The following Release Notes apply to Toolbox build 23.1.0821.641
Dado Machine Token Fixes
A number of reported issues with Dado Machine Tokens have been examined and resolved.
- It was reported by users wherein they were unable to prevent associative dados from ramping during nesting, leading to incorrect measured values in the G-code. This issue has been resolved.
Figure 1: Dado lacking lead-in when ramping.- There was an issue wherein dado machine token would be unable to generate a lead-in when ramping. This issue has been resolved.
Figure 2: Lip groove issue.- There was a noted issue wherein dado lip grooves would be placed incorrectly when a lead-in or lead-out was changed in the drawing process. This issue has been examined and resolved.
Figure 3: Dado shifting in machining.- There was a noted issue wherein dados would shift in position during processing, leading to incorrectly calculated G-Code and misplaced machining. This issue has been resolved- dados should now remain in their set position without issue.
- Users reported an issue during machining, wherein dados would not double pass when a double pass was placed in the order being processed. This issue has been resolved.
Before | After |
Figure 4: Dado incorrect ramping on single pass. | Figure 5: Dado single pass ramping fixed. |
- Users noted an issue when dados were set to ramp in a single pass route, wherein the dado would ramp incorrectly.
Processing Fix
Figure 6: Extra G-code issue.- There was a reported issue that occurred during processing, wherein users who had the "Run Face 6 First" setting disabled while having "G-code Combine Type" set to "Singlehead" in the Toolfile would have their G-code populate the output file with the optional stop text and an extra footer added, regardless of whether they enabled the additional text or not. This issue has been resolved.
New Thermwood Post-Processor
- A new post-processor has been created for the Thermwood machine nesting Toolfile.
