent the extra scales from being reintroduced into an active drawing when products are added. *
- Resolved a machining issue with Hettich Intermat 9935 95° Special Thick Door hinges.
- Made some detailed changes to the Rocheleau R13 drawer based on user feedback.
- Resolved the issue with “Construction Method Thick Back” not matching the machining inside the Cabinet Modification Split Back subassembly. Also updated the “Use Dado” prompts to match that of the product.
- Resolved an issue with adjustable shelf hole rows not responding to the rear notched cabinet side when the notch depth exceeds the "Shelf_Hole_Min_Depth_Back_Notch" value.
- Resolved several issues with Corner Filler With Cleats product.
- Resolved a drawer prompt issue inside Component Drawers subassembly. Now, “Top Drawer Slide Selection” will only appear when there is a top drawer.
- Resolved a regression issue with the “J Pull” handle option. Feature has been restored.
- Resolved a regression issue with Upper Cabinets with bottom valance, scribe filler, and overlay bottom. Sides will now be the correct size.
- Updated the Sink subassembly. “Cutout Corner Radius” and “Substrate Cutout Offset” prompts will now be visible. Also now allows entering a negative value for “Cutout Gap”.
- Resolved an issue in Base 1 Drawer Microwave cabinet. "Top Reveal" prompt will now control the top reveal of the drawer front.
- Resolved machining issues with certain Blum Aventos HK-Top lift-up hardware. Drilling will now be on correct door face when using thinner material.
- Updated the Blum SPACE STEP:
- Will now align the kick face to have the same setback as adjacent standard kick faces.
- Changed the 3D cad layer to use the “3D_KICK” layer.
- Resolved issue with inside height calculation.
- Resolved an issue with the Farmhouse Sink subassembly. Selecting the “Single Bowl” option will now draw correctly in 3D.
- Modified the behavior of screw, dowel, and cam locations for custom spacing on divisions and fixed shelves. The placement of the holes will now match the cabinet tops & bottoms. This adjustment ensures that the part width lookup aligns with the cabinet top's width when using a captured back construction method.
- Resolved drilling location issue for the Hinge BLUM Bi-Fold 60Deg Knock-In hinge.
- Resolved misspelled global variable “Connecting Hole Max Sapcing”. Now “Connecting Hole Max Spacing”.
- Resolved error inside “Inset Door Reveal” prompt within the Solid Wood Door subassembly.
- Resolved issue with Dishwasher & Fridge appliance products with applied panels. They were missing “Product Type” prompt which prevented them from processing correctly. Also moved the “Add Item Number” prompt to the main tab. This will need to be checked to process the product.
- Resolved issue with “Door Style” prompt not appearing in the Door and Drawer Front report. The prompt is also now a control type 5 combo box to make it easier to add new door style options in the future.
- Renamed the product Integrated Dishwasher (corrected spelling) and resolved issue with the handle not centering horizontally.
- Updated the Face Frame subassembly elevation drawing to show the horizontal rails. Using overlay doors will put them on the FACEFRAME-H layer.
- Resolved hardware association issue with Blum Aventos HF lift-up system.
- Addressed issue with the drop-down door hinges. In the LookUpTableDropDownSystems, we’ve set the “Center Hinge Hardware Name” (Column 15) and the “Center Hinge Plate Hardware Name” (Column 16) to 0. This configuration ensures the system uses the default hinge and hinge plate specified in the hardware prompts. If no hinge or hinge plate is required, you can set these columns to "None" to omit them from the hardware selection.
Additions/Resolutions Office Furniture Expansion
- Resolved issue with worktops and their “Add Scallop Cutout” feature. The edgeband thickness has been added as an offset to the virtual route. We have also added a draw only route without the offset so it will draw correctly in 3D.
- Added "Library Version" prompt to all staircase products and subassemblies.
- Resolved a positioning issue of the bullnose steps for C-shaped and U-shaped stairs.
- Resolved a wedge routing issue on the qtr platforms.
- Resolved issues with Cut Stringer and Box Stringer options.
- Handrails will now appear when selected.
- Added missing global variables to the Library Update:
- “Keyway Large Radius”
- “Keyway Small Radius”
- “Keyway Tolerance”
- “Double Keyway Large Radius”
- “Double Keyway Small Radius”
- “Double Keyway Tolerance”
- “Double Keyway Distance Between Keyways”
* Not included in Library Update, only in the full install.
Microvellum Foundation Library Release Notes | Build 25.0319
The following release notes apply to Microvellum Foundation Library build 25.0319.
This update introduces many new global variables. Any existing projects will naturally not contain these new variables, causing issues when adding new products to these projects. Because of this, Microvellum recommends doing one of three options:
- Finish out all projects before updating to this library version
- Update library, then revert the global file within each active project. You will need to redo any previously made global settings.
- Update library, then identify and add all the newly added global variables from the template to your custom project global file. (advanced)
Additions
- Added the ability to control the language of most all product part name strings.
- Currently supports English, French, Spanish.
- Added a new Lookup Table to the Factory workbook, “LookupTablePartNames”.
- Added a new Global Variable, “Region Language”.
- This setting can also be used to abbreviate or change the English name/phrase of all product parts.
After updating your library to this build, you will need to revert the Global File within any existing project using the previous version. Or alternatively, one can manually add the “Region Language” variable to avoid errors in part names.
- Added 18 new global variables for greater control over default cabinet top & bottom conditions:
- “Base Overlay Top”
- “Base Full Top”
- “Base Rails”
- “Base Overlay Bottom”
- “Base Full Bottom”
- “Base No Bottom”
- “Tall Overlay Top”
- “Tall Full Top”
- “Tall Rails”
- “Tall Overlay Bottom”
- “Tall Full Bottom”
- “Tall No Bottom”
- “Upper Overlay Top”
- “Upper Full Top”
- “Upper Rails”
- “Upper Overlay Bottom”
- “Upper Full Bottom”
- “Upper No Bottom”
- Added additional functionality to the Master Horizontal Designer Cabinet.
- An option is now available to turn on a bottom drawer for each bay in the local product. This still uses the Component Door-Drawer subassembly but removes the need to turn it on through the subassembly.
- An option is now available to have a top fascia in each bay of the product. It is recommended to turn on the fascia through the product rather than the Component Door-Drawer subassembly.
- Features have been added to the Solid Wood Door subassembly:
- Options are now available to have up to 5 center panels horizontally and 5 panels vertically.
- Users can now select between Full Length Rails or Full Length Stiles.
- Two new options have been added to assist with Applied FE multi panel conditions where adjacent cabinets bump up to the applied panel.
- Simple Panel Calculation – When selected, users can enter the height/depth of adjacent Base & Upper cabinets. Panel sizes and locations will automatically adjust to accommodate.
- Custom Panel Calculation – When selected, users can specify quantity of Stiles and Rails to add. Prompts allow one to enter each Style & Rail position.
- Doors with Lite Qty added to them will now display in 2D elevation. Also resolved positioning issues with the 3D glass parts.
- Added the global variable “Hinge Half Overlay Threshold”. This is used to control the point at which a hinge is considered half overlay instead of full overlay.
- Added two new Wall Hanger options: Hafele US Wall Hangar 290.02.715 (LH) & 290.02.714 (RH). Also added a new Wall Rail product.
- Added a Drawer option to Sink Cabinets.
- Added enhancements/changes to the Connecting Holes feature:
- Added a new global variable "Connecting Hole Max Spacing" and linked to all connecting hole machine tokens (Distance Between Holes). This will enable more than two holes in height per column of holes.
- Added a new global variable, "G!Connecting_Hole_Condition", with options to set it to left or right sides, both, or none.
- Global variable “G!Cabinet_Connecting_Holes” is no longer used.
- Added an option to have connecting holes on the scribe filler subassembly.
- Added a new global variable “Dado_Depth_At_Division”, which allows a different dado depth for fixed shelves when intersecting divisions. Also added subassembly prompts “Dado Depth Left” and “Dado Depth Right” at the relevant conditions.
- Added 2 new Undermount drawer runners DTC D-Motion (No Graphics)
- DS10 Soft-Close
- DS80 Soft-Close
- Added a new drawer system, the DTC Magic Star Plus, with the following specifications:
- 40kg Black/White
- Heights C, F, K, M
- Runner Lengths 270, 350, 400, 450, 500, 550 mm
- Added a new drawer system, the Enko Ecobox (NZ) (No graphics) with the following specifications:
- 30kg White
- Heights 80, 120, 150
- Runner lengths 350mm, 500mm
- Added a new drawer system, the Grasshopper Cobox (UK) (No graphics) with the following specifications:
- 30kg Mocca
- Heights 80, 150
- Runner lengths 270mm, 300mm, 350mm, 400mm, 450mm, 500mm, 550mm
- Added a new drawer system, the Artia Topaz Slimline (AU/NZ) (No graphics) with the following specifications:
- 40kg Dark Grey/White
- Heights 86, 118, 167, 199
- Runner lengths 270, 300, 350, 400, 450, 500, 550 mm
- Added a new waste bin option, the Titus Kosara Bin (No graphics).
- Added a new global variable “Front Adjuster Condition” with four options: None|Drawer Fronts|False Fronts|Both
- Use Adjusters will only turn on in the False Front if it is a bay position of 82 (False Front).
- Added the "Drawer_Front_Adjuster" prompt to hardware wizard to select the desired hardware.
- Added hardware and options to the Finished Face Subassembly.
- Added a 3D_Drawer Front Adjuster.dwg to Graphics/Hardware.
- Resolved an issue with Simple Face Frame. Left/Right stiles will no longer extend to the floor unless the toe kick notch is turned off.
- Resolved an issue with Countertop products involving the edgebanding option. Correct edges will now have edgebanding.
- Resolved an issue with left/right Applied 5 pc panels incorrectly showing in 2D elevation.
