Microvellum Release Notes: Year of 2026
This document will catalog all releases for Microvellum software builds that are released in the year 2026.
The following release notes apply to Microvellum build 26.1.0702.641.
Dark Mode
Fig. 1: The MV Palette in Dark Mode.
  • To enhance the user experience when working within Microvellum, a new Dark Mode setting has been added to the software. Enabling this will apply a dark theme to most interfaces, allowing for a greater degree of control and customization over one’s software and reducing eye strain when working for extended periods of time. This setting can be enabled within the Microvellum ‘Options’ (Microvellum Settings > Options > General) by checking the “Enable Dark Mode” checkbox, then closing and re-opening the software. Dark mode can be disabled or enabled at any point, but doing so will require one to close and re-open the software each time.
Fig. 2: Enable Dark Mode checkbox.
Face Frame JPG Output
Fig. 3: Create Face Frame JPG Images option.
  • When processing face frame cabinets, it was previously the case that the images of the products would be processed and stored within the data as .WMF images exclusively, leading to issues when attempting to pull the images or analyze them using third party software, which sometimes had difficulty utilizing the format. With the release of this build, a new setting has been added to allow for greater flexibility and control over the output of one's face frame cabinet product images: “Create Face Frame JPG Images”. This setting can be found in the Processing tab of the Microvellum Options. When enabled, face frame product images will be generated and stored in a JPEG format. Users can also control the output size (in pixels) of the image using the ‘JPG Output Size’ box, with values ranging from 100-5000 (default 600).
New Prompt Separator Bars
Fig 4: A control type 11 separator bar in the Product Prompts.
  • A new feature has been added to the UIs of the software. When customizing or working with product prompts or the various wizard interfaces, users are now able to add (via the spreadsheet) prompt-dividing lines, allowing for sections of options to be manually broken up and grouped according to one’s preferences.
  • To add a new divider to the prompts or a wizard interface, open the spreadsheet of the interface (Edit Design Data > Prompts for product prompts, for instance), navigate to the row containing the prompt you would like to have placed above or below the divider, then right-click and insert a new prompt. Add the prompt’s name in the Defined Name column; Microvellum recommends naming this new prompt something like “Separator” or “Divider”. Then, in the Control Type column, enter a value of 11 or 12, and save & close. Re-open the Product Prompts interface, and you should now see a new divider separating the prompts according to how you placed it within the spreadsheet. Repeat this process as many times as desired to group prompts as you see fit.
Fig 5: The separator bar in the Design Data.
  • A control type value of 11 adds the separator bar across all columns within the prompts UI, while a control type of 12 only applies the separator bar to the specific column location of the prompts it is separating, rather than setting the bar across the entirety of the interface.
Fig. 6: A control type 12 separator bar in the same location as Fig. 4.
Product Prompts Improvements
Based on user feedback, the Product Prompts interface has had a few overhauls applied to improve usability, clarity, and cohesion with other interfaces within the software. Some of these changes include:
  • A new layout for Product Prompt buttons and elements of the UI, to better maintain a sense of cohesiveness with other features of Microvellum. The “Redraw Product” checkbox has been removed, with the UI now only featuring only the 3 button options on how to save, redraw, and close the Prompts interface (Save & Close, Save & Redraw, Save, Close & Redraw).
  • It was previously not possible to work with other features of the software while the Product Prompts UI was open. This is no longer the case, and users will be able to interact with and work in other parts of the software while the UI remains active.
  • Users expressed that the scaling and positioning of the UI did not adapt to a full-screen configuration, nor would buttons adapt to the space being expanded upon. This is no longer the case- now, when working in a full-screen window or otherwise altering the size of one’s window, the position of the buttons used for saving, redrawing, and closing the UI will move accordingly.
Annotations in Reports
Fig. 7: Annotations in a composite drawing.
  • As part of our ongoing commitment to improving the efficiency and ease with which users can manufacture products, a software change has been applied that will allow user-created annotations to appear in reports. Annotations that have been added will appear accurately within the product drawing inside of any reports that are generated on the product, provided those annotations have been created using the new annotation tools that have been added to allow for this function.
Fig. 8: Annotation tools.
  • Within the Nesting Tools interface, a new set of annotation tools based on frequently used drawing commands within CAD software have been added. These tools contain popular commands used in the 2D drawing process, such as drawing lines, arcs, polylines, modifying rotation, measuring the length of shapes, adding text, Mtext, and more. Annotations created using these tools can be appended to the product image by clicking the 'Update Annotations' button, which will apply any new annotations to the generated WMF image.
Notes
It is recommended to only add annotations using the annotation tools present in the nesting tools, as annotations added using different methods may not print or appear within reports.
AI Formula Editing
Fig. 9: The new AI formula assistant section of the Formula Editor.
  • A new feature has been added to the Formula Editor: users can now open an AI-assisted chat feature to analyze their formulas for the purposes of explanation, formula creation, formula evaluation, or request recitation of existing formulas. The AI requires user confirmation before any instance of editing can be applied (it will never make any changes automatically, making its use entirely optional) and is fully integrated into the editor without issue. With the AI being integrated into the data of the software, this feature will assist users in streamlining and speeding up any formula related work in the manufacturing process.
  • Users can access this feature by opening the Formula Editor in Edit Design Data (double-click on a formula value) and clicking the “AI” button. Read and agree to the Terms of Use and the AI chat window will open. Some example prompts are available, but users can enter their own prompts in the window at the bottom of the UI.
INNERGY Panel
Fig. 10: The INNERGY panel in the MV Palette.
  • To enhance the interoperability between Microvellum software and INNERGY software, a new live panel has been added to the Microvellum palette displaying information relevant to one’s manufacturing workflow, such as whether one is signed in, time tracking, tasks, recent notifications, search for products or work orders, and what job is currently active, etc. Clicking on any of the options within the panel will open the corresponding INNERGY page, such as the current project. This panel will always be visible on the palette, regardless of the current tab open.
