Microvellum Foundation Library Release Notes | Build 25.0124
The following release notes apply to Microvellum Foundation Library build 25.0124.
Additions
  1. Added Century Components Waste Bins, Vanity Organizers, and Base Cabinet Organizers.
  1. 11”, 14”, 17” Signature Series Bottom Mount 34qt & 50qt.
  1. 4”, 5”, 6”, 9”, 12” Cascade Series Base Cabinet Organizers.
  1. 9”, 10.5” Vanity Grooming Organizers.
  1. Added Rev-a-Shelf Tip Out Tray option for Top Facia (False Front) conditions. Includes 42 new material variations with 3D graphics, codes, and pricing. Currently this is facilitated as a drawer type option.
  1. Added Nikpol Teramo Bins for AU/NZ regions.
  1. Added a new cabinet modification option, “Cabinet Split Back”. Features include:
    1. Split Height/Split Width.
    2. Regular Backs and Thick Backs.
    3. Split Nailer option.
    4. Center Distance to Center variable.
    5. Variable to set a distance between the backs.
  1. Added Top Filler options to all Corner cabinets. Options include Top Scribe Filler|Top Scribe Return Filler|Top Soffit. Subassemblies have been added for all options. Also added the framework for the Soffits as a nested subassembly.
  1. Added a new global variable, "Add Elevation Depth Label" and linked it to the 2D Instruction subassemblies.
  1. Added a new global variable, “Add Drilling For Wrapped Battens” and linked it to the construction holes in all products.
  1. Added "Add Top Facia" or False Front option to each bay of Horizontal Designer cabinets.
  1. Added the Force Grain Direction prompt variables to Soffit product and subassembly.
  1. Added Component Pocket Doors to all the internal options prompt list “Component Insert”.
  1. Added "Vertical Front Rail Setback" as a global feature and linked it to the origin of the front rail in all relevant products. This can be especially helpful when using 3mm edgebanding when the need arises to set the rail in from the face.
  1. Added "Vertical Front Rail" as a global feature and linked it to the local prompt in all relevant products.
  1. Added the ability to globally edit part names of drawer system bottoms and backs.
  1. Added 2D elevation & section dwg representations for Institutional Hinges.
  1. Added additional drawer heights for DTC Dragon Pro (209mm & 238mm).
  1. Resolved an issue with Extruded Die Wall products. Curved Outside/Inside Stacked Skin option will now calculate the correct size & position when using more than one skin.
  1. Valance Prompt Options will now appear for Tall and Base cabinets.
  1. Resolved an issue in Strip Lighting Insert that sometimes affected the groove nest machining location in Metric configurations.
  1. Resolved an issue with Shadow Rail feature when used in Horizontal Designer cabinet with a Vertical Front Rail. The top-notch for the Vertical Front Rail will now include the depth of the Shadow Rail. Additionally, the shadow rail notch will be turned off if the "Vertical Rail Width" exceeds the height of the Shadow Rail.
  1. Upper Microwave Cabinets will now follow the same rules when determining the material pointer for the cabinet bottom (referencing “Bottom Finished” option).
  1. Updated a formula inside the Cost Based Estimating Report to match the Shop Quote report.
  1. Resolved an issue with Glass Door option, when selected inside a Finished Face when it’s a Liftup Door. X Location of glass will now be correct.
  1. Resolved an issue in Component Doors subassembly where the Door Stay Left & Right prompts were incorrectly hidden from view.
  1. When using Division With Adj/Fixed Shelves Component Insert, the wide span material trigger will no longer automatically be applied to these shelves.
  1. Resolved several issues with the ADA Sink Angled Frame product.
  1. Resolved an issue with certain hinge plates where formulas were incorrectly pulling the “mm” custom setback value from the hardware name. The new formula will only pull the custom setback distance when the “@” symbol is used. For example: Hinge Plate BLUM Straight 0mm Knock-In@36mm.
  1. Resolved issues occurring when using both the Top Filler and Top Valance features. Cleat and Filler will follow the location of the cabinet top.
  1. Resolved several reported issues with the Blum REVEGO system.
  1. Resolved an issue with Hawa Concepta III product. Left hand door hinge bore location has been corrected.
  1. Updated the Richelieu Axial drawer system. Graphic now includes the rear brackets.
  1. Added the missing “Blum Tandem Plus 563F 100lb” to the list of Wood Drawer Slide options.
  1. Resolved an incorrectly rendered help image for Upper 2 Door Microwave.
  1. Titus Tekform Slimline drawer system Easy-Fix hole diameter is now 8mm instead of 10mm.
  1. Resolved an issue with the Global Variable workbook that causes most variables to display the incorrect help image (Cells shifted). This has been resolved in the new library install but cannot be corrected by the update utility. Contact support for assistance with getting this resolved (30 seconds to correct).
  1. Added missing graphics for the Lock Olympus N Series Deadbolt Horizontal and Lock Olympus R Series Deadbolt Horizontal. Also added these to the Hardware inventory with machining tokens.
  1. Added missing graphics for the Blum Tandem Plus 563F 100lb drawer runners.
  1. Resolved an issue when using Left/Right Side Full Height sides and Top Fillers.
  1. Resolved issues with ADA Sink Angled Frame product:
    1. Removed incorrect edge banding and added EDGEBAND token to sides with irregular shape to properly account for the banding.
    2. Broke the POLYLINE routes into two tokens, one for machining and one for 3D representation.
  1. Resolved a material issue in Shelves with Shelf Std product. Changing to “Unfinished Materials” will now point the material to “unfinished” material pointers.
  1. Changes to L/R Scribe Filler parts:
    1. Renamed from “Filler Return” to “Filler Panel”.
    2. Remove left and right edge banding when Filler Panel is not flush with face of door.
    3. Added edge band material pointers Base_Filler_Edge, Tall_Filler_Edge, Upper_Filler_Edge.
    4. Material pointers linked to all filler products and subassemblies.
    5. Users will need to specify desired edge band material after update (Default will be None).
    6. Default Construction Method set to “Dado” instead of “G!Default_Construction_Method_FE”.
  1. Resolved issue with Base 2 Door 2 Drawer FF where the intermediate FF drawer stile and drawer being incorrectly positioned when changing the right-hand FF stile. We have also fixed the problem with the drawer stile not showing in the Flat Shot drawings. This was due to a filter on the token filtering out anything with the name “Drawer”. We have changed the name of the part to "Top Mid Stile" from "Top Drawer Mid Style".
  1. Resolved an issue with haunched frame machining when using Left/Right Front Corner choices.
  1. Resolved an issue with Transition and Diagonal FF cabinets. Haunched cutouts will now machine on top & bottom rails for mid stiles.
  1. Resolved an issue with Blind Corner Tall FF cabinets. Handles will now be in the correct location at Right Blind with Right Swing.
  1. The toe kick notches for both the left and right sides have been updated to take int account the "G!Face_Frame_Dado_Depth" when selecting Dado "G!Face_Frame_Attachment_Method_Sides".
  1. Added Drawer Divisions to all Double Top Drawer conditions.
Additions/Resolutions Closet/Wardrobe Expansion
  1. All references to “Extend_Sides_to_Floor” have been removed from machine tokens.
Additions/Resolutions Staircase Expansion
  1. Added a new global variable, “Staircase Cranked Winders” for cranked stringers around the winders.
  1. Added "Split Flight" feature.
To download this build, visit the Foundation Library Downloads Page.
