Toolbox Release Notes | Build 24.1.0913.641
The following release notes apply to Toolbox build 24.1.0913.641
Copying Fix
Issues were reportedly occurring when users attempted to copy projects and rooms:
  1. When attempting to copy a and move a project, it was sometimes the case that products being redrawn in 3D after importing would cause the software to crash or an error would occur, usually while drawing the product’s plan view.
  1. When copying a room and redrawing the products and components from the original room, multiple room components (such as walls) would be missing from the data or fail to draw.
  1. Both issues have been resolved, copied projects and rooms should no longer cause errors or crashes, and room components should no longer fail to carry over into the copy.
Factory Database Modification
  1. The Factory Database has received a modification: users will now receive a pop-up warning when their Factory Database is approaching its maximum capacity.
  1. This feature will function upon opening the software, which will query user databases to determine capacity size, then the amount of space currently used, and send an alert like the one above if the database is nearly full, to help users prevent any operational slowdown or data management issues, such as the overwriting of new projects.
  1. If your database is nearing its maximum capacity, it is suggested you create a backup of your database before deleting/exporting data using the Database Management Utility.