APPLOAD Fix
  • There was an issue reported with the exit timing of Microvellum BSB, wherein the APPLOAD feature of the software would not load correctly after closing the software. This would sometimes lead to any modifications made to the software’s startup via that feature being lost upon closing and re-opening. This issue has been resolved, and should no longer occur.
DPI Scaling Fix
Fig. 11: The issue of DPI scaling affecting the Config Manager (left) and fixed with the update (right).
  • A long-term issue with DPI scaling has been resolved. There has been a recurring issue for users on some display devices, wherein the software window or several interfaces specifically do not scale correctly unless manually adjusted via the shortcut menu (the process for which is documented in the following article). This would lead to issues like specific buttons (such as 'Close', 'OK', etc.) being cut off, and certain interfaces (such as the Configuration Manager) to not have all of their various options appear correctly. This issue has been resolved; multiple interfaces should now scale correctly consistently following adjustment via the steps outlined in the article mentioned previously.
  • Edit Design Data Fix
Fig. 12: 'WorkbookView has been disposed' error.
  • After exiting the Edit Design Data UI, some users experienced an error claiming that the WorkbookView had been disposed, preventing them from properly closing and applying changes made in the spreadsheet. The cause of this issue was determined to be related to the Name Manager feature not closing properly, causing the software to erroneously register issues with the spreadsheet. This issue has been resolved, and the error should no longer appear.
Toolfile Tab Fix
Fig. 13: The IPP settings appearing in the sample spreadsheet tool file.
  • Some users reported an issue that would appear within SS toolfiles, wherein the settings tab for IPP toolfiles would be visible and interactable. This issue has been resolved- IPP options should no longer appear in the SS toolfile interface.
Subassembly Validation Fix
  • When experiencing an error related to a subassembly failing to validate properly in one’s design data, it is expected that the error message will specifically cite the row on the subassembly sheet of the product that the problem is occurring, to allow a user to easily move to it to review the issue. This was found to not be the case, however, as some users reported that the warning error would instead only state the total number of rows on the sheet, requiring one to manually search the spreadsheet to find the issue. This issue has been resolved, and error messages should now pinpoint exact locations they occurred.
BSB Closure Fix
  • Some users reported an issue with Microvellum BSB wherein, even after closing the application, it would continue to run in the background, consuming memory and power to remain running despite not being in use. This issue has been resolved- closing the software should now close it completely.
No Output Fix
  • There was a reported issue occurring in certain iterations of Microvellum AC, wherein label images would not appear or would appear in an incorrect quantity in output locations during processing. This issue has been resolved- label images should appear exactly as anticipated in the correct location.
The following release notes apply to Microvellum build 26.1.0529.641
BSB Docking Size Fix
  • An issue was reported to be occurring in Microvellum BSB 2026: when adjusting the size of a docked Microvellum palette, users found that the palette would reset to its default size after closing and opening the software again, requiring a size adjustment each time. This issue has been resolved and should no longer occur.
Formula Editor Fixes
A handful of issues were noted to be occurring with the formula editor.
  • Users of Microvellum AC reported that the Formula Editor could not be opened by pressing the F2 button on the keyboard as expected. This issue has been resolved, and the shortcut should now work properly.
  • When editing materials in the Material File, some users reported that the Apply Formula button of the Formula Editor would not appear as intended within the interface, leaving them unable to apply their formula changes. This issue has been resolved- the button should appear as expected.
  • Some users reported an issue with Formula Editor wherein hitting the ESC key would not exit the interface as intended. This issue has been resolved, and the key should now exit the interface as expected.
Workbook Find Fix
  • The “Find Next” button within the “Find” feature of Workbook Designer was reportedly having an issue wherein hitting the Enter key would not prompt the command to work. Users hitting Enter would find that it would not trigger the button at all, even if the button is currently selected. This issue has been resolved. Hitting the Enter key should now move from one item to the next.
Saw XML Fix
  • An issue was reported with the output of specific sawing G-code. Namely, when processing a product in a more recent software build, users found that specific lines of code would be dropped from the G-code without explanation. This issue has been resolved. There should no longer be any missing lines of code.
Configuration Fixes
A pair of issues were reportedly occurring when users attempted to switch between configurations.
  • Users who switched between library configurations found that attempting to login using their credentials after the switch would cause issues; the logged in user would not remain logged in and be locked out, even as an admin, the user name would sometimes revert to the first on the list, and there would sometimes be an error when entering one’s password. All of these issues have been resolved. There should no longer be problems with logins, regardless of configuration.
  • It is expected that the password field of the login screen will be cleared of any existing text after switching between users. This was reported to not be the case for some users, with the password text remaining in place even after changing user. This issue has been resolved. When switching users, the password text should now reset.
Microvellum Release Notes | Build 26.1.0520.641
The following release notes apply to Microvellum build 26.1.0520.641.
Assign Render Material
  1. A new option has been added to the Library Specification Groups interface: Assign Render Material. This new interface displays the Microvellum material texture library alongside one’s material file, allowing users to easily and seamlessly assign different material textures to different parts of specific materials in their file. For more information on this feature, visit the following article.
Escape Measurement
  1. An improvement to measuring products has been applied to Product Prompts. Previously, users were able to measure a product’s dimensions by double clicking on the dimension field in the Product Prompts UI, but were unable to cancel this command, even if done erroneously. Moreover, if the incorrect measurement is applied (such as in the case of having activated this accidentally and thus clicking on a random spot), the original measurement is lost. This improvement allows users to cancel the command using the ESC key (as is the case with all commands) at any point, retaining the current value if the command is cancelled.
Colored Formula Parentheses
  1. An improvement has been made to the formula editor in Edit Design Data: formula parentheses will now display different colors to indicate which parts of the formula interact.
Format Formula Text
  1. Another improvement has been applied to the formula editor in Edit Design Data. A “Format Text” button has been added to the interface to allow users to change the formatting of their formula text between the base, existing style and programming style text. This button only changes the formatting and style of the text, it does not apply any other alterations or modifications to it.
