Product Prompts Drafting Tab
Many of the drawing instructions for products can be modified through the Product Prompts. To modify, click on the Product Prompts icon and select a product. Click to access the Drafting tab.
- Item Number Controls – Allows you to change the placement of the product item numbers, both in 2D and 3D views.
- AutoCAD Layers – Allows you to override the layers to be used for the 2D product elevation.
- AutoCAD Labels – Allows you to adjust the settings for color labels added to the 2D product elevation.
- Product 2D Elevations – Allows you to override settings that pertain to text and dimensions used for the 2D product elevation.
- Product 2D Sections – Allows you to override settings for section drawing instructions.
- Product 2D Plan View – Allows to you make adjustments to plan view dimension settings.
Related Articles
How to Modify Multiple Products using Edit Multiple Product Prompts
Multiple products can be modified using the Edit Multiple Product Prompts function. You can access the prompts for a product by right-clicking in the Draw Products window, or by selecting the Modify tab in Toolbox and selecting the Edit Multiple ...
How to Modify a Product through the Prompts Interface
Modifying a Product Through the Prompts Interface Once a product has been placed in a drawing, the Product Prompts interface will display. Specification Group Name – Allows you to assign a specification group to a product. Prompt Tabs – Switch ...
How to Modify Subassemblies through the Prompts Interface
The majority of the library products contain subassemblies. Subassemblies are simply products within a product. They contain their own set of prompts that are accessible by selecting Subassemblies from the menu located in the top left corner of the ...
Dynamic Product Images
Dynamic Product Images Dynamic Product Images are a compilation of Toolbox’s internal FLATSHOT (or metafile) tokens. These tokens allow you to create multiple views of a product quickly. Most of the library products, by default, contain two “sheet ...
Modifying Walls Using the Prompts Interface
Modifying Walls using the Prompts Interface You can access the prompts, for a wall, by right-clicking in the Draw Room Components window. You can also select the Modify tab in Toolbox and select Properties under the Modify Room Components menu (or ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 26.0527
Adding Custom Hinges and Mounting Plates (Foundation Library)
Hinges and mounting plates are classified as hardware items within the Foundation library, and as such, the process for adding hinges and mounting plates does not differ greatly from other pieces of hardware, though with the variety of cabinet ...
Apply Render Materials
The Apply Render Materials interface is a Microvellum function that allows one to assign specific render materials to database materials within one’s material library. Using this interface, one can efficiently control and visually align one’s ...
Microvellum Release Notes | Build 26.1.0520.641
The following release notes apply to Microvellum build 26.1.0520.641. Assign Render Material A new option has been added to the Library Specification Groups interface: Assign Render Material. This new interface displays the Microvellum material ...