- Resolved an issue with hinge plate positions at corner doors. They will now all reference the “@36mm” at the end of the hardware name.
- Resolved an issue causing incorrect material pointer association for “Upper Blind Panel”.
The issue above cannot be with a library update but is resolved upon installing the build. It is recommended to manually correct this prior to updating if you have a previous library version.
- Resolved multiple issues with Master Horizontal Designer Cabinet:
- An issue with the top facia being out in the Z origin and having no gap between the facia and the doors has been resolved.
- Fixed the issue with the Drawer Stretcher being out of alignment in the X origin.
- Fixed issue with door half overlay condition that would sometimes be full overlay.
- Resolved an issue with Base 7 Drawer. The Z origin for the sixth drawer box will now be correct.
- Resolved a regression issue with the Solid Wood Door subassembly. Value cells on the Prompts worksheet were incorrectly shifted by one row, causing problems with the calculation of hidden prompts.
- The default construction method for Filler Cleats no longer pointing to "G!Default_Construction_Method_FE". The method is now set to “Dado” by default, and can be controlled in the subassembly.
- Resolved an issue with MV Profile Door where sometimes extra routes incorrectly appeared off the panel.
- Formula changes have been applied throughout all products in the library where the use of “ProductCode” special MV system function has been replaced with “Product_Type” instead. This simplifies many aspects of its use and allows the user to change the Interface Language inside the MV options.
- Improvements and corrections made to Corner Fillers within Blind Corner cabinets.
- Added prompts to control the Corner Filler type, "Corner_Filler_Type" and "Corner_Filler_Style".
- Fixed an issue with the prompt value for the Blind Facia looking at "Blind_Panel_Type" instead of "Blind_Panel_Style".
- Both "Blind_Panel_Style" and "Corner_Filler_Style" will default to "Plank" when selecting a Generic Five Piece.
- Fixed an issue in the Generic Five Piece subassembly where the edge profiles were not linked to the outside profile prompts so you could not turn off individual edges.
- Resolved an issue with hanger notches when used at finished ends with scribe. Notch depth will now include the scribe distance.
- Resolved an issue where sometimes the "Drawer Front Height" calculator would sometimes be missing certain drawer fronts.
- Added missing drawer lengths 550mm and 600mm for King Slide 3M52 (Wood drawer Slide).
- Added missing drawing blocks for certain LEGRABOX lengths.
- Resolved an issue with the KD hardware ("G!Use KD At Bench Back") feature. Hardware will now be centered in the cabinet opening.
- Updated Blind Corner cabinets when used with Shadowline rails. Notch machining in Stretcher will now align with Shadowline Rail.
- Resolved an issue with ViewBase cross section when sinks are undermounted.
- Resolved an issue with all Scribe Filler products and Scribe Filler With Cleats so that they work correctly when the fillers are less than the "Minimum_Filler_Width". This involved changing Base Points, Machine Point, and X Origins of parts when changing from a left to right filler.
- Resolved an issue with the Extruded Countertop products where control of size and position of the elbow joint was not possible when the left & right segments were different. Also, the substrate has been added to the Elbow subassembly.
- Resolved an issue with the Bay Opening Calculator in Master Office Horizontal Open Designer Cabinet.
- Resolved an issue with Master Split Cabinet when used with a Cabinet Modification Option Notch Left/Right and a Double Center Shelf. The double center shelf will now contain the appropriate cuts and the back will be split in two.
- When cabinets reach a certain depth, and parts with Dado construction reach the "G!Dado_Small_Part_Threshold" value, they will now look to the "G!Dado_Small_Part_Notch_Distance_To_Edge" instead of always using "G!Dado_Notch_Distance_to_Edge".
- For the Box End and other similar products, we have added a prompt “Machine Miters” under the construction tab. This will activate the PLINE token with actual machining instead of “draw only” miters.
- Resolved an issue with Profile Handle option “Splay” when used on a lift up or drop down door.
- Resolved duplicate prompts inside the Divisions subassembly.
- Resolved an issue with drawer stretchers inside Door-Drawer cabinets. Added “Drawer Stretcher Offset” prompt.
- Resolved a regression issue with J Pull Handle and "Splay" profiles on doors not appearing on the correct edge.
- Resolved an issue with Tab Pulls displaying incorrectly in 2D elevations.
- Updated machining for Lamello Cabineo hardware. Increased the edge overhang to 5mm.
- Resolved an issue with dwg graphics for the Harn Alunan drawer system, T height, 400mm depth. Updated 6 dwg graphics.
- Drawer System Hettich AvanTech now has “Cut to Length Wood Back” set as default.
- Resolved an issue with Master Split Corner Cabinet when using Applied Ends with the global variable “Include Applied Ends in Cabinet Width”. Right hand swing door will now be correctly positioned.
- Updated the 3D Graphics for Kessebohmer BLIND CORNER LeMans II with significantly smaller file sizes (500 MB to 32 MB), improving Toolbox performance. Also resolved hole drilling location issue.
- All handle/pull hardware will now point their drilling diameter to the global variable “G!Handle_Hole_Diameter” instead of hard locked “5 mm”.
- “Toe Kick Height” prompt is now hidden in Upper Corner Cabinets.
- Made improvements & corrections to the HAWA Concepta III:
- Hinge machining now follows the global “G!Hinge_cup_machining”.
- Resolved the panel drilling and incorrect 5mm holes to be 3mm.
- The End Stop Bracket now has a prompt value to set its distance in the "Hardware" Tab. This allows the user to adjust the depth from the front of the cabinet.
- Added a prompt under Face Options to allow the user to turn off straightener routes and hardware if desired.
- Added Bi-Fold door options including related extra hardware & 3D graphics.
- Added a new global variable, “Face Frame At FE Use Default Side Overlay” to control whether you want the side overlays to adhere to the default global or to default to the product option and default to outside overlay when using finished ends or applied ends.
- Resolved issue when using concealed Frameless hinges plates at Face Frame conditions.
- Improved 2D draw tokens for Mid Stile parts.
Microvellum Foundation Library Release Notes | Build 25.0124
The following release notes apply to Microvellum Foundation Library build 25.0124.
Additions
- Added Century Components Waste Bins, Vanity Organizers, and Base Cabinet Organizers.
- 11”, 14”, 17” Signature Series Bottom Mount 34qt & 50qt.
- 4”, 5”, 6”, 9”, 12” Cascade Series Base Cabinet Organizers.
- 9”, 10.5” Vanity Grooming Organizers.
- Added Rev-a-Shelf Tip Out Tray option for Top Facia (False Front) conditions. Includes 42 new material variations with 3D graphics, codes, and pricing. Currently this is facilitated as a drawer type option.
- Added Nikpol Teramo Bins for AU/NZ regions.
- Added a new cabinet modification option, “Cabinet Split Back”. Features include:
- Split Height/Split Width.
- Regular Backs and Thick Backs.
- Split Nailer option.
- Center Distance to Center variable.
- Variable to set a distance between the backs.
- Added Top Filler options to all Corner cabinets. Options include Top Scribe Filler|Top Scribe Return Filler|Top Soffit. Subassemblies have been added for all options. Also added the framework for the Soffits as a nested subassembly.
- Added a new global variable, "Add Elevation Depth Label" and linked it to the 2D Instruction subassemblies.
- Added a new global variable, “Add Drilling For Wrapped Battens” and linked it to the construction holes in all products.
- Added "Add Top Facia" or False Front option to each bay of Horizontal Designer cabinets.
- Added the Force Grain Direction prompt variables to Soffit product and subassembly.
- Added Component Pocket Doors to all the internal options prompt list “Component Insert”.
- Added "Vertical Front Rail Setback" as a global feature and linked it to the origin of the front rail in all relevant products. This can be especially helpful when using 3mm edgebanding when the need arises to set the rail in from the face.
- Added "Vertical Front Rail" as a global feature and linked it to the local prompt in all relevant products.
- Added the ability to globally edit part names of drawer system bottoms and backs.
- Added 2D elevation & section dwg representations for Institutional Hinges.
- Added additional drawer heights for DTC Dragon Pro (209mm & 238mm).
- Resolved an issue with Extruded Die Wall products. Curved Outside/Inside Stacked Skin option will now calculate the correct size & position when using more than one skin.
- Valance Prompt Options will now appear for Tall and Base cabinets.
- Resolved an issue in Strip Lighting Insert that sometimes affected the groove nest machining location in Metric configurations.
- Resolved an issue with Shadow Rail feature when used in Horizontal Designer cabinet with a Vertical Front Rail. The top-notch for the Vertical Front Rail will now include the depth of the Shadow Rail. Additionally, the shadow rail notch will be turned off if the "Vertical Rail Width" exceeds the height of the Shadow Rail.
- Upper Microwave Cabinets will now follow the same rules when determining the material pointer for the cabinet bottom (referencing “Bottom Finished” option).
- Updated a formula inside the Cost Based Estimating Report to match the Shop Quote report.
- Resolved an issue with Glass Door option, when selected inside a Finished Face when it’s a Liftup Door. X Location of glass will now be correct.
- Resolved an issue in Component Doors subassembly where the Door Stay Left & Right prompts were incorrectly hidden from view.
- When using Division With Adj/Fixed Shelves Component Insert, the wide span material trigger will no longer automatically be applied to these shelves.
- Resolved several issues with the ADA Sink Angled Frame product.
- Resolved an issue with certain hinge plates where formulas were incorrectly pulling the “mm” custom setback value from the hardware name. The new formula will only pull the custom setback distance when the “@” symbol is used. For example: Hinge Plate BLUM Straight 0mm Knock-In@36mm.
- Resolved issues occurring when using both the Top Filler and Top Valance features. Cleat and Filler will follow the location of the cabinet top.
- Resolved several reported issues with the Blum REVEGO system.
- Resolved an issue with Hawa Concepta III product. Left hand door hinge bore location has been corrected.