Room Name Fix
  1. An issue was reported with the “Draw All Products in Category” option in the Draw tab. After the command was used to draw products in a room, some users found that the room name would fail to appear in the Product Viewer. This issue has been resolved, room names should now appear correctly.
Product Placement Fix
  1. Users reported an issue with products being placed incorrectly in BSB. Specifically, when placing a cabinet against a wall with a polyline drawn perpendicular to the wall, using the polyline as a placement anchor would result in the product being placed in the incorrect location, not set against either the wall or on the polyline. This issue has been resolved; products should now be placed correctly along a selected line.
Pocketing Tool Fix
  1. A machining issue would sometimes occur with pocketing route lines. Some users found that their pocketing routes would collide with regional boundaries (or other routes) after their tools were set to a specific diameter. This issue has been resolved, pocketing routes should no longer collide with 2D boundaries.
Hardware Report Fix
  1. When compiling hardware reports for work orders, some users found that the reports displayed incorrect values for the quantity of hardware attached to buyout materials. This issue has been resolved, and the correct quantity should now display.
Find and Replace Fix
Issues were reported centered around the Find and Replace feature in Workbook Designer. All the following issues have been resolved:
  1. It is expected that this feature will allow users to find the names of materials in the workbook material without issue. This was found not to be the case for some users, with the Find and Replace feature not returning any results when searching.
  2. The Find and Replace feature is expected to be able to replace the name of any non-formula driven material in the workbook. However, some users found that the replacements they made either failed to register or would not be saved after being applied.
  3. Some users reported that this feature was failing to apply changes to their material names, instead received a pop-up alert informing them that a material with the same name already existed in the workbook.
Product Copy Fix
  1. Some users reported an issue wherein a copy of their product’s 3D model would appear when working within the software and redrawing products with multiple interfaces open. This model would oftentimes be generated within the actual Microvellum 3D model, causing issues when attempting to move or modify the product. This issue has been resolved, and this additional shell model should no longer appear in drawings.
Draw Products Fix
Multiple issues involving product drawing have been resolved:
  1.  It is expected that the Draw tab of the Microvellum Palette will do nothing when clicked unless a project is open. It was reported that this was not the case, however, with some users finding that clicking the tab without a project open would result in the software beginning to collect and load moldings.
  2. There was an issue wherein the “Draw Selected Product in New Drawing” option would not appear when selecting products in the Product Viewer.
  3. Some users reported issues of lag or failure to load product groups when opening Microvellum, requiring one to switch away and re-click several times.
Options Lag Fix
  1. Users reported lag when attempting to open specific interfaces, such as the Microvellum Options or Tool File UI. This issue was especially problematic when attempting to open imported tool files. This issue has been resolved, and loading times should generally be faster when opening either interface.
Product List Fix
  1. Users reported an issue that would prevent them from opening the Product List. When attempting to do so, they would receive an unhandled exception error. This would also cause the project currently open to be misidentified as the template. This issue has been resolved, and should no longer occur.
Numerous reported issues centered on the formula editor have been resolved:
  1. The Apply Formula button within the Edit Material interface would sometimes disappear during editing.
  2. The formulas applied would sometimes not be saved correctly, instead disappearing after exiting the Edit Formula interface.
  3.  Some users found that certain cells within workbooks were unable to be edited normally, only being able to change using the Formula Editor upon being clicked, even if the edits involved were not related to formulas.
  4. Redundant and unnecessary options and buttons within the formula editor have been removed.
  5. An issue was reported when editing functions- editing a function should ordinarily maintain the existing formula and change only the specific parts of the formula that were modified. Some users reported that after modifying a function, however, the formula would simply duplicate within the cell, breaking it.
Item Number Fix
  1. An issue was reported regarding item numbers. When a product is drawn, then its scale is changed afterwards, it is expected that the item numbers will scale appropriately with their block’s size. Some users found this was not the case, with the item numbers remaining the same size regardless of the product or block scale, leading to item numbers appearing on the incorrect face or being difficult to read within the product drawings. This issue has been resolved, and numbers should now scale correctly with their blocks.
Docking Fix
  1. Some users reported an issue with the size of the Microvellum palette when using Microvellum BSB 2026. Users who set their palette to a specific size and place in the software found that, upon closing, the palette would revert to its default size and position, failing to retain their modifications. This issue has been resolved; docking should now save modified palette sizes and positions.
Microvellum Release Notes | Build 26.1.0422.641
The following release notes apply to Microvellum build 26.1.0422.641.
BSB 2026
  1. Microvellum BSB 2026 is now available for download and installation by users with an existing Microvellum BSB subscription. This new version of Microvellum is based on BricsCAD Pro 2026 and includes numerous stability improvements and bug fixes related to the BricsCAD platform. Visit the following article for more information on Microvellum BSB 2026.
Adaptive Nesting
Fig. 1: The Adaptive Nesting setting.
  1. A new setting has been added to the nesting options within nest Processing Stations: Adaptive Nesting. Adaptive nesting is a new setting able to be selected from the dropdown menu under “Optimization”. When selected for an operation, Adaptive Nesting runs the batch through Block Nesting, then True Shape Nesting automatically, comparing the results and setting the option that produced higher yield as the outcome. This removes the need for manual trial and error between the two options on the user end.
Dimensioning Fixes
Multiple issues surrounding the dimensioning of products have been identified and resolved.
  1. Users reported an issue wherein the dimensions of certain parts of a product would not appear in section drawings, such as doors. This issue was noticeably only occurring in Microvellum BSB and would only affect a single part at a time, with all other dimensions appearing correctly. This issue has been resolved; dimensioning should now appear correctly on all parts in section drawings.
  1. When creating product sections, it is expected that the Distance in Y from Product Origin to Cutting Plane value would be calculated to be positive. However, some users reported that the value would instead calculate to be negative when attempting to draw an elevation section. This issue has been resolved, and the value should no longer be negative unless specifically input as such.
