Toolbox Release Notes | Build 23.1.0801.641
The following Release Notes apply to Toolbox build 23.1.0801.641
Horizontal Drilling Cam Locks Fix
  1. There was an issue wherein the horizontal drilling for cam locks would not calculate different Z location values for parts with face 5 and face 6 machining, if the two were enabled simultaneously. This issue has now been resolved; the values should now place the tokens correctly.
IPP Post Fix
Figure 1: Maestro IPP bug; 0's generated
  1. An issue was reported when utilizing a Maestro IPP Toolfile, wherein zero values were generated when using “Create New G-code”. This issue has been addressed and resolved; the G-Code should now match the entered values instead of generating 0’s.
Stay-Down Path Fixes
Before
After
Figure 2: Stay Down connector arc angle issue.
Figure 3: Stay Down connector arc angle fix.
  1. Stay-down connector arcs were sometimes noted to look visually incorrect in terms of their angling. This has been addressed and resolved; arcs have been tuned to be visually smoother for machining.
Figure 4: Stay down path counterclockwise bug.
Figure 5: Stay down path counterclockwise fix.
  1. Stay down paths would sometimes read as incorrect if the border direction was counterclockwise. This has been resolved; the paths should be read as correct now.
Figure 6: Transition radius increase
  1. There was a noted issue with certain machines tending to have errors occurring during a transition, even though the machine could technically make the cut. The issue has been addressed and resolved with an increase to the transition radius, being set to be larger than bit diameter by .001.
MCOR/IRIB Fix
Figure 7: MCOR/IRIB alignment bug
Figure 8: MCOR/IRIB alignment fix
  1. An issue was reported in the metric build of Toolbox, wherein routes and corners alignment in certain nest patterns did not align properly, due to MCOR and/or IRIB not calculating correctly. The issue has been resolved.