- Updated the Richelieu Axial drawer system. Graphic now includes the rear brackets.
- Added the missing “Blum Tandem Plus 563F 100lb” to the list of Wood Drawer Slide options.
- Resolved an incorrectly rendered help image for Upper 2 Door Microwave.
- Titus Tekform Slimline drawer system Easy-Fix hole diameter is now 8mm instead of 10mm.
- Resolved an issue with the Global Variable workbook that causes most variables to display the incorrect help image (Cells shifted). This has been resolved in the new library install but cannot be corrected by the update utility. Contact support for assistance with getting this resolved (30 seconds to correct).
- Added missing graphics for the Lock Olympus N Series Deadbolt Horizontal and Lock Olympus R Series Deadbolt Horizontal. Also added these to the Hardware inventory with machining tokens.
- Added missing graphics for the Blum Tandem Plus 563F 100lb drawer runners.
- Resolved an issue when using Left/Right Side Full Height sides and Top Fillers.
- Resolved issues with ADA Sink Angled Frame product:
- Removed incorrect edge banding and added EDGEBAND token to sides with irregular shape to properly account for the banding.
- Broke the POLYLINE routes into two tokens, one for machining and one for 3D representation.
- Resolved a material issue in Shelves with Shelf Std product. Changing to “Unfinished Materials” will now point the material to “unfinished” material pointers.
- Changes to L/R Scribe Filler parts:
- Renamed from “Filler Return” to “Filler Panel”.
- Remove left and right edge banding when Filler Panel is not flush with face of door.
- Added edge band material pointers Base_Filler_Edge, Tall_Filler_Edge, Upper_Filler_Edge.
- Material pointers linked to all filler products and subassemblies.
- Users will need to specify desired edge band material after update (Default will be None).
- Default Construction Method set to “Dado” instead of “G!Default_Construction_Method_FE”.
- Resolved issue with Base 2 Door 2 Drawer FF where the intermediate FF drawer stile and drawer being incorrectly positioned when changing the right-hand FF stile. We have also fixed the problem with the drawer stile not showing in the Flat Shot drawings. This was due to a filter on the token filtering out anything with the name “Drawer”. We have changed the name of the part to "Top Mid Stile" from "Top Drawer Mid Style".
- Resolved an issue with haunched frame machining when using Left/Right Front Corner choices.
- Resolved an issue with Transition and Diagonal FF cabinets. Haunched cutouts will now machine on top & bottom rails for mid stiles.
- Resolved an issue with Blind Corner Tall FF cabinets. Handles will now be in the correct location at Right Blind with Right Swing.
- The toe kick notches for both the left and right sides have been updated to take int account the "G!Face_Frame_Dado_Depth" when selecting Dado "G!Face_Frame_Attachment_Method_Sides".
- Added Drawer Divisions to all Double Top Drawer conditions.
- All references to “Extend_Sides_to_Floor” have been removed from machine tokens.
Additions/Resolutions Staircase Expansion
- Added a new global variable, “Staircase Cranked Winders” for cranked stringers around the winders.
- Added "Split Flight" feature.
Year of 2024
This section lists all of the Foundation Library builds that released in the year of 2024.
Microvellum Foundation Library Release Notes | Build 24.1127
The following release notes apply to Microvellum Foundation Library build 24.1127.
Additions
- Added a new Soffit product to the Upper Cabinet Accessories category.
- Added the Top Filler (Ceiling Scribe) option to Upper and Tall cabinets. (Corner Cabinets will be available in the future)
- Added the Blum AVENTOS HF top, HS top, and HL top lift-up systems.
- Added the Hafele Free Flap 1.7 and 3.15 lift-up systems.
- Added the Salice 120 deg hinges Series 200.
- Added four Salice Futura Drawer Slides:
- Salice Futura Smove 7555
- Salice Futura Smove 7955
- Salice Futura Push 7557
- Salice Futura Self-Closing 755
- For MDF Profile Doors with Lites, it is now possible to add up to 3 routes for the glass rebate. This can be achieved by adding a pipe delimited list in the Glass Rebate Tool Name (COL60) and the Glass Rebate Offset (COL62).
- Added a handle to the Integrated Dishwasher product.
- Added the Gollinucci 571 Metal Line and Gollinucci 580 Evo Line bins (Metric only).
Modifications
- Changed the machine point for the Finished Face right door. Now have 3M for the left door and 1 for the right door to better accommodate P2P machines.
- Changing the quantity of drawers in Drawer Bank cabinets will now rename the product to match.
- Adjustable Shelf Standards now using the global “Shelf Standard Tool” instead of “Small Pocket Tool”.
- Removed the global variables “Lock From Bottom Upper” and "Lock From Top Base” as they are no longer used.
Resolutions General
- Resolved an issue with shaped shelf and rear modification notch machining not being on the same face as the adj shelf slot machining.
- Resolved an issue with adj shelf slot machining not aligning with shelf studs when using a shaped shelf L/R.
- Resolved a machining issue with the Blum Aventos HK Top Chipboard. Holes for the front should now be located correctly.
- Resolved an issue with the Toe Kick Assembly Box. Left sleeper will now be in correct location when adding a left cabinet filler.
- Resolved an issue with the 2D Elevation Oblique view of Solid Wood 5pc Doors.
- Resolved an issue with the Vertical Splitter subassembly. The Shelf Edge Face Mounted Lip Down feature should now function as expected.
- Resolved two issues within Base Spacer Corner Drawers products:
- Changing to “M” drawer height will now provide the correct drilling locations.
- Added the missing “Add Lock Second Drawer Front” prompt.
- Resolved an issue with Transition Angle Cabinets. Tops and Bottoms will now be flush with end panels and automatically adjust to the correct cut size when using thick edgebanding.
- Added a 2D elevation token for the Aluminum Handle option. This token should appear for both top mount and face mounted handles.
- Resolved an issue with Base 1 Door Sink w/ False Front that would occur when using the Fixed Panel option.
- Resolved an issue with the Blum Tandembox Antaro. Back drilling should now correctly adjust when changing the bottom thickness.
- Resolved a machining issue with Master Angled Ends Cabinet.
- Resolved an issue with Nailer machining. Setting to “None” will now prevent dowels from appearing at Finished Ends.
- Resolved an issue with the Rear Modification options of Horizontal Designer Cabinets. Notches should now only affect the parts in each appropriate bay.
- Resolved a dimensioning issue with Face Frame drawing tokens when used with Horizontal Designer Cabinets.
- Resolved an issue when using frameless hinge plates in a face frame cabinet. The global “Hinge Plate Offset From Front” will be referenced when the plate hardware item is not using the “@” symbol.
Microvellum Foundation Library Release Notes | Build 24.1025
The following release notes apply to Microvellum Foundation Library build 24.1025.
Additions
- Added new global variable “Remove Stop Dado On Bottom Edge” for wood drawer boxes. Check this option to run the dado through at the bottom of the sub front and back. This is recommended when the sub parts sit on top of the bottom panel and are too small for a stop dado at both the top and bottom.
- Added features to the Strip Lighting insert.
- The light moves and rotates with sloped shelf angle.
- Added an option for wire cutouts in side panels, end hole route, and wiring grooves to wall for wire.
- Added the Light Valance option.
- Added Hafele 833.72.840 Surface Mounted and Hafele 833.72.840 Recessed.
- Added features to the MDF Profile Doors.
- For grooved panels, added an option to make the grooves equally spaced.
- Added columns to the Lookup Tables to control routes you want to follow the corner routes. If the offset is greater than the radius, it will be square.
- Added new Panel Insert option. Added 6 new columns to D!LookUpTableInternalProfile to control panel insert. Added a material pointer MDF Door Panel Insert.
- Added new global variable “Construction Method Shelf Edge” so shelf edge construction can be unique and different from “Default Construction Method”.
- Added product depth label to the 2D Instructions subassembly.
- Added two Door Wizard variables to restore the “Flat Panel Rabbet” feature in 5-piece doors:
- Flat Panel Rabbet
- Flat Panel Rabbet Width Gap
- Added new global variable “Back Floor Scribe” and linked to all cabinet thick backs. It will activate when the “Extend Back to Floor” is used and a value is entered in “Back Floor Scribe”.
- Numerous changes and adds for 2D elevation views:
- Added four new global variables for better control over the 2D elevation of “Width/Height/Depth” and “Elevation Caption” text. Old global variables “ElvWHD" and "ElvCaption” have been moved to the Legacy category, as they are no longer referenced.
- New variables added to the global and "2D Instructions" subassembly:
- "Elevation WHD"
- "Elevation WHD Offset"
- "Elevation Caption"
- "Elevation Caption Offset"
- The product prompt “ElvWHD” was renamed to “Elevation WHD” in all products.
- Two new drawing tokens were added to the 2D Elv View Instructions subassembly for the Width x Height x Depth and one for a caption.
- Updated all products and changed the prompt “ElvProductDescription” to “Elevation_Product_Description”.
- Global variable “ElvProductDescription” is now hidden.
- Added “Elevation Product Description” and “Elevation Product Description Offset” prompts to the 2D Instructions subassembly. Now, using a DRAWTEXT token for the elevation product description instead of the system prompts.
- Global variables added:
- "Elevation Product Description"
- "Elevation Product Description Offset"
- Added the ability for all drawers to have their attachment screws included in hardware reports. With this, added greater control to specify which type of drawer attachment screws needed for system (euro) screws vs wood screws.
- Added two variables to the Hardware Wizard:
- Added a column to the "H!LookUpTableScrews" for the face panel screw depth.
- Added new hardware "Screw 12mmx3.5mm".
- Linked the Bottom Hole Dia, Bottom Hole Depth, Back Hole Dia, Back Hole Depth, Slide Hole Dia and "Slide Hole Depth" prompts in all drawer subassemblies to the "H!LookUpTableScrews".