  1. Another issue would occur in paper space when creating product sections. When drawing a product section with “Draw Facing Right” as the selected orientation, then redrawing the product in model space, the section drawing would disappear, displaying only a product outline. This issue has been resolved, and the drawing should appear correctly in paper space.
Multi-pass Tool Fix
  1. An issue was reported with multipass tools. When assigning a multipass tool to a part via material tool override, then copying parts to a new sheet and updating the G-code/creating new G-code, it is expected that the new G-code will have the same number of setmills/passes as the original sheet. This was found not to be the case, as doing this would instead result in passes being duplicated in the G-code. This issue has been resolved, and duplicate passes/setmills should no longer appear in G-code.
Associate Machining Fixes
A handful of issues relating to associative machining and machining tokens have been resolved.
  1. Some users experienced an issue when attempting to process work orders with cabinets that include both left and right doors. Namely, one of the doors would sometimes fail to have machining appear on it in the composite. This issue has been resolved, and doors should appear correctly in composite drawings.
  1. An issue was reported regarding parts not machining correctly. It is expected to be the case that when creating a work order with 2 parts that are placed on top of each other, both parts will correctly display their machining during cutting. However, some users found that their parts would display without machining in the composite and 2D drawings. This issue has been resolved, and parts placed on top of each other in 2D drawings should have machining appear correctly.
  1. There was a reported issue when creating products with a top and bottom part, wherein sometimes the 2D machining for the top part would not appear, and instead, the machining for the bottom part would be doubled. This issue has been resolved; machining should appear correctly on both the top and bottom of parts.
Grid View Fixes
Multiple issues were reported related to the grid view of the Processing Center, across BSB, AC, and the standalone Processing Center application.
Fig. 2: Batch names sorted incorrectly.
  1. When organizing batches that have been processed via the event log, users reported issues with sorting. It is expected that events and batch names will be sorted alphanumerically in grid view, with times in the event log being sorted chronologically, and batch names being sorted according to the number of the batch (B2, B3, B4, etc.) However, some users found this was not the case, with event logs and batch logs instead being erroneously organized according to the first digit. This issue has been resolved; items should now appear alphanumerically as intended.
  1. When setting up one’s grid view in the Processing Center, it is expected that users can select which columns to see. The most frequent minimum required column is the Project Name the products in the work order are selected from. If users select less than that, it is expected that they will be alerted that they need to select more columns to display, but otherwise, one should be able to save and exit with only the minimum. However, several users reported that attempting to reduce the number of columns selected would cause an error that would result in them being unable to make any column selections. This issue has been resolved and should no longer occur. Columns should be able to be selected without issue.
  1. When hiding specific Processing Stations in the grid view, it is expected that any hidden stations remain hidden once the view is saved. Some users reported that their view would reset each time they attempted to edit a new work order, however. This issue has been resolved, and the view should no longer reset.
  1. Some users had an issue when resizing the Product List UI. Namely, when viewing the Parts List, then resizing the window of the UI, the interface would switch to the Product List tab. This should no longer be the case; the UI should remain on the currently selected tab in the Product List UI.
Microvellum Palette Modification
  1. When switching between tabs in the Microvellum palette, it was previously the case that the Draw tab would reset to the Room Components tab after being switched away from then reopened. This is no longer the case, and the Draw tab will instead display the last vertical tab that was open.
Formula Driven Product Name Fix
  1. When editing the name of a formula driven product, it is expected that altering the name in the formula will alter the name of the product in the Product List. Some users found this was not the case, however, with the name not changing unless one opened and re-opened the Product List interface. This issue has been resolved; product names changed in formulas should result in immediate changes to the name in other connected interfaces.
File Name Fix
Fig. 3: A custom file name repeating and compounding with each batch.
  1. An issue was reported with specific file names. When setting a specific file name for batches via the Custom File Name Field in the IPP Settings, it is expected that the file name will remain consistent and only output what is entered. It was reported, however, that this would instead result in file names compounding with each successive batch, eventually resulting in a file name too long to be accepted as a file path. This issue has been resolved and should no longer occur.
Part List Fix
Fig. 4: A part list jumbled into a single line.
  1. When using the MVPARTLIST command, it is expected that the part list will be drawn in model space in an organized grid format. However, it was instead reported that the list of parts would instead be drawn in a jumbled, illegible fashion, with all the text placed together in a single line. This issue has been resolved; when creating a parts list using the command, it should now display properly.
Specification Groups Fix
Fig. 5: The Vendors option not working when opened in the Solid Stock library.
  1. There was a reported issue with the Vendors option in the Specification Group UI. Namely, when attempting to display information on vendors from the interface (visible from the Material File), clicking on the option would not open any subsequent windows or show any information. This occurred when clicking the option for any material library other than the Sheet Stock Library. This issue has been resolved, and vendors should now be accessible from all material libraries in the UI.
Processing Center Modification
  1. Previously, it was not possible to unhide messages in the standalone Processing Center application, if one selects the “Do Not Show Again” option in the pop-up. It is now possible to show messages that were previously hidden via the General tab of the Options.
System Language Fix
  1. When interacting with the language settings in the Windows setting and changing the Display language to anything other than English, it would sometimes cause users issues, due to language selection altering the layout of one’s keyboard. An error would appear when attempting to process a work order following a change to the language of the system. This issue has been resolved. There should no longer be issues with language changes, though it is still recommended close and restart any Microvellum software after a system language change.
Sawing Report Fix
  1. An issue was reportedly occurring for users utilizing a CPOUT output type for their sawing operations. When using a CPOUT output type and setting the output path to a local location, it was sometimes the case that the file name would not appear in reports, instead being blank. This issue has been resolved; the saw name should now appear as expected in reports.
Gannomat Fix
  1. Users processing orders with a Gannomat Database Writer installed experienced a recurring error with their file paths. Namely, it is expected for the software to alert users who have the MDB writer installed without the Microsoft Access Database Engine installed to receive a pop-up alerting them of this, along with a link to download the engine. Instead, several users found that they would receive an error claiming no database could be created at the assigned path they’d set using the Gannomat writer. This issue has been resolved. Users should now receive the intended pop-up directing them toward downloading the correct database management engine rather than an error.
