Toolbox Release Notes | Build 23.1.0313.641
Label Images
Resolutions:
  1. Resolved an issue with PTP stations not flipping the face 6 WMF image correctly. WMF orientation should now match the gcode.
  2. Resolved an issue with Unified Work Order databases not writing the face 6 image to the database correctly.
  3. Resolved an issue with file names being duplicated in certain products and when multiple people were all working in the same configuration.
Subassemblies
Resolutions:
  1. Drawing a nested subassembly in 2D will no longer cause the hardware to change position.
  2. Resolved an issue when trying to assign mapped parts if there were multiple library-level subassemblies.
  3. Resolved a refresh issue in subassembly prompts when attempting to save back to the project.
  4. Certain workflows will no longer cause new library-level subassemblies from appearing on the list.
Processing Center
Resolutions:
  1. Resolved an issue with the UI grid that caused sorting to be slightly wrong in some cases.
  2. The ‘Convert to Metric’ setting no longer causes an error when processing on a PTP station with transposed dimensions.
Hardware Machine Token
Modifications:
  1. We have added a new feature that will update hardware machine tokens in your project from the template. More information here.
