Microvellum Foundation Library Release Notes | Build 23.0828
Additions
  1. The Lamello hardware below has been added to the hardware array as options.
    1. Lamello Cabineo 8 Flush
    2. Lamello Cabineo 8 M6x12.3 Flush
    3. Lamello Cabineo 8 M6x15.3 Flush
    4. Lamello Cabineo 8 Flush With Cover Cap
    5. Lamello Cabineo 8 M6x12.3 Flush With Cover Cap
    6. Lamello Cabineo 8 M6x15.3 Flush With Cover Cap
    7. Lamello Cabineo 8 Overlay
    8. Lamello Cabineo 8 M6x12.3 Overlay
    9. Lamello Cabineo 8 M6x15.3 Overlay
    10. Lamello Cabineo 12 Flush
    11. Lamello Cabineo 12 Flush With Cover Cap
    12. Lamello Cabineo 12 Overlay
    13. Lamello Clamex P-10
    14. Lamello Clamex P-14
    15. Lamello Clamex P-Medius 14-10
    16. Lamello Clamex P-Flexus 14-10
  1. Added several OVVO fixing hardware to the hardware array as options.
    1. OVVO OD830
    2. OVVO RD9 with V-0930RH
    3. OVVO RD12 with V-1230RH
    4. OVVO RD12 with DH1
    5. OVVO RN12 with DH1
    6. OVVO PN12
    7. OVVO RN12
  1. Added two new global variables to reduce full applied cabinet back widths & heights.
    1. "Back Width Adjustment"
    2. "Back Height Adjustment"
  1. Added a Cabinet Cutout subassembly to all base and master products in both the Frameless and Face Frame categories. This can be turned on through a prompt under the Construction tab called “Full Top Cutout”. This subassembly can create cutouts in the top, bottom, left side, and right side. The cutouts can be split into 1,2,3, or 4 cutouts for each side. A custom calculator is included to control the location and spacing of the multiple cutouts. A special 3D block is added to cabinets using this cutout (lower left of opening). The block can be used to quickly select the subassembly’s prompts for making changes.
  1. Added two new global variables to give users the option to omit the 3D drawing blocks for Drawers, Pullouts, and Waist Bins. This can be a good way to speed up Toolbox performance if you have large drawings with many products.
    1. "Draw Hardware Blocks For Pullout"
    2. "Draw Hardware Blocks For Drawers"
  1. Added a global variable "FE Flush To Door Face". When this is ticked on the Applied End subassembly will default to the "Thickness_Door+Door_To_Cabinet_Gap." When unticked the applied panels will look at the "FE Panel Overlay" for the front extension. "FE Panel Overlay" has been set to 0 as default in the template.
  1. Master Split Cabinet - Added the ability to add a double center shelf at the split. This has been achieved by adding a function to the vertical splitter to have a double shelf. Each shelf has the option to reverse the machining from the bottom face to the top face if needed such as cams or dados.
  1. The Bead Option for outside of Face Frames has been added to the Split Height Designer FF cabinets.
  1. Added the ability to specify the Splay Handle Position and J Profiles. This feature has been added to the finish faces and MV Profile door subassemblies. You can now select the top, bottom, or vertical edge.
  1. Added categories for Tall Corner Cabinet Accessories and Upper Corner Cabinet Accessories. Split the master Corner Filler With Cleats product into the Base, Tall, And Upper Corner Cabinet Accessories folders.
  1. Added global variable “Shelf_Support_Fixing_Drill_Front_Only” for conditions that only require a front fixing drill at adjustable shelves.
  1. Office Furniture Mobile Cabinets - The "Toe Kick Height" will now match the selected caster height. The formulas have been written to check the hardware to see if there is a size at the end of the name. This will then set the height to the castor height. For example: Twin Wheel Castor_67mm
Modifications
  1. All barcodes in reports have been changed to use the Barcode field.  The product label has also been updated.
  1. Made a number of general improvements to the Dishwasher product.
  1. Gallery rails have been added to the Harn Ritma Cube drawer system.
  1. Changed how Inner Drawers (Rollouts) locations are calculated. Added a "Top Gap" variable for the distance between the top drawer and the top of the opening as well as a gap between the drawers. This is independent from the drawer heights.