Microvellum Release Notes | Build 25.2.0406.641
The following release notes apply to Microvellum build 25.2.0406.641.
Label Image Fix
Fig. 1: An error noting an incorrect number of Label Images.
  1. An issue was reported wherein creating new G-code from an existing work order that was edited using nesting tools would prompt an error. Users specifically would receive an error stating that there was an incorrect number of label images. This issue has been resolved- the error should no longer appear in new work orders. However, it should be noted that while this issue has been resolved for new work orders, existing work orders with this issue may still have this problem occur. It is thus recommended to recreate and re-process any work orders that have prompted this issue.
Update Part Fix
Fig. 2: The object reference error upon updating a part.
  1. When changing the processing station during nest editing of a composite, it is expected that parts will update to reflect the changes in processing station rules. However, some users instead experienced an object reference error, preventing the part from being updated properly. This issue has been resolved- this error should no longer occur when attempting to update a part and changing processing stations should result in the expected changes in the composite.
Project Copying Fix
  1. Users reported an issue that would appear when attempting to open room in a copied project. It is expected that when copying a project, all rooms, products, and other components of the project should be able to be opened and altered without issue. It was found by some users, however, that when attempting to open a room in their copied project, the software would freeze, with the Updating Drawing Information progress bar never advancing to the point of closure, preventing them from editing any products or interacting with the room. This issue has been resolved. Copied projects should now be able to open and be modified without issue, and the progress bar should no longer stall.
Part Properties Fixes
  1. An issue was reported wherein attempting to open the Part Properties interface would result in an error occurring in the software. Noticeably, this issue would occur when placing a product with the interface open and repeated even if attempting to do so in a new project or room. This issue has been resolved. This error in the interface should no longer occur, and products should be able to be placed and modified without issue.
  2. There was an issue in Part Properties, which would occur when opening the Part Properties interface, causing an error to occur in Microvellum BSB. This noticeably was only the case in rooms wherein a product was affixed to a wall, and only after re-opening the room. This issue was resolved and should no longer appear in Microvellum BSB.
  3. A similar issue was reported when attempting to redraw products using the Part Properties interface. After closing and re-opening a room, and attempting to modify a product, users experienced an unhandled exception error. This noticeably only occurred when the product in question was connected to a 2D Elevation drawing. This issue has been resolved. 2D Elevation drawings should no longer cause any issues with the Part Properties interface.
Scrap Inventory Fix
  1. There was a reported issue in Microvellum AC, wherein processing would freeze when specific values were set in the Scrap Management section of the Processing Station. Noticeably, processing would consistently freeze shortly before the Commit Scrap to Inventory interface would pop up. This issue also only would occur if the operation was set using Microvellum’s legacy optimizer. This issue has been resolved, and processing should now proceed as normal, without significant issues in scrap management.
Formula Driven Material Fix
  1. An issue was occurring when using the Find and Replace feature in the Material File. It is intended to be the case that formula driven materials are unable to be altered via the Find and Replace feature, due to the necessity of retaining the material name for formula functionality. This was found to not be the case, with formula-driven materials being able to have their names altered, resulting in the loss of the formula (due to the change of the name breaking the formula). This issue has been resolved- formula driven materials should now be unable to be altered via Find and Replace.
Product Prompts Fixes
A pair of issues connected to the recent changes to the Product Prompts UI in Microvellum build 25.2.0317.641 have been reported.
  1. Users who added products to a room via the Product List and then attempted to draw them using the Product Viewer found that the product would not be drawn but instead received a pop-up warning noting that the product was not found in the active drawing. This issue has been resolved- this workflow and process should no longer experience this issue. Drawing a product via product viewer should result in the product being drawn as intended.
  2. Some users reported an issue with filling walls with products. After filling a wall with products, it was sometimes the case that modifying the values of the products would result in one of the products changing its item number to match the first product placed. This issue has been resolved. Additionally, a slight change has been applied to ensure that when working with multiple products, the Product Prompts UI will automatically save and close, as opposed to allowing one to use the “Save” option, to prevent issues with multiple products being drawn or modified.
Fig. 3: The item numbers of the first and last product erroneously matching.
Microvelllum Release Notes | Build 25.2.0330.641
The following release notes apply to Microvellum build 25.2.0330.641
Formula Editor Fix
  1. There was a recurring issue wherein attempting to edit any formula within the Part Properties of the software would result in an error. This would only occur when attempting to edit a formula within Part Properties specifically. This issue has been resolved and should no longer occur for users attempting to edit formulas in Part Properties.
Product Prompts UI Fix
  1. Some users reported experiencing an issue with some of the new features added to the Product Prompts UI in Microvellum build 25.2.0317.641. Namely, the “Save” button and “Redraw Products” checkbox would sometimes disappear after editing or drawing a product for the first time in a session. This issue has been resolved- the button and checkbox should now remain visible even after the initial drawing.
  1. An issue with the Product Prompts UI was reported wherein hitting the Enter key multiple times within the interface would result in an unending loop of errors occurring in succession, requiring one to restart the software to fix. This issue has been resolved and should no longer occur for users
Template Fix
  1. There was an issue reported by users utilizing the Microvellum 2D template. Namely, during processing, users would experience an error when attempting to nest on Toolbox AC Standard in more recent builds, stating that there was a duplicate record name in the software. This issue did not occur while using Microvellum BSB. This issue has been resolved- a coding adjustment has been applied to Microvellum AC to prevent this issue from happening.
Perfect Graining Fix
  1. Users reported there was a problem with specific saws, wherein operations with perfect graining using specific saws as one’s output would generate G-code with no perfect graining information. This issue has been resolved, and perfect graining information should now appear correctly.
  2. Another issue with perfect graining was reported, wherein some users who selected “Combine CSV XLS” as their conversion type would experience an object reference error during processing. This issue has been resolved, and this error should no longer occur.