- Added new prompts to all drawer subassemblies to control desired screws:
- "Slide Screw Type"
- "Bottom Fixing Screw Type"
- "Back Fixing Screw Type"
- "Slide Hole Dia"
- "Slide Hole Depth"
- All SLIDE tokens in drawers have been updated so they now tally up the number of screws used when a work order is processed.
- With these changes, multiple existing global variables will no longer be used, and can be moved to “Legacy” (unless you have custom drawer subassemblies):
- "Dwr Slide Bore Depth"
- "Dwr Slide Bore Dia"
- "Drawer Back Hole Diameter"
- "Drawer Back Hole Depth"
- "Drawer Bottom Hole Diameter"
- "Drawer Bottom Hole Depth"
- "Drawer Spot Hole Diameter"
- "Drawer Spot Hole Depth"
- Added the “Vent Route” subassembly to Cabinet Modifiers category. This contains options for vertical or horizontal cuts to be added to Left, Right, Top, Bottom, Front, Back of any cabinet. You can also specify the route from the inside or outside.
- Added new global variable “Dowel Drill Through Backs” to have the drilling into the back from associative parts drill from the opposite side and drill all the way through the back to keep all machining on one face.
- Added selection icon for the Universal Hardware Insert subassembly. Also changed the hardware selections from a combo-box to a “control type 9” which allows users to select any piece of hardware.
- Added “Drop Down Door Stay” variable to the Hardware Wizard.
- Added five new Salice Progressa Undermount Slides (3D graphics coming at a later date)
- Salice Progressa Smove
- Salice Progressa+ Smove
- Salice Progressa+ Push to Open
- Salice Progressa+ Shelf Smove
- Salice Progressa+ Shelf Push to Open
- Added Salice PACTA Drop Down Door Hinge System
- Salice PACTA Flap System White
- Salice PACTA Flap System Glossy White
- Salice PACTA Flap System Stainless Steel
- Salice PACTA Flap System Grey
- Salice PACTA Flap System Champagne
- Salice PACTA Flap System Satin Metal Black
- Salice PACTA Flap System Glossy Metal Black
- Added the Kessebohmer CONERO Pull Out System Hardware Range:
- Kessebohmer Conero 72H Trouser Hanger Pull Out
- Kessebohmer Conero 72H Internal Pull Out
- Kessebohmer Conero 168H Internal Pull Out
- Kessebohmer Conero 72H Laundry Pull Out
- Kessebohmer Conero 72H Trouser Hanger And Laundry Pull Out
- Kessebohmer Conero 72H Comfort Tray Pull Out
- Kessebohmer Conero Belt and Tie Rack Pull Out
- Kessebohmer Conero Clothes Lift
- Kessebohmer Cornero Clothes Lift TOP
- Replaced all Blum Hinges and Hinge Plates with “simplified” reduced size CAD files for better AutoCAD performance in 3D.
Resolutions General
- Resolved an issue with Return Fillers on the right side of cabinets. Part origin now correct.
- Resolved an issue with Any Angled Shelf Fixed. Dummy parts are now set to a “negative” material to prevent being added to a work order.
- Resolved a construction hole machining issue that would occur cabinets used notched toe kick and applied backs.
- Resolved an issue with adj shelf hitting blind panel in Tall Open Blind Corner cabinet.
- Resolved an issue with missing “Fixed Panel” option for cabinet Face Options. It was missing from the v24.0823 update.
- When using the global variable “Drawer Box Fixed Location”, the Drawer Bottom Gap will now adjust when entering a positive value for “Bottom Reveal”.
- Resolved a location issue with Blind Corner Hinge Plates.
- Resolved missing machining for the following Fixed Panel Fasteners:
- SH 325 Zero Side Mount Fixed Panel
- Keku AS Push-In Fitting Fixed Panel
- Keku EH Suspension Fitting Left Fixed Panel
- Keku EH Suspension Fitting Right Fixed Panel
- Keku EHS Suspension Fitting Left Fixed Panel
- Keku EHS Suspension Fitting Right Fixed Panel
- Resolved #NAME? errors inside certain Upper Cabinets that affected some prompt values’ formulas.
- Resolved an issue with Secondary Locks (such as elbow catch) appearing in the wrong location when used with a cabinet valance.
- Resolved an issue with Door Drawer blind cabinets that prevented the top-drawer selection prompts from appearing when selecting a wood drawer.
- Resolved an issue with Double Door Tall cabinets where the horizontal door gap was looking at "G!Door_Gap" instead of "G!Horizontal_Door_Gap".
- Added a missing 2D section height dimension token in Solid Wood Doors.
- Resolved an issue with ADA Sink Angled Frame product. Left/Right hand sides with different thicknesses will no longer lose machining.
- Resolved an issue with "Component Door Drawer" subassembly when the global “Door Drawer Stretcher” was set to “none”.
- Resolved an issue with Hafele Alto Slim drawer system. Will no longer be set to “Convert to Inner Drawer” by default.
- Removed the Hardware Wizard variable “KD_Cams”, as it was not being used.
- Resolved reported issues with the Blum REVEGO and HAWA Concepta III pocket slide-in door systems that were discovered by beta testers.
- Resolved an issue with 2+ bay designer cabinets with haunched face frame and radius left/right sides. The haunch machining will now align with the mid stiles.
- Face Frame report will now include face frames from the Face Frame Only product category.
- Resolved issue with Office Cabinet products involving finished tops & bottoms when using thick backs and Dado/Screw construction. Screw holes will no longer appear at captured backs.
- Office Cabinet products’ Toe Kick parts will now reference "G!Dado_Small_Part_Notch_Distance_To_Edge" and "G!Construction_Method_Toe_Kick_Top".
Microvellum Foundation Library Release Notes | Build 24.0919
The following release notes apply to Microvellum Foundation Library, Build 24.0919
Additions
- Added 5 new special Wine Rack products and 9 new Wine Rack Insert subassemblies.
- Products:
- Master Vertical Wine Rack Corner Frame
- Master Vertical Wine Rack Frame
- Stemware Rack
- Wine Rack Diamond Stack
- Wine Rack Panel
- Subassemblies:
- Wine Bottles
- Wine Rack Display Divisions
- Wine Rack Divisions
- Wine Rack Lattice
- Wine Rack Nek Rite
- Wine Rack Vino Pins
- Wine Rack Vino Rails
- Wine Rack Vintageview Wall Series
- Wine Rack X
- Added three more Button-Fix connectors
- Type 1 metal
- Type 1 flush
- Type 1 bonded
- Added “LookUpTableDropDownSystems” LookUp Table to the Hardware workbook for drop-down door hardware. Added the following hardware:
- Hafele Flap stay with pull cable A Anthracite
- Hafele Flap stay with pull cable A Black
- Hafele Flap stay with pull cable A Matt Silver
- Hafele Flap stay with pull cable A White
- Hafele Flap stay with pull cable A Silver Gloss
- Added a left and right dowel offset to the Shelf Fixed and Vertical Splitter subassemblies.
- Added additional material pointers for MDF Profile doors, drawers, and applied ends so they can automatically default to a different material than the Finished Faces doors.
IMPORTANT NOTE: This will require users who update their libraries to assign a material to the new pointers.
- Base_MDF_Door
- Tall_MDF_Door
- Upper_MDF_Door
- Base_MDF_Drawer_Front
- Tall_MDF_Drawer_Front
- Upper_MDF_Drawer_Front
- Base_MDF_Applied_Ends
- Tall_MDF_Applied_Ends
- Upper_MDF_Applied_Ends
- Added new subassemblies Flatshot Instructions & Flatshot Corner Instructions. Global variable was added to control the names of the subs "Flatshot Instructions Name". This allows users to name their own custom flatshot Instructions subassembly, so it won’t get overwritten during updates. Removed all flatshot tokens from all products. Also added global variable "Flatshot Parts Filter".
- Added two global variables for more control over the Wrapped Batten size and screw locations.
- "Screw Distance To Edge Wrapped Batten"
- "Wrapped Batten Width"
- Overhauled the Pelmet product. Added the ability to angle the left and right returns and extended returns. Updated product rendering.
- Added additional functionality to the Upper Rangehood Cabinet.
- Created a new cabinet mod “Center Ducting Box”.
- Created an option to have a full one piece back. This makes it easier to locate a stud when installing the cabinet.
- Added Solid Wood Handle option that apply to the face of the cabinet doors. To achieve this, we utilized the Aluminium Handle option. By entering a value inside the added column in "D!LookupTableAluminiumHandles", this will tell the system to face mount the extruded molding. Added a sample option: “Timber 30mm x 20mm Handle”.
- Added Tip-On feature to Blum MERIVIOBOX. Added hardware material “Blum Tip-On Blumotion Set For MERIVOBOX”.
Modifications
- Improved the Hawa Concepta III Pocket Door product:
- It can be added to any cabinet product as a subassembly.
- Several redundant prompts were removed, as they were needed only in a product, not a subassembly.
- Removed the parts and referenced them to the middle pocket.
- All the door offsets were set from the left side. Now created offsets for the right door.
- Removed the double door options, as this is not an option yet.
- Changes have been made to the Mitered End Panel and Mitered Shelf products. You can now change the grain direction for both the faces and the ends. The Thick Panel Assembly subassembly has also received improvements.
- Improved the 2D Instructions subassembly. The subassembly will now function more reliably in other “non-cabinet” products.
- Modified the ADA Sink Angled Frame product. "Sub Front" will now align top and bottom with the sides.
- Added the "ElvNoDim" prompt to all miscellaneous products that were lacking it. This gives better control on removing unwanted 2D elevation dimensions.
- Modified all Toe Kick Base products to look at global “Construction_Method_Toe_Kick” instead of “Default_Construction_Method”.
