New System Variables | Description |
DX12FRAMERATEUNLIMITED | Enables variable sync monitor optimization. |
HPDRAWMODE | Controls the drawing mode used when defining new boundaries to hatch or fill. |
HPPATHALIGNMENT | Specifies the alignment of new drawn paths to be hatched or filled. |
HPPATHWIDTH | Specifies the width of new drawn paths to be hatched or filled. |
Updated Commands | Description | Changes |
DATAEXTRACTION | Extracts drawing data and merges data from an external source to a data extraction table or external file. | New data extraction templates are stored in the DXEX file format and are not compatible with AutoCAD 2024 and earlier releases. |
HATCH | Fills an enclosed area or selected objects with a hatch pattern, solid fill, or gradient fill. | Draw boundary option was added. |
OPEN | Opens an existing drawing file. | Improved file open performance when opening a drawing that contains large numbers of annotation scales. |
PAN | Shifts the view without changing the viewing direction or magnification. | General performance improvements. |
ZOOM | Increases or decreases the magnification of the view in the current viewport. | General performance improvements. |
System Variables | Description | Change |
TRUSTEDDOMAINS | Specifies the domain names or URLs from which AutoCAD can run JavaScript code. | Removed. |