Error Warning Fix
  1. When experiencing a processing error during an operation, a pop-up warning alerting users to the error should appear, with a “Do Not Show Again” checkbox within it that allows users to prevent warnings from appearing again. Some users reported that this was not the case, with the various error warnings not having the checkbox present, leading to issues of warning pop-ups appearing repeatedly. This issue has been resolved. The "Do Not Show Again" box should appear whenever appropriate in pop-up warnings.
Vertical Drill Hole Improvement
  1. Users reported an issue with slow nesting speed due to the optimizer processing vertical drill holes less efficiently. To address this, compounding on the improvements made in Microvellum release 25.2.0317.641, further improvements have been made to the optimization results of the vertical drill hole optimizer. This may result in more precise and efficiently drilled hole groupings, though results will still vary depending on the tool configuration of one’s specific machine.
Toolfile Fixes
Multiple fixes were applied to issues reportedly occurring during processing that were specifically related Toolfiles and Processing Stations. The following issues have been resolved:
  1. An issue was reported wherein barcodes would erroneously be optimized with incorrect barcode numbers. Products with specific barcodes to indicate grouping would sometimes have characters (most often the prefix or first number of the code) drop from the number, leading to incorrect barcode data.
  2. There was reportedly an issue occurring for some users wherein work order processing would be interrupted by an error with the product or part geometry, resulting in the batch being unable to complete.
  3. There was a reported issue by users who attempted to process new G-code created from the composite of a completed work order, wherein elements of the data such as label position would inexplicably change in the data, leading to the operation stalling.
  4. An issue with tool compensation was reportedly occurring wherein the tool compensation of specific tools would sometimes be applied to the incorrect side of a part.
  5. Some users experienced an issue wherein border route machining would sometimes disappear. Namely, after modifying a work order and altering the position Face 6 machining, Face 5 border routing would be removed from the subsequent batch.
  6. An issue was noted with the image output of sawing tools within the Processing Station. When setting the image file paths of a sawing tool, it is expected that the file path settings will be preserved and occur regardless of whether the saw tool is used in a saw processing station or another type. However, it was noticed by some users that the image file would not be generated at the expected location when using a processing station other than the saw processing station.
  7. An issue was occurring during drilling operations, wherein some users would receive an error during processing stating that no drills are available within the software that can reach machined holes.
  8. Another issue with processing routes was reported, wherein parts with routes that were given an offset value would cause a collective error.
  9. An issue would sometimes occur wherein routes and routed holes processed in a batch with IRIB enabled would have erroneous tool compensation, resulting in incorrectly placed routes or holes.
Optimizer Fixes
Multiple fixes were applied to issues reportedly occurring during processing that were specifically centered around the Microvellum optimizer. The following issues have been resolved:
  1. An issue was sometimes occurring during processing, wherein users would get an error message informing them that a material with perfect graining enabled was not found in the work order and therefore couldn’t be added to the perfect grain container.
  2. There was a reported issue with block nesting. Namely, when attempting to optimize using block nesting with the Max Qty Per Sheet setting at its minimum value (1), some users found they received multiple errors that interrupted optimization.
  1. A similar issue would occur for users attempting to process operations using Metric configuration, wherein an error would repeatedly appear stating that there were no suitable parts in the order. Both issues were resolved using the same fix.
  2. An error would sometimes occur when processing work orders using the Multi-Run Optimization option, with an error popping up stating that a specific number of parts were placed correctly without clarification.
  3. There was a reported issue occurring for some users utilizing specific processing stations for nesting their parts, wherein parts would sometimes not be placed correctly within the nest, resulting in an error.
  4. Users reported an issue processing certain parts in sawing operations, with the error claiming the perfect grain container in the operation was too large for any of the material sheets available, regardless of whether appropriate materials were available or not. This would result in the nesting operation being interrupted and unable to complete.
Microvelllum Release Notes | Build 25.2.0317.641
The following release notes apply to Microvellum build 25.2.0317.641
Product Prompts UI Overhaul
The Microvellum Product Prompts interface has been redesigned to improve efficiency and usability, giving users greater control over multiple features of their products. All existing functionalities of the interface remain intact, and a handful of new changes have been added:
  1. Changes can now be saved without closing the UI. Additionally, a checkbox (“Redraw Product”) has been added to allow one to control whether the product should be redrawn when its prompts have been altered and saved.
  2. Prompt tabs now stack vertically rather than horizontally in the interface, eliminating the need to use directional arrows to navigate to the tabs of the interface.
  3. The Product Details section (item number, quantity, angle, comments, etc.) has been relocated to a far more visible location on the lefthand side of the interface.
  4. There is an additional Prompt Help Text box, which retains the Help Text of the last option hovered over in the interface, allowing users to copy and paste descriptions and tool tips.
  5. There is now a setting under Microvellum Settings > Options > General called Product Prompts, which controls the width of Columns 1 and 2.
Work Order Creation UI Overhaul
The Work Order creation interface has been given an overhaul to improve usability and enhance visual cohesion. All existing functionality of the interface remains intact, with nearly all changes having been made to feature location.
  1. Buttons within the interface which open sub-menus (such as Configure Name) have been relocated to the upper right-hand side of the UI to ensure they are grouped in a single location.
  2. The Parts Group and Default Status dropdown menus have been relocated to the center righthand side of the UI for easy and quick access to either option.
  3. A new Comments field has been added to the interface (having been removed from the Properties Interface) to allow for a much faster, easier experience, adding comments to work orders. The comments entered in this field are saved upon work order creation and can be updated if the work order is modified (existing work order comments will appear in this interface as well).
  4. Additionally, the comment field has been modified to warn users if they exceed the 255-character limit for work order comments, with work orders not being able to process until the character count is reduced, ensuring that no comments are altered or entered incorrectly, as previously, comments would simply cut off after meeting the character limit.
  5. The Work Order Name and Select Recent Name fields have been moved to the top left-hand side of the interface.
  6. All checkbox creation options and Microvellum Server checkbox options have been set in the center of the interface, for easy access.