- Modified Blum straight mount hinge plates so they setback 20mm from first hole to face of the cabinet. This was done by adding the @ function to the name to move the plates forward. Renamed 4 hardware materials:
- Hinge Plate BLUM Straight 0mm Expando@36mm
- Hinge Plate BLUM Straight 0mm Knock-In@36mm
- Hinge Plate BLUM Straight 0mm Screw-On@36mm
- Hinge Plate BLUM Straight 3mm Expando@36mm
Resolutions General
- Resolved an issue with Toe Kick Assembly Box when the cabinet has a Finished End. Sleepers will now be correctly located in X.
- Resolved an issue with all pull-out subassemblies that prevented some drill machining from appearing on the nest patterns. The machining dummy parts have been split out to have a part per row of machining. They are no longer using the Part_Thickness column, which was causing the issue.
- Resolved an issue with Solid Wood and Profile doors that caused the right hinge to be missing on diagonal cabinets.
- Resolved an issue with Elev View DRAWDIM tokens. The tokens were referencing "G!Elevation_Height_Dimension_Offset" instead of "G!Elevation_Width_Dimension_Offset", as they were intended to.
- Updated ENKO Slimbox drawers to match manufacturer’s specifications.
- Resolved an issue with the Hettich InnoTech Atira drawer system gallery rails.
- Resolved an issue with Grass Zargen drawer system. Correct drawer heights are now used for all opening heights.
- Several improvements and corrections were made to the Blum REVEGO folding door system.
- Resolved an issue with Folding Door Hinges. Changing hinge type will now change the subassembly and also have the correct rotation offset from the door edge.
- Resolved an issue with Blum Hinge Plate Straight mounts. Drilling now starts at 20mm from front of carcass. In order to achieve this, the hardware materials are now using the “@” symbol to move the plates forward.
- Resolved an issue with Pie Cut Corner Cabinets, which occurred when they were used with the Shadow Rail option and a full top or overlay top.
- Resolved an issue with the “Master Cut Report – Batch”. Sq Meter quantity will now be correct.
- Resolved an issue with internal subassembly insert “Divisions”. Parts will now notch for shadow rail option.
- Resolved an issue with the Hafele Matrix Box S drawer. Bottom length corrected.
- Resolved an issue with hinge plate locations when using Full Inset Doors.
- Resolved an issue with edge array tokens on cabinet thick backs that involved the mirrored edge.
- Added Left Hand/Right Hand options to the Blended Locker product.
- Added 2D elevation dimension tokens for each frame opening height and width. Global variable added to control the option: "G!Face_Frame_Opening_Dims_Elv_View".
- Resolved Drawer Front Calculator issue in the Base 3 Drawer Split Top FF & Base 4 Drawer Split Top FF.
Microvellum Foundation Library Release Notes | Build 24.0823
The following release notes apply to Microvellum Foundation Library, Build 24.0823
Additions
- Added a new global variable option, “Rebate With Router And Saw”. Selecting this option will enable two machine tokens per cabinet back edge as it associates to cabinet sides, tops, bottoms (Thick Back not supported). This option can be used when routing & sawing code is required for multiple machines (P2P & Nest). This can be set up with multiple processing stations and disabled G-code, as required per Toolfile.
- Added the “WallOffset” prompt to Filler and End Panel products to assist when they are associated to a wall.
- Added the ability to reverse or "flip" the machine point for fixed shelves in the Vertical Splitter subassembly.
- Added new material pointer “Shadow_Line_Solid_Rail_Material” and linked to all “Shadow Line Solid Material” prompts in all products. This will allow users to setup a contrasting color without changing the drawer front pointer. The Door Wizard "D!LookUpTableShadowline" column 7 lookup table has been updated.
- Added MDF Door edge pointers and linked them to the profile door subassembly:
- "Base_MDF_Door_Edge"
- "Tall_MDF_Door_Edge"
- "Upper_MDF_Door_Edge"
- "MDF_Drawer_Front_Edge"
- Added a new Door Style for the MV Profile Door called “Default Custom”. With this selected, the door variables are controlled with the below new door wizard variables instead of the LookUpTable.*
- Default Patten
- Default Rail Width
- Groove Panel Face
- Default Groove Spacing
- Default Groove Depth
- Split Drawer Rails
- Add Rail Lines
- Added a new option to Frameless Blind Corner Cabinets called “Rebated Blind Corner Panel” to notch into the top and bottom of the cabinet.
- Added the global variable “Floor Scribe” to all toe kick products and subassemblies.
- Added a feature to the Master Split Cabinet that enables the finished end(s) to be one piece or split like the rest of the cabinet.
- Added additional Sink brand options to better demonstrate how to add specific sink brands and models:
- Kohler 3839-1
- Kohler 3840-1
- Kraus KWT310-33
- Kraus KHU640-33
- Estilo EST0265
- Ausitn & Co AC15003
- Added a new cabinet face option, “Fixed Panel”, facilitated with the Component Doors subassembly. Several hardware items have been added and are available for this new option. They are duplicates of existing hardware added in the 24.0607 update, required due to differences with their associative machine tokens:
- Button Fix Type 2 Fixed Panel
- Added functionality to the Divisions With Fixed Shelves subassembly to control the construction holes for both the left and right holes.
- Added two Global Variables to better control the wood drawer default construction after library updates:
- "G!Default_Construction_Method_Wood_Drawers_Into_Bottom"
- "G!Default_Construction_Method_Wood_Drawers_Bottom"
- In Base 2 Door 2 Drawer, to eliminate face 6 machining, prompt values were added to the drawer subassemblies so that when there is a double top drawer with a single division, the drilling from the left drawer will drill through the drawer division on the left and the drilling from the right drawer will turn off on the left side.
- All Division subassemblies have had the "Reverse Machining Division 1" and "Reverse Machining Division 2" prompts added. These prompts allow the user to change the face for the machining of dados, cams, etc., and can be useful in preventing face 5 & 6 machining.
- Added extra hinges for lift-up and drop-down door conditions. One can now have up to 4 hinges.
- Added a new global variable, “Include Rear Dado On Divisions”, and updated all subassemblies using divisions. Select this option to add a rear dado on the back edge of the divisions, allowing them to securely slot into the cabinet thick back. This option is designed to work in conjunction with "Default Construction Method Rear".
- Added the TIP-ON BLUMOTION hardware to the Blum Legrabox:
- Blum Tip-On Blumotion set for LEGRABOX and MOVENTO
- Blum Tip-On Blumotion Synchronisation Linkage
- Added Blum Thin Door Hinges:
- Hinge BLUM Thin Door 110deg Full Overlay EXPANDO T@41mm
- Hinge BLUM Thin Door 110deg Half Overlay EXPANDO T@34mm
- Hinge BLUM Thin Door 110deg Inset EXPANDO T@25mm
- Added two new global variables to better control flatshot tokens. Clients can now globally control which parts to exclude and whether or not to include the labels.
- "Flatshot View Labels"
- "Flatshot Parts Filter"
- Added a new global variable, “Dado_Stretcher_Front_Notch_Distance_To_Edge” to control the front notch distance on all stretchers. This was added because, in many cases, the front notch needs to have a minimum width to avoid interference with the knives on an edgebander. We have also updated all rails to look at the global “Dado_Minimum_Width”.
- Added Folding Doors option to blind corner cabinets.
- Added additional sizes for Grass Nova Pro Scala drawer system.
- Added the Hawa Concepta III Pocket Door. This can be used as a stand-alone product located in the Master Cabinet Accessories or can be used as a Component Insert subassembly which can be added to any product. This product is considered to be in beta, still being developed and tested. Please submit any feedback to Microvellum by creating a support case.
- Added the Blum REVEGO Pocket Doors product. This is a stand-alone product located in the Master Cabinet Accessories. This product is considered to be in beta, still being developed and tested. Please submit any feedback to Microvellum by creating a support case.
Resolutions General
- Resolved an issue with 2D elevation of upper cabinets with wall fillers that were incorrectly moving with Bottom Reveal changes.
- Resolved an issue with Tall Fridge Cabinet. The Applied Ends will no longer move when the Bottom Reveal prompt is changed.
- Resolved an issue with Extruded Die Walls when using multiple skins and using the custom calculator to change sizes.
- Hafele Alto Slim drawer system will now have front molding parts for the inner drawer option.
- For all drawer systems, the “Back Grain Direction” and “Bottom Grain Direction” subassembly variables will now control these parts.
- Resolved an issue with Dowel & Screw machining. Holes on stretchers from divisions will only be face 5.
- When using Dado & Screw construction with regular dados, the drilling from the thick backs into the top and bottom is now on the correct side keeping all the machining on face 5. Also, the drilling and Rail Notch machining into the top stretcher will remain on face 5.
- In the Base 2 Door 2 Drawer product, the prompt “Double Division” has been renamed to “Double Drawer Division” to prevent a conflict with turning on a double horizontal division.
- When using the global “Drill Through at Divisions for Adj Shelves”, the routing machining for Lock Dados will now be on face 5 with the drilling.
- Resolved issue when “G!Dado_Depth_Thick_Back” is a different value than “G!Dado_Depth”. Thick backs will now be correctly sized.
- Resolved an issue that occurred with multiple drawer systems, wherein adjusting the "Bottom Gap" subassembly variable moved the runner holes in Z twice the needed distance.
- Resolved a drilling location issue with DTC Dragon Pro drawer system.
- Resolved a number of issues with the Diagonal Angle Cabinets which have been refactored and rebuilt. Corrected 2D elevation view.
- Resolved an issue with “Internal Drawers With Faces” Component Insert that prevented the divisions from appearing.
- Resolved an issue with Drawer Front Edgebanding, wherein a different color than the door's edging was needed. The “Finish_Face_Drawer_Edge” prompt has been added to all relevant products.
- Resolved a cabinet back router machining error that occurred from backs added via the Cabinet Modification options.
- Resolved numerous unspecified issues with various drawer systems as reported by users.
