Toolbox Release Notes | Build 22.1.0406.641
The following Release Notes apply to Toolbox Build 22.1.0406.641
Database Management
Resolutions:
- Resolved an issue that caused template level projects to be deleted when deleting a seemingly “empty” category (this was caused by a mix-up in the LinkIDCategory when importing an existing library).
Subassemblies
- Resolved an issue where in rare circumstances, 'save subassembly to library', saved to a unique subassembly instead of the correct library subassembly. Any who have experienced this just need to save the subassembly back to library again.
Modifications:
- When subassemblies are renamed when saving, the UI has been improved to predict and/or suggest the best naming of subassemblies.
Product Prompt UI
Resolutions:
- Resolved an issue that was allowing combo box lists to be scrolled through on hover with the mouse wheel.
Project Properties
- Resolved an issue where multiple edits made in the material wizard tabs of Project Properties were not saved.
Processing Center
Resolutions:
- Resolved a grammar inconsistency in the processing center.
Machine Tokens
- Resolved an issue where entering 6 options for parameter 4 of the pline token would result in the token being drawn even when machine only was selected with option 1.
Modifications:
- Modified the Dado token parameter option 1 help text to be more accurate.
- Resolved an issue that resulted in missing .dat files when “Run Face 6 First” was selected.
- Resolved an issue where FIGREFs were duplicating for larger work orders.