Use Onion Skin 900 Tools
  1. Previously, when using 900-series tools (multiple tools or multi-pass tools), the software was unable to support the use of the Leave Onion Skin option within Small Part Handling (leaving a thin layer of material from the first cut of a double pass for the second cut to remove). This has changed in this update, with a new checkbox, “Use Onion Skin” being added to Toolfiles when selecting a 900-series tool. This new checkbox will not function unless the “Leave Onion Skin” option in the Small Parts Handling section of the Processing Station is enabled simultaneously. When a 900-series tool is used as the Nest Border Tool and if both checkboxes are enabled, the final pass of a tool will leave the specified onion skin thickness rather than machine to full depth.
SQL Express 2025
  1. Users working on a server configuration reported issues with errors occurring when attempting to run their software. Specifically, SQL Server Express 2025 would have an issue with attempting to load configurations, with users who attempted to do so experiencing a null data error. This noticeably only occurred when using the Express edition of SQL Server 2025. This issue has been resolved- utilizing SQL Server Express 2025 should no longer cause any errors within the software.
Work Order Comments Filter
  1.  When searching through large work order databases, it can sometimes be difficult to navigate or locate specific information due to the presence of many comments within multiple work orders.  To resolve this issue, a new filtering feature has been added to the Work Order Selection interface when modifying an existing work order. This checkbox, “Search Comments”, places a filtering for specific text entered in the Search Bar, allowing users to search for specific words or characters within comments of their work orders, to better locate specific work orders within one’s database.
Work Order Permissions Modification For Label Only Access
  1. A new setting has been added to the Employee Permissions interface, to allow for better control over which employees can process work orders, load parts, or manage scrap. The “Work Order Processing” permission has been added to the Employee Permissions interface under the Work Order section. If this permission is left disabled, the employee in question will only be able to print labels within the Processing Center.
  2. Additionally, the “Access Production” setting within the Module Access section has been renamed and relocated. This checkbox allows the employee in question to log into and utilize the functions of Microvellum Production and the Processing Center as a whole. The setting has been renamed to “Access Work Order” and moved to the Work Order section of the Employee Permissions interface.
  3. Both changes have been applied to the standalone Processing Center application, as well as Microvellum AC and BSB.
Block Nesting Improvement
  1. The efficiency of block nesting with Microvellum’s optimizer has been improved. Previously, it was reported that the current optimizer was less effective at calculating material sheet stacks during block nesting optimization than the legacy optimizer. To address this issue, the maximum quantity of sheets per stack has been increased within the coding, and a new slider has been added to the Nest Processing Station’s optimization section: “Sheet Quantity Preference”. This slider functions similarly to the “Stacked Material Preference” slider in the Saw Processing Station but applied to block nesting specifically to allow for general control over whether the optimizer prioritizes yield or quantity of stacked sheets during the operation. This setting may thus result in a significant improvement in the number of stacked sheets when using block nesting.
  2. The slider will be greyed out whenever the Max Quantity Per Optimized Sheet text box is set to a value of 1 or less. If a value of 0 or less is entered, the text box will automatically raise it to a minimum value of 1. Previously, if the value was set to 0, it would reset to a default value of 5 when the Processing Station was closed and re-opened.
Saw Delimited Setting Fix
  1. Issues were reported with specific settings disappearing when viewing them in the processing station interface. Users who set their output type to “SawDelimited”, then assigned custom values to the saw and processed the work order found that while their custom values are visible in the XML file and processing, they would not appear in the Saw Processing Station when reopened so it appeared blank, leading to confusion. This issue has been resolved - custom values assigned to saws should appear appropriately within the values column.
Move Part Warning
A warning has been added to the nesting tools when a part that has been moved is set to overlap with another part. When a part is detected to overlap another part, a pop-up warning will alert users, and present the following options:
  1. Yes.  Allows you to move the part
  2. No.  Places the part where it currently is
  3. Cancel.  Returns the part to is original location
Nest Editing ESC Error
  1. An issue was noted with the nesting tools, wherein moving parts, then canceling the command with the Esc key would cause an error. This issue has been resolved- canceling a command after moving a part should no longer result in an error.
Label Creation Fix
  1. There was sometimes an error that would occur for users attempting to process work orders, wherein setting the work order to generate labels would sometimes result in the order failing to process successfully, instead causing an exception error. This issue has been resolved- users should no longer experience this error when generating labels as part of processing a work order.
Optimizer Fixes
Multiple fixes have been applied to Microvellum’s Optimizer. The following issues have been resolved:
  1. New coding has been added to identify parts as FromPerfectGrain. Perfectly grained parts now have a number assigned to identify them to the software.
  2. There was a reported issue with optimizing parts that had perfect graining assigned to them, with parts sometimes failing to align correctly, and perfect graining containers sometimes disappearing from the composite.
  3. When using the current optimizer, there was sometimes an issue with specific parts (such as wall components) being erroneously rotated at random.
  4. Users reported an error occurring when attempting to launch nesting operations with products from more than 1 project as part of the work order.
  1. An issue would sometimes occur with parts in sawing operations. When parts in a sawing operation had perfect graining applied, steps in the process such as trimming would sometimes fail to apply correctly. This would sometimes result in the trim failing to register, while at other times, it would result in other parts being cut into.
  2. An issue would sometimes occur during nesting operations, wherein parts with perfect graining applied would sometimes grain match incorrectly, resulting in incorrectly placed parts or software errors to occur.
  3. Users would sometimes experience an error when processing certain parts, with the error stating that “Materials were not supplied”.
  1. A slight grammatical error between the nesting and sawing processing station, the name of the multi-run optimization setting, has been amended. Previously, the setting was referred to as “repeating optimization” in the sawing processing station, and “Enable Multi-run Optimization” in the nesting processing station.
  2. When optimizing with Trueshape enabled, it was sometimes the case that certain parts would cause the optimizer to fail to place any parts, without any warning or alerts regarding the issue.
