Microvellum Foundation Library Release Notes | Build 24.0919
The following release notes apply to Microvellum Foundation Library build 24.0919
Additions
  1. Added 5 new special Wine Rack products and 9 new Wine Rack Insert subassemblies.
    1. Products:
      1. Master Vertical Wine Rack Corner Frame
      2. Master Vertical Wine Rack Frame
      3. Stemware Rack
      4. Wine Rack Diamond Stack
      5. Wine Rack Panel
    2. Subassemblies:
      1. Wine Bottles
      2. Wine Rack Display Divisions
      3. Wine Rack Divisions
      4. Wine Rack Lattice
      5. Wine Rack Nek Rite
      6. Wine Rack Vino Pins
      7. Wine Rack Vino Rails
      8. Wine Rack Vintageview Wall Series
      9. Wine Rack X
  1. Added three more Button-Fix connectors
    1. Type 1 metal
    2. Type 1 flush
    3. Type 1 bonded
  1. Added “LookUpTableDropDownSystems” LookUp Table to the Hardware workbook for drop-down door hardware. Added the following hardware:
    1. Hafele Flap stay with pull cable A Anthracite
    2. Hafele Flap stay with pull cable A Black
    3. Hafele Flap stay with pull cable A Matt Silver
    4. Hafele Flap stay with pull cable A White
    5. Hafele Flap stay with pull cable A Silver Gloss
  1. Added a left and right dowel offset to the Shelf Fixed and Vertical Splitter subassemblies.
  1. Added additional material pointers for MDF Profile doors, drawers, and applied ends so they can automatically default to a different material than the Finished Faces doors.
Warning
IMPORTANT NOTE: This will require users who update their libraries to assign a material to the new pointers.
    1. Base_MDF_Door
    2. Tall_MDF_Door
    3. Upper_MDF_Door
    4. Base_MDF_Drawer_Front
    5. Tall_MDF_Drawer_Front
    6. Upper_MDF_Drawer_Front
    7. Base_MDF_Applied_Ends
    8. Tall_MDF_Applied_Ends
    9. Upper_MDF_Applied_Ends
  1. Added new subassemblies Flatshot Instructions & Flatshot Corner Instructions. Global variable was added to control the names of the subs "Flatshot Instructions Name". This allows users to name their own custom flatshot Instructions subassembly, so it won’t get overwritten during updates. Removed all flatshot tokens from all products. Also added global variable "Flatshot Parts Filter".
  1. Added two global variables for more control over the Wrapped Batten size and screw locations.
    1. "Screw Distance To Edge Wrapped Batten"
    2. "Wrapped Batten Width"
  1. Overhauled the Pelmet product. Added the ability to angle the left and right returns and extended returns. Updated product rendering.
  1. Added additional functionality to the Upper Rangehood Cabinet.
  1. Created a new cabinet mod “Center Ducting Box”.
  1. Created an option to have a full one piece back. This makes it easier to locate a stud when installing the cabinet.
  1. Added Solid Wood Handle option that apply to the face of the cabinet doors. To achieve this, we utilized the Aluminium Handle option. By entering a value inside the added column in "D!LookupTableAluminiumHandles", this will tell the system to face mount the extruded molding. Added a sample option: “Timber 30mm x 20mm Handle”.
  1. Added Tip-On feature to Blum MERIVIOBOX. Added hardware material “Blum Tip-On Blumotion Set For MERIVOBOX”.
Modifications
  1. Improved the Hawa Concepta III Pocket Door product:
    1. It can be added to any cabinet product as a subassembly.
    2. Several redundant prompts were removed, as they were needed only in a product, not a subassembly.
    3. Removed the parts and referenced them to the middle pocket.
    4. All the door offsets were set from the left side. Now created offsets for the right door.
    5. Removed the double door options, as this is not an option yet.
  1. Changes have been made to the Mitered End Panel and Mitered Shelf products. You can now change the grain direction for both the faces and the ends. The Thick Panel Assembly subassembly has also received improvements.
  1. Improved the 2D Instructions subassembly. The subassembly will now function more reliably in other “non-cabinet” products.
  1. Modified the ADA Sink Angled Frame product. "Sub Front" will now align top and bottom with the sides.
  1. Added the "ElvNoDim" prompt to all miscellaneous products that were lacking it. This gives better control on removing unwanted 2D elevation dimensions.
  1. Modified all Toe Kick Base products to look at global “Construction_Method_Toe_Kick” instead of “Default_Construction_Method”.
  1. Modified Blum straight mount hinge plates so they setback 20mm from first hole to face of the cabinet. This was done by adding the @ function to the name to move the plates forward. Renamed 4 hardware materials:
    1. Hinge Plate BLUM Straight 0mm Expando@36mm
    2. Hinge Plate BLUM Straight 0mm Knock-In@36mm
    3. Hinge Plate BLUM Straight 0mm Screw-On@36mm
    4. Hinge Plate BLUM Straight 3mm Expando@36mm
Resolutions General
  1. Resolved an issue with Toe Kick Assembly Box when the cabinet has a Finished End. Sleepers will now be correctly located in X.
  1. Resolved an issue with all pull-out subassemblies that prevented some drill machining from appearing on the nest patterns. The machining dummy parts have been split out to have a part per row of machining. They are no longer using the Part_Thickness column, which was causing the issue.
  1. Resolved an issue with Solid Wood and Profile doors that caused the right hinge to be missing on diagonal cabinets.
  1. Resolved an issue with Elev View DRAWDIM tokens. The tokens were referencing "G!Elevation_Height_Dimension_Offset" instead of "G!Elevation_Width_Dimension_Offset", as they were intended to.
  1. Updated ENKO Slimbox drawers to match manufacturer’s specifications.
  1. Resolved an issue with the Hettich InnoTech Atira drawer system gallery rails.
  1. Resolved an issue with Grass Zargen drawer system. Correct drawer heights are now used for all opening heights.
  1. Several improvements and corrections were made to the Blum REVEGO folding door system.
  1. Resolved an issue with Folding Door Hinges. Changing hinge type will now change the subassembly and also have the correct rotation offset from the door edge.
  1. Resolved an issue with Blum Hinge Plate Straight mounts. Drilling now starts at 20mm from front of carcass. In order to achieve this, the hardware materials are now using the “@” symbol to move the plates forward.
  1. Resolved an issue with Pie Cut Corner Cabinets, which occurred when they were used with the Shadow Rail option and a full top or overlay top.
  1. Resolved an issue with the “Master Cut Report – Batch”. Sq Meter quantity will now be correct.
  1. Resolved an issue with internal subassembly insert “Divisions”. Parts will now notch for shadow rail option.
  1. Resolved an issue with the Hafele Matrix Box S drawer. Bottom length corrected.
  1. Resolved an issue with hinge plate locations when using Full Inset Doors.
  1. Resolved an issue with edge array tokens on cabinet thick backs that involved the mirrored edge.
Additions/Resolutions Office Furniture
  1. Added Left Hand/Right Hand options to the Blended Locker product.
  1. Added 2D elevation dimension tokens for each frame opening height and width. Global variable added to control the option: "G!Face_Frame_Opening_Dims_Elv_View".
  1. Resolved Drawer Front Calculator issue in the Base 3 Drawer Split Top FF & Base 4 Drawer Split Top FF.
To download this build, visit the Foundation Library Downloads Page.
