Toolbox Release Notes | Build 21.2.0111.641
The following Release Notes apply to Toolbox Build 21.2.0111.641
Scrap Management
Resolutions:
Resolved an issue that was causing the Offal Cutting pattern to cut into rounded parts.
Saw Optimizer
Resolutions:
Resolved an issue where the PTX output did not match the results in the optimization report.
Part Processing
Modifications:
- Modified the output of the tool file filename to include the full filename on all parts for Point-to-Point Part Stations regardless of the type (spreadsheet or IPP).
Resolutions:
Resolved an issue where unwanted characters (carriage return, line feed, tab, commas within variables, quotation marks in variables) were being inserted into the .PTX output.
Project Wizard
Resolutions:
Resolved an issue where Project Wizard Find and Replace did not revert on close.
User Interface
Resolutions:
Resolved issue where double-clicking "OK" when launching Find and Replace to copy a Specification Group would create duplicate Specification Groups.
Include Routes In Borders (IRIB)
Resolutions:
Resolved an issue when checking for a square pocket, the original route was allowed to be changed even if it wasn't a pocket.
Materials
Resolutions:
Resolved an issue causing the find and replace in a project's material file to change the template's material file.
Resolved an issue after copying/moving to a different category, then renaming materials, sometimes the name change was not maintained.
