The following release notes apply to Toolbox build 24.1.1105.641
Nesting Fix
Fig. 1: The fatal error that would occur during processing.- There was reportedly an issue that occurred when clients attempted to process a work order using the nesting processing station. When processing a work order and assigning stations to all parts, there was sometimes a fatal error (leading to a software crash) happening when the nesting processing station nears its completion (during Quantity Indexing).
- The issue has been resolved, though it should be noted that the error was difficult to test extensively, due to the problem being difficult to replicate. As such, if the issue is found to occur after updating, please report it to Microvellum by creating a general problem support case.
Database Size Warning Fix
- Users have reported issues with the database size limit warning pop-up implemented in Toolbox build 24.1.0913.641. Namely, regardless of the amount of space currently in use on one's database, the pop-up would appear repeatedly to warn users that their database was at 90% capacity.
- This issue has been resolved- the query being used to measure databases has been improved, resulting in more accurate estimation of when one’s database is low on available space. The warning message should thus only display when one’s database is nearing maximum capacity.