  1. Updated Lockdowel hardware to include part numbers in their names.
  1. Applied Panel subassembly will now look at parent product for "Edge Top" & "Edge Bottom" prompts values.
  1. The Drawers subassembly has been updated to match the Component Drawers subassembly.
Resolutions
  1. Resolved an issue with the Z origin for the lift-up handle in all Door subassemblies for the 2D cross-section draw tokens.
  1. Resolved a hardware association issue that sometimes appeared when changing the door material to be a thinner material. Refactored the formulas affecting handle & lock associating to doors and drawer fronts. These now have a greater tolerance when drawer fronts are a different thickness than doors.
  1. Resolved a drilling issue inside the DTC Dragon Pro Drawer.
  1. Updated the imperial drawing template to prevent the inch symbol from appearing on angular dimensions.
  1. Added the missing dwg graphics for 249mm Richelieu Optimiz-R sides.
  1. Added E pure and F side graphics for Blum MERIVOBOX used in New Zealand region.
  1. "Left Filler Width" and "Right Filler Width" cabinet prompts will now display their help images.
  1. Resolved a machining issue that affected rear cabinet modification features in Open cabinets. Also resolved another issue that affected Divisions, Pigeon Holes, and the Horizontal Splitter subassemblies.
  1. Resolved an auto screw drilling issue within the Toe Kick Assembly Base.
  1. Resolved an issue with Cam Lock machining holes at drawer divisions. The rear machine tokens will now look at small part threshold for the drawer divisions.
  1. The "Bottom Hinge" prompt in the Component Doors subassembly was incorrectly hidden. This is now a visible prompt.
  1. Resolved a 3D origin issue with glass doors within the Generic Five Piece Door when used as a sliding door.
  1. Global "Name_Filter_Pulls” has been updated to prevent handles from associating to the incorrect parts in corner cabinets.
  1. Resolved an issue with the "J Handle Route" not appearing on the left swing tall doors.
  1. Resolved an issue with MV Profile Door’s Edge Profile Lead.
  1. Resolved an issue with Base Drawer Sink With False Front when selecting one drawer.
  1. The Component Drawer subassembly will now look at the local product for the drawer type setting. This previously affected a number of products such as Base 1 Drawer Microwave.
  1. Corrected a misspelling typo that caused an issue with the Pelmet subassembly.
  1. Resolved an issue with split back sizes within the Master Split Height Designer Cabinet.
  1. Resolved an issue with Front Rails when changed to a vertical rail and the material is a different thickness. Dado tokens will now look to "M!Sub_Front_Thickness" when the rail is set to vertical.
  1. Resolved an issue that caused solid wood drawer parts to appear in the face frame flat-shot feature & reports.
  1. Resolved an issue with Base Applied Back Panel product. "Applied Ends To Floor" feature will now function properly.
  1. Resolved an issue within the Base 6 Drawer Cabinet that affected the drawer calculator.
  1. Resolved an issue within the Master Any Angle Cabinet when using the "Cabinet Void" feature.
  1. Resolved an issue with the Component Pocket Doors subassembly. Parts will filter in accordance with the face option selected ("Left Swing", "Right Swing").
  1. Resolved an issue with the Component Door Drawer FF that sometimes caused incorrect door sizes.
  1. Resolved an issue within the Internal Drawers with Faces subassembly insert that could cause incorrect drawer locations.
  1. Resolved an issue within the Component Drawers subassembly that triggered when the split drawers feature was used. The vertical gap will now be correct when it’s different from the horizontal drawer gap.
  1. Resolved an issue in solid wood door so center panel 2D elevation tokens will not draw when "Door_Construction"="Single Panel".
  1. Corrected the help image for the Vauth Sagel Cornerstone Maxx Blind Corner Pullout. Also created a help image for the Kessebohmer LeMans II pullout.
  1. Office Furniture Master Desk - The left and right pedestal parts are now correctly turning off when selecting the left or right leg. An issue with the kick face origin has also been corrected.
