This update introduces many new global variables. Any existing projects will naturally not contain these new variables, causing issues when adding new products to these projects. Because of this, Microvellum recommends doing one of three options:
- Finish out all projects before updating to this library version
- Update library, then revert the global file within each active project. You will need to redo any previously made global settings.
- Update library, then identify and add all the newly added global variables from the template to your custom project global file. (advanced)