- Resolved an issue with the new Hafele Symo Lock not appearing in the list for users running the library update.
- For the Base Applied Back Panel product & all Applied End Panels, the "Grain Direction" prompt is now linked to the Finished Face panel.
- Added missing prompt data for the “Mirrored Value” across many Left/Right product prompts. This will help make the “Mirror Products” Toolbox feature much more reliable.
- Updated the global help image for “Front Shelf Hole to Edge”.
- Resolved issues that affected many products when using the Microvellum “Replace Product” feature. This function should now perform correctly.
- The Vertical Opening Splitter FF and Horizontal Opening Splitter FF subassemblies have been integrated into the Face Frame Vertical and Horizontal Designer Cabinets as Bay Face Options. The below products have been updated:
- Master Horizontal Designer Cabinet FF
- Master Vertical Designer Cabinet FF
- Master Upper Split Height Designer Cabinet FF
- Master Split Vertical Designer Cabinet FF
- Master Multi Carcase Designer Cabinet FF
- Added the Master Split Vertical Designer Cabinet FF product. This has the ability to split the carcass into two at any bay.
- Added the Split Height Face Frame & Upper Split Height Face Frame products to the Face Frame Only category.
- Added new global variable “Drawer_Front_Overlay_Middle” and pointed the product prompt "Drawer Front Middle Overlay" to the 2 Door 2 Drawer FF Cabinet.
- Updated the Leg Levelers in the Master Multi Carcase Designer Cabinet FF. Each carcase will now have its own set of leg levelers.
- Resolved an issue with Master Multi Carcase Designer Cabinet FF that caused the "Frame Overlay" prompts to be incorrect when Left and Right were different.
- Resolved a number of issues with the Face Frame Diagonal Angle Cabinets which have been refactored and rebuilt. Corrected 2D elevation view.
- Resolved an issue with Face Frame Corner Cabinets when product width was different than the product depth. Face Frame parts will now size correctly.
- Resolved an issue with Master Vertical Designer Cabinet FF, which occurred when using Division Inserts in the bottom bay and there is no cabinet bottom. Divisions will now have the correct size and position.
Additions/Resolutions Closet/Wardrobe Expansion
- Resolved issue with drawer depths hitting the rear inside cleats of closet products and not respecting the global “Back Space Requirement” variable.
Microvellum Foundation Library Release Notes | Build 24.0722
The following release notes apply to Microvellum Foundation Library, Build 24.0722
Additions
- Added five new Fulterer Drawer Slide/Runners:
- Fulterer 5045
- Fulterer 5210
- Fulterer 5000
- Fulterer 5001ECD
- Fulterer 5210ECD
- Added the Blum AVENTOS HKi lift system.
- Added features/revamped the Extruded Toe Kick Base product to have same features as extruded countertops. Added stacked skins feature on curved segments.
- Added features/revamped the Extruded Part Collection product to have same features as extruded countertops.
- Added Accuride 1532 Pocket Door hardware to the Component Pocket Doors subassembly.
- Added new global variable "Add Bottom Return To Wall Filler". Tick to add a bottom return panel to scribe fillers when attached to wall cabinets. The filler return bottom and top will now offset the valance distance when the Local Prompts "Left_Side_Full_Height" or "Right_Side_Full_Height" are unticked. When this new global is unticked, the "Left/Right Side Full Height" will uncheck to allow applied under panels.
- Added the Hafele Symo 3000 locks.
- Added a set of “Generic” hardware items for Hinges, Hinge Plates, Face Frame Hinges, and Adjustable Legs. These are non-brand specific and utilize simplified 3D graphics which improves MV performance when drawing products in a large drawing. These will be set as default for new library installs.
- Added Salice Conecta hinges for 1” (25mm) thick full overlay doors.
- Added 3 new global variables for better control within the Screw/Dowel/Cam construction tokens. For example, these will provide better results right out of the box when adding screws to nailers:
- "Screw_Offset_Small_Parts"
- "Dowel_Offset_Small_Parts"
- "Cam_Offset_Small_Parts"
- Added a new cabinet Back Construction option “Removable”. Added new global variable “Removable Back Clearance”.
- Added new rendered product images for Extruded Die Wall products.
- Added IFERROR to perfect grain override formula to prevent errors in the event a formula material has an error in its name.
- Added "Blind Panel Type" and "Blind Panel Style" prompts to blind corner cabinets, giving local control.
Resolutions General
- Resolved an issue with Hettich Avantech YOU rear fixing brackets.
- Resolved an issue with Carcase subassembly backs in Tall Wall Oven.
- Resolved an issue within the Master Die Wall extruded product. Skin parts will locate correctly when quantity is greater than 1.
- Resolved an issue in appliance products that caused the “Show Item Number” prompt to misbehave.
- Resolved an issue in Master Split Cabinet. "Lower Back" will now be in the correct location when using “Extend Back to Floor” global variable.
- Resolved an issue in all Frame and Frameless Transition cabinets when selecting “Adjusted Depth” option. "Cabinet Angle" will now calculate correctly.
- Resolved an issue with drawer front adjuster feature. Associative 5mm drilled holes will now appear correctly in the drawer box sub fronts.
- When "Default Construction Method FE" is set to “None” and "Construction Method Nailers" is set to “Screw”, the nailers will no longer switch to dowels at the Finished End.
- Resolved an issue with global variable “Extend Sides to Floor Global” affecting the Carcase subassembly in the Tall Wall Oven Full Box product.
- Resolved an issue in Extruded Die Wall w/ Skins. Angled studs now correct size when Inside and Outside skins are different thicknesses.
- Resolved issues with the Washing Machine and Dryer dwg blocks. Removed underlying entities that were causing issues when exporting to IGES.
- Resolved issue with the Internal Insert Peka Pinello Board Pullout. Changing to left hand will now have the correct associative drilling.
- Resolved two issues when using Aluminium Handles at drawers.
- Edgebanding at top edge will now be removed based on the Remove Edgetape column in "D!LookupTableAluminiumHandles".
- Drawer system heights will now calculate correctly by including the height of the Aluminium Handle as well as the drawer front height.
- Resolved an issue with "Shelf Edge" feature on Fixed and Adjustable shelves. When using "Lip Up" or "Lip Down", the machining extra machining will no longer appear.
- Resolved an issue with filler machining routes when cabinet top or bottom has a different material thickness than the filler parts.
- Resolved a "Left/Right Reveal Gap" issue in Door/Drawer cabinets. Drawer Fronts will now remain in alignment with doors when making minor adjustments to Left/Right reveals.
- Resolved a missing prompts issue in Base Open 2 Drawer. "Reveal" and "Gap" prompts are no longer hidden.
- Resolved an issue with the Strip Lighting Insert subassembly that caused the pocket recess routing to locate incorrectly in a nest.
Microvellum Foundation Library Release Notes | Build 24.0624
The following release notes apply to Microvellum Foundation Library, Build 24.0624
Additions
- Added additional sample Generic Five Piece solid wood door styles:
- Raised Panel 5pc with Applied Molding
- Mitered Solid Raised Panel 5pc
- Mitered Haunched Solid Raised Panel 5pc
- Mitered with Applied Molding Raised Panel 5pc
- Mitered Inset Panel 5pc
- Mitered Inset Beaded Panel 5pc
- Plank
- Plank w Slab Molding
- Added legacy “Cal Door” Door Library with 49 different Door Styles and Four Door Types (new Door Wizard)*:
- Cal Door Mitered Solid
- Cal Door Mitered Inset
- Cal Door Cope N Stick Solid
- Cal Door Cope N Stick Inset
- Added Blum 95 deg Overlay Blind Corner Hinges
- Added 64 & 167 heights to the Hafele Alto Slim
- Added a “Post Laminate” option to the Extruded Countertop Products
- Modified the Access Panel subassembly insert. Added a visible prompt to control the lip thickness.
- Added enhancements & features to the Extruded Die Wall products:
- Extruded Die Walls will now perform better when extruding along a polyline a with non-blended radius.
- Extruded Die Wall products along a blended radius can now be segmented via the prompts
- Added “Bay Position” hidden prompt to all drawer subassemblies. This can be used in reporting to designate which drawer it is for assembly. Bay Position comment added to all drawer bottoms and wood drawer sub front parts.
- Added nine new global variables to better control which Nailers the user requires:
- "Use Top Nailer Base"
- "Use Center Nailer Base"
- "Use Bottom Nailer Base"
- "Use Top Nailer Tall"
- "Use Center Nailer Tall"
- "Use Bottom Nailer Tall"
- "Use Top Nailer Upper"
- "Use Center Nailer Upper"
- "Use Bottom Nailer Upper"
- Added new global variable to control whether Hardware is included within the Flatshot dynamic product image feature.
- "Flatshot Hardware"
Resolutions General
- Restored the "Slab Molding" feature within the Solid Wood Door subassembly. Added missing molding profile drawings.
- Resolved graphical rotation issues with Tab Pulls that affected 2D elevation and section views.
- Resolved an issue with handle location when using a top shadowline only with a drawer bank cabinet.
- Resolved an issue with toe kick assembly option in Any Angle cabinets.
- The Base 2 Bay Drawer has been rebuilt from the Master 2 Bay Horizontal Cabinet to resolve some issues with the shadowline feature.
- Resolved an issue in corner cabinets when using shelf standards.
- Resolved an issue when using the global variable “Extend Sides to Floor”. This will no longer affect Upper cabinets.
- Selecting the global “Face Frame Miter FE Joint” will now force the Applied Panel FF to ignore "G!Face_Frame_Outside_Overlay_at_FE" and align with the mitered face frame.
- Resolved a 2D plan view draw token issue for Transition Angle Cabinet FF products.
- Resolved an issue with Horizontal Opening Splitter FF when adding Shelf ADJ to a bay.
- The back in all Face Frame Cabinets will now be placed correctly in the Z origin and size correctly when selecting no bottom.
Microvellum Foundation Library Release Notes | Build 24.0607
The following release notes apply to Microvellum Foundation Library, Build 24.0607
Additions
- Added additional features to the ADA Sink Angled Frame:
- Option to turn on Mounting Rails for the Angled Panel (and toe kick). Fastening method have been included.
- Hardware options have been modified to include fastening hardware to attach the angled panel to either a side or mount to a rail.
- Hardware position control prompts for the new hardware have been added for (X,Y) position along with lift off clearance.
- LookUpTableHorizontalMountHwr added to easily include user added hardware that will update the dropdown list of hardware and modify control values.
- Angled_Panel_Bottom_Reveal now works correctly and defaults to 0 for a flush Angled Panel to the edge of the carcass.
- Added additional hardware mounting options to the ADA Sink Angled Frame:
- Side Mounts:
- Button-fix type 2
- Rail Mounts:
- Button-fix type 1
- Button-fix type 3
- SH 227 Galaxy
- SH 350 Lock
- SH 400 NZ Clip
- Added additional functionality for grain matching products and door/drawer fronts together:
- Setting product item numbers to a value over 100 will trigger a new feature where the system will create perfect grain containers grouping doors & drawer fronts with matching item numbers (101.1, 101.2, 101.3).
- 2D elevation tokens added to help identify the grouping of perfect grain containers.
- New global variables added:
- "Split Drawers From Doors"
- "Split Double Width Cabinets"
- "Allow Grain Matching Across Multiple Products"
- "Show Perfect Grain ID on Elevation"
- Added additional global variables to control the Item Number positions for Counter Top and Toe Kick products:
- "Countertop ItemNumberX2DElv"
- "Countertop ItemNumberZ2DElv"
- "Countertop ItemNumberX3D"
- "Countertop ItemNumberY3D"
- "Countertop ItemNumberZ3D"
- "Toe Kick ItemNumberX2DElv"
- "Toe Kick ItemNumberZ2DElv"
- "Toe Kick ItemNumberX3D"
- "Toe Kick ItemNumberY3D"
- "Toe Kick ItemNumberZ3D"
- Added additional Blum Aventos HK Top options for “Chipboard Screw” machining.
- Within the Toe Kick Base product, screw construction has been added to the top of the sleepers into the cleats as well as machining from the front and back of the cleats into the front and back rails. We have also added in the"G!Dado_Minimum_Width" variable to add DADOs.
- Added a new report “Product Detail Report w Bays”. This report will display more information typically needed for designer cabinets with multiple bays.
- Added the ability to drop cabinet backs to the floor (when not captured). Added new global variable "G!Extend_Backs_To_Floor".
- Added prompts to the Tall Pullout Pantry. When selecting Horizontal Handles you now have the option to have centered Horizontal Handles. When unselecting Horizontal Handles you now have an option to have the handle on the left or right side of the face panel.
- Added help text warning messages for Base 1 Drawer Waste Bin product (and others). If the cabinet's inside width, height, or depth does not accommodate the correct size for the selected Pullout, the message will appear on the 2D plan view of the product.
Modifications
- Modified all appliance products to better differentiate appliance opening size vs actual appliance size. For example, a dishwasher may require 24” opening, but the appliance is actually 23.875”.
- Improvements made to the Door and Drawer Front Fabrication report. Door Styles will now display. Also removed subassemblies that were not actually doors from appearing.
- Magic Corner hardware for blind corner cabinets renamed to Magic Corner II to match manufacture’s specs.
- Extruded Countertop – The HeightAboveFloor formula has been updated to align with the standard Base Cabinet height.
Resolutions General
- Resolved an issue with many drawer systems’ drawer bottom part sizes when using “Back Over Bottom” option. Recommend verifying your particular drawer system drawer depths are matching your expected sizes. Also verify the “Back Over Bottom” selection is set to your desired option.
- Resolved a formula issue inside Base 1 Door Sink With False Front that was introduced in the previous update. Finished Faces will now display correctly.
- Resolved numerous hardware graphics issues wherein the graphics were not scaling properly for imperial scale users.
- Resolved a 2D elevation issue with Countertop With Waterfall Ends product.
- Resolved an issue with the rotation of the handle on the 2d elevation drawing for the left bi-fold doors.
- Resolved an issue when using Tall Wall Oven with Shadowline.
- “Adj/Fixed Shelf Qty” prompts will now remain visible when using “Division with Adj Shelves”.
- Resolved an issue when using Blum HF lift up hardware within Wall Oven cabinets. The calculation for the position of the lift mech in the component doors sub has been updated to look at the opening size, not the size of the overall cabinet.
- Resolved a Z location issue for certain drawer types inside the Component Drawers subassembly.
- Resolved an issue with “Base 1 Drawer Waste Bin” products where waste bin pullout types in the subassembly were not automatically being set when product is added.
- Resolved an issue in “Upper Open End Cabinet”. Adj shelf holes will now line up when selecting Right Hand option.
- Resolved an issue with “Scribe Filler With Cleats” option when using different thickness material for the fillers.
- Global variable “Draw Hardware Blocks For Pullouts” will no longer control wood drawers. They will use “Draw Hardware Blocks For Slides”.
- Resolved an issue where extra AutoCAD scales were being added to the drawing whenever a dwg block (such as hardware) was brought in from a product. All dwg blocks have been purged of unnecessary scales.*
Additions/Resolutions Face Frame Cabinetry*
- Resolved a cabinet issue with the internal height calculation when using the “Add Center Shelf” option. This was introduced from the previous update and has now been corrected.
- Resolved an issue when selecting a cabinet Finished End and also Applied End on the same side. Parts will no longer be in the same space.
- Resolved an issue with door heights when selecting Top Facia and deselecting Intermediate Rails.
- Resolved issues with Base Transition Angle Cabinet FF. Product has been rebuilt from Master Transition Angle Cabinet FF.
Additions/Resolutions Office Furniture Expansion*
- Added the Office Desk - 1 Piece Top and Office Desk - 2 Piece Top products each with a shaped cutout in the corner and a bow shape on the front.
- Added the 3-piece Top Desk product with a corner leg configuration.
- Added scallop cutout options to desks and worktops used for back edge cable management.
- Added Cabinet Connector Holes option to all office furniture cabinet products.
- Simplified the office furniture cabinet products that were using two back parts used to transpose the part orientations and grain directions. This can now be done within the MV processing stations, so the extra parts were removed.
- Corrected a part thickness issue inside Standard Hob.
- Resolved an issue with Closet Drawers with Single Hanging product. Top Fixed Shelf will now be in the correct location when activated.
Microvellum Foundation Library Release Notes | Build 24.0520
The following release notes apply to Microvellum Foundation Library, Build 24.0520
Additions
- Added a new product, the “Extruded Master Countertop”. Four other extruded countertop products have been replaced with a new version based on this product. Many new features have been added into this enhanced extruded product (Toolbox 24.1.0416 or newer required for some new features):
- Connector hardware (toggle bolts) available.
- Buildup options.
- Backsplash options.
- Offset from Polyline variable.
- Position of product Left or Right of line.
- Countertop front edge detail options.
- Supports recalculation of geometry with product prompt depth changes (without the need to extrude from polyline again).
- Supports additional more complex polylines such as non-blended radius conditions.
- More features planned for future enhancements.
- Added Galvin Prime Slim Drawers. (No Graphics) (AU/NZ Market only)
- Added Furnware Group SYMETRA Drawers. (No Graphics) (AU/NZ Market only)
- Added slot cutouts for aluminum file bars in wood drawers.
- Added the ability to associate drilling screw holes to thin backs as well as thick backs. New global variable added “Screw Construction Regular Backs”.
- Added a new global variable “Door Rounding” used with a FLOOR function to round down the width and height of all door & drawer front parts.
- Grain Direction & Perfect Grain Container prompts have been added to the MV Profile Door and the Solid Wood Door subassemblies.
- Added new features to the ADA Sink Angled Frame product:
- Angled Frame with Toe Kick.
- Inset or Overlay Angled Panel.
- Finished Front, Finished Sub Front, or Sub Front.
- Added horizontal parts to create an optional enclosed bottom.
- Inside and outside radius parameters for the angled polyline cut.
- Prompt layout has been changed and will most likely continue to be refined in the next update as we gather additional feedback.
Modifications
- Modified the rear notch on the Front Stretchers to match the Rear Stretchers. The notch will now look at "G!Dado_Small_Part_Notch_Distance_To_Rear_Edge".
- Replaced many M2U functions throughout the library with UCN to prevent undesirable default imperial values from appearing. For example, instead of “=M2U(1,Accuracy)" which results in “0.03937” inches, we now use “=UCN(0.0312,1)” or “=UCN(0.0625,1)” which provides fractional values (1/32” or 1/16”) more commonly used by imperial users.
These changes will not affect metric users. However, for imperial users, some default variables might change slightly in new library installs. M2U values that match specific hardware specifications have not been changed.*
- Changed how the globals “Back Width Adjustment” & “Back Height Adjustment” behave when they are both used together with Full Applied backs. The back sizes will adjust, however the X & Z origins will remain flush with the left side and bottom of cabinet. This will prevent any associative screw hole machining issues.
- All drawers updated to use "G!Drawer_Bottom_Hole_Depth" for the Bottom Hole Depth instead of a fixed value.
- Wood Drawers now use "G!Drawer_Box_Dowel_Target_Spacing" instead of "VLOOKUP(PARTMACHINEY(),G!LookupTableTargetSpacingDowels,2,TRUE)"
- Default value for "G!Drawer_Box_Dowel_Target_Spacing" changed to "UCN(3.7795,96)"
- For Solid Wood Drawer fronts, Stiles and Rails will now be the same width by default.*
Resolutions General
- Resolved the Solid Wood Door "Add Finish Label" prompt to match Finished Faces subassembly. The prompt will now correctly display one label per product when global “Finish Label Condition” = “Product”.
- Resolved an issue with all Finished Face/MV Profile Door/Solid Wood Door subassemblies referencing an incorrect column in the Door Wizard "D!LookUpTableDoorStyle" table. Various parameters such as “Default Top Rail Width” will now correctly reference the Door columns when it’s a door and the Drawer columns when it’s a drawer front.*
- Resolved an issue with the Hettich WingLine Guide hardware graphics. Should no longer cause issues with the Flatshot feature.
- Added a 140mm option to the Hafele Alto drawer system for the NZ region.
- Resolved a Hinge Plate issue for right hand doors in corner diagonal cabinets.
- Resolved an issue with Base Under Counter Oven product that was affecting the bottom Facia.
- For Solid Wood Drawer fronts, corrected "Use Single Solid Wood Front SA" so it will not reference the Min Door Height (column 13) when it's a drawer front.
- Resolved an issue in certain subassembly insert components that were incorrectly displaying Fixed Shelf Qty prompts when bay 2 was set to Adj Shelf.
- Resolved a machining issue in all Corner Cabinet’s right-side backs. Dado tokens were missing a value for parameter 5 Dado Thickness. This seemed to only affect users using a Saw.
- Resolved an issue when using Buyout Doors. Default buyout material used is no longer zero thickness.
- Added the option for Interior Components to reference Frame Opening vs Box Opening. When selected, certain interior inserts will reference the Face Frame Opening Height instead of the Interior Cabinet Height, allowing them to be centered in the frame opening.
- Resolved an issue within some Office Drawer Cabinets.
Microvellum Foundation Library Release Notes | Build 24.0419
The following release notes apply to Microvellum Foundation Library, Build 24.0419
Additions
- Added the new Blum SPACE STEP system. This can be activated within the “Toe Kick Assembly” construction option prompt in certain base & tall cabinet products.
- Added a new drawer system, the Harn Alunan T.
- Added 9 new Lamello Cabineo X hardware Edge Array options:
- Lamello Cabineo X Flush 12
- Lamello Cabineo X Flush 8
- Lamello Cabineo X Flush Shelf Support 5mm
- Lamello Cabineo X Flush With Cover Cap 12
- Lamello Cabineo X Flush With Cover Cap 8
- Lamello Cabineo X Flush With Cover Cap Shelf Support 5mm
- Lamello Cabineo X Overlay 12
- Lamello Cabineo X Overlay 8
- Lamello Cabineo X Overlay Shelf Support 5mm
- Improvements & additions have been made to the cabinet Shadow Rail feature.
- All updated to work with a backing rail.
- The prompt “Add Wrapped Batten” in all products has been changed to “Add Backing Rail” to avoid confusion with the main Wrapped Batten feature.
- Added the ability to have the backing rail in-between the cabinet sides.
- Drawer Stretchers will now sit behind the shadow rails.
- Added SEARCH functions to look for "L-Shape", "Solid Rail" and "Batten" If the name of the profile has "Solid Rail" in the name it will use machinable parts. If "Batten” is in the name, it will change the backing rail to a wrapped batten. If the name has "L-Shape" it will turn on parts to create an L-shaped shadow rail. With this setup, users can easily create their own shadow rail features by adding rows to D!LookUpTableShadowline.
- Added three new Shadow Rail profile styles:
- L Shape Solid Rail with Backing Rail
- Gola Standard
- Gola Zero Radius
- Mounting clips added, and 3 new columns to the lookup table in the door wizard for the position of the clip and the type.
- Added two additional Sink Faucet options.
- Added a new global variable, “Use Simple Face Frame”. This will now turn on a simple face frame when the doors are inset and “G!Inset Door Setback” is less than 0.
- Added an appliance panel option to the Fridge product. Note that the default sizes are generic and will need to be modified to match appliance manufacture’s specs.
- Added a double Facia (False Front) feature to all Sink Cabinets, the Master Cabinet, and several other base cabinets.
- Added a new frameless master cabinet: Master Split Height Designer Cabinet.
- Added six new global variables to control the inset backs left and right on corner cabinets:
- “Base Left Corner Inset Back”
- “Base Right Corner Inset Back”
- “Tall Left Corner Inset Back”
- “Tall Right Corner Inset Back”
- “Upper Left Corner Inset Back”
- “Upper Right Corner Inset Back”
- Added a new global variable, “Thick Backs Top and Bottom Use Default Construction Method”. With this selected, the top and bottom machining on thick backs will look at the default Construction Method Top and Construction Method Bottom. This will address certain challenges that are encountered when configuring cabinet back machining when the method differs from the carcase machining.
- Added the "Use Aluminium Handles" prompt to all products with handles. Previously this was only able to be activated from the Door Wizard.
- Added a Library Change Log to a worksheet in the Factory workbook. This can be used to track & document custom library changes and/or feature requests. Also useful for MV technical support agents or service providers to review information about your library.
Modifications
- Modified the “Cabinet Leveler” feature inside the Notched Toe Kick subassembly. Materials for “EZ Level” have been renamed and the SA info has been updated to better reflect the needed hardware quantities and names for ordering.
- Drawer Divisions within Door/Drawer cabinets will now only contain horizontal dowel/screw holes where they meet up with stretchers above or below.
- Modified the "Internal_Profile_Lead" location inside center pocket tool path of MDF Profile Doors. Lead in should no longer interfere with the rail detail in small doors/drawer fronts.
- Toe kick assembly boxes have been updated to look at the global variables "Toe Kick End Offset", "Toe Kick Finished End Offset" and "Toe Kick Back Offset". Added new global variables for the Adjustable Leg subassemblies as they were looking at the Toe kick offsets. New global variables have been added:
- “Adjustable Leg End Offset”
- “Adjustable Leg Finished End Offset”
- “Adjustable Leg Back Offset”
- Updated the hinge plate setback as well as the door reveals in the Diagonal and Transition cabinets. Default results should be improved in these scenarios.
- Resolved issues when adding a Component Door insert into an opening.
- The Prompts "Is_DivisionLeft", "IS_Division_Right", "Is_Shelf_Top", "Is_Shelf_Bottom" are now visible prompts on the Construction Options tab.
- The Prompts "Left_Hinge_Overlay" and "Right_Hinge_Overlay" have been updated as well as the "Left_Reveal_Overhang" and "Right_Reveal_Overhang". The overlays will now calculate correctly when changing the Left and Right hinge overlay types. Previously the “Hinge_Overlay” and “Reveal_Overhang” prompts were disconnected with one another.
Resolutions General
- Resolved numerous issues and inconsistencies with all drawer system subassemblies. Reviewed, compared, and conducted extensive testing within each drawer subassembly. Some items addressed (not a complete list):
- Resolved issues with switching between back over bottom and back around bottom construction.
- Reduced complexity of (Space_Required_Under_drawer_Bottom) Formulas, verified they were subtracting (Reduce_Bottom_Thickness)
- All Drawer Systems now contain 3SIDEDCUTOUT for center notch function.
- All drawer system bottoms that receive rout machining to size the thickness are now using a 4-sided cutout token on the part instead of an associative Dado token from a phantom part. This solves some reported Toolbox post processing (nesting) issues.
- Many other issues resolved.
- Global "ADA Sink Toe Kick Options" category no longer missing from Library Update.
- Resolved an issue with sink cutout graphic not displaying in 3D.
- Resolved an issue with Extruded Toe Kick Base when used on a 90° blended radius.
- Resolved a misspelled prompt in Drawer Stretcher subassembly (Strectcher Width).
- Resolved issue with applied finished ends not displaying in 2D elevation view of product. Also corrected elevation dimension that occurred in certain circumstances.
- All Extruded Products using legacy "G!Default_Routing_Tool_CW" variable have now been updated to use "G!Default_Cutting_Tool".
- When certain adjacent cabinets were processed together, Perfect Grain Container errors would sometimes appear. This was due to the system trying to perfect grain match all the adjacent panels onto the same container and exceeded the size of available sheet stock. To prevent this, all designer cabinet products now have their “Perfect Grain Container” option defaulted to “None”. Users will be able to set the “Perfect Grain Container” as needed.
- When adding glass to the MV Profile Door, the layer name used has been corrected to “Door_Glass”.
- Resolved issue in the Component Drawers subassembly that affected the “Left/Right Reveal” variables.
- Adjusted the IF PEANUT 3 Invisible Fastener machining to match manufacture’s specifications.
- Resolved an issue in Open End cabinets. Dowel/Screw machining will no longer be missing in certain conditions.
- Resolved an adjustable shelf line bore hole issue inside Transition Angle cabinets when back machining was required with Continuous Shelf Holes option selected.
- Resolved a 2D cross section dimension detail when changing the door bottom reveal.
- Resolved a small calculation issue inside the Cost Based Reports related to the waste factor.
- Changed the behavior within Face Frame cabinets wherein changing End Condition to “Applied End” or “Face Frame” the side face frame overlay control will switch to “Outside Control”.
- Updated the Face Frame subassembly to include the "Left_Stile_Scribe_Amount" and "Right_Stile_Scribe_Amount" in the stile size and the overall dim within the automated generated 2D Face Frame image and 2D elevation drawing of products.
- Applied Panel FF will now extend in the correct direction when using the “Extend Front Edge” prompt.
- Added additional global variables to better control the desired Cleat options.
- “Closet Top Cleat”
- “Closet Center Cleat”
- “Closet Bottom Cleat”
- “Closet Individual Cleats”
- “Closet Full Cleats”
- “Closet Full Top Cleat”
Microvellum Foundation Library Release Notes | Build 24.0322
The following release notes apply to Microvellum Foundation Library, Build 24.0322
The following release notes apply to Microvellum Foundation Library, Build 24.0119