  3. All of these issues have been resolved, and should no longer occur for users.
Machining Fixes
  1. Users reported an issue when Destroy Offal is turned on with True Shape set to high it was cutting into other parts. This issue has been resolved- parts should no longer be cut into due to the Destroy Offal setting. This also fixed an issue with Shadowline cutout widths varying.
  2. An issue was reported regarding incorrect part machining applied to parts rotated at specific angles. Namely, parts that were machined that were rotated at diagonal angles would sometimes be machined incorrectly, resulting in incorrectly cut parts.  This has been resolved.
  1. A related issue was reported wherein users would have vectors of their routing machining drop during processing. Notedly, this would only occur when processed with the Machine Cannot Offset Routing (MCOR) setting enabled.  This has been resolved.
  1. An Offset Polyline issue was reported wherein extra vectors (and thus, routes) would be incorrectly added to 2D drawings, causing incorrectly shaped parts. This issue has been resolved- a coding fix was applied to enhance the software’s ability to determine whether a route is a pocket. Additionally, the default value of parameter 4 in the PLINE5 machine token has been modified from 3;0;1;0;0 to 3;0;3;0;0.
Processing Center Improvements
  1. The Processing Center standalone application is now capable of being opened without requiring a work order to be loaded within the software. A new “Continue” button has been added to the login UI of the application to allow users to open the application without first loading a work order.
Improved Vertical Drill Optimization
  1. An improvement has been made to the optimization results of the vertical drill hole optimizer. This may result in optimal hole groupings, though results will still vary depending on the tool configuration of one’s specific machine.
Microvellum Release Notes | Build 25.2.0223.641
The following release notes apply to Microvellum build 25.2.0223.641.
Add 2D Elevation Tokens to 3D Drawings
Fig. 1: The new 2D Elevation setting.
  1. A popularly requested feature by the community has been added to the Microvellum software: the checkbox Add 2D Elevation Tokens to 3D Drawings is now available under the Drawing Preferences section of the CAD tab. This setting, when enabled, creates a 2D Elevation Drawing automatically when the 3D model of the product is drawn. This setting can be enabled simultaneously with the identical function that adds 2D Plan tokens, provided one’s drawing preferences are set to a 3D setting.
Fig. 2: The new 2D Elevation Tokens to 3D Drawings option enabled.
Processing Center Application
  1. A new Microvellum software application has been released: the Processing Center. The Processing Center application is intended to give users access to the full suite of Microvellum’s existing manufacturing tools to process existing work orders, independent of any existing CAD-based applications. It is intended to provide users with an enhanced experience and act as a replacement on the shop floor for applications like MV Production (or MicroManager). For more details about the Processing Center application, visit the following article.
Processing Center Ribbon
Fig. 3: The Home tab of the embedded Processing Center's ribbon.
Fig. 4: The Labels & Reports tab of the embedded Processing Center's ribbon.
  1. In conjunction with the release of the standalone processing center application, the processing center within Microvellum AC and BSB has received an update to improve usability. The Processing Center (both in the standalone application and embedded into the software) has had a ribbon added to the top of the UI to grant users a fast, easy means of accessing the most used functions within the system. Users can now select part loading, work order management commands, scrap options, labeling and report options, and more instantly without needing to open a separate menu.
Microvellum Release Notes | Build 25.2.0213.641
The following release notes apply to Microvellum build 25.2.0213.641
File Name Fix
  1. An issue was occurring when processing work orders with the Create Sequential File Names setting enabled. When the setting was enabled, a work order being processed would sometimes experience an error, causing the batch to be deleted. This issue has been resolved, and this error should no longer occur when creating files with sequential names.
Product Processing Fix
  1. Users reported an issue occurring when processing work orders using custom tool files, wherein they would sometimes experience an error when processing simple parts (such as the Misc Panel). This issue noticeably did not occur with builds prior to 25.2.0204.641. This issue has been resolved- the error should no longer occur when processing parts using custom tool files.
  2. An issue was reportedly occurring wherein certain work orders would experience an error during processing. This issue was determined to be related to database coding, and as such, has been resolved. Work orders should no longer elicit this error.
Composite Fix
  1. It is expected when updating G-code of a work order that the composite drawing of that work order will be updated to reflect any changes. However, an issue was reported wherein users found that updating the G-code of a work order with the composite drawing open would cause the software to experience an object reference error and crash. This issue has been resolved. G-code modifications should now result in the composite changing as intended.
Xilog File Generation Fix
  1. There was a reported issue with generating files using Xilog Writer. Users who set up their G-code to generate using Xilog Writer would sometimes have the path to their G-code fail to be generated in the correct location on more recent builds. This issue has been resolved- all files set to generate with the Xilog conversion type should now generate correctly in the proper location.
Microvellum Release Notes | Build 25.2.0206.641
The following release notes apply to Microvellum build 25.2.0206.641.
Item Number Fix
  1. An issue was reported regarding item numbers in composite drawings. Users who processed work orders with multiple products reported that the item numbers would sometimes universally be set to 1.00 in the composite, regardless of the actual item number. This issue has been resolved- item numbers should no longer be set to the same number in composite drawings or any data.
Database Explorer Fix
  1. There was a reported issue with the S (subassemblies) workbook, wherein the S workbook would sometimes not appear within the Database Explorer, preventing users from modifying their subassemblies through that utility. This issue has been resolved, and the S workbook should now appear within the interface as expected.
Microvellum Release Notes | Build 25.2.0204.641
The following release notes apply to Microvellum build 25.2.0204.641.
Toolbox Brand Retirement
  1. As part of Microvellum’s ongoing alignment with the values and catalog of INNERGY, and to improve user experience, clarity, and consistency, we have updated our terminology within the software and documentation. The brand name “Toolbox” is being retired, and Microvellum’s all-in-one CAD/CAM software platform will instead be referred to as “Microvellum."
Update Improvements
  1. Multiple redundant material hatch .pat files have been removed from the update process of the software. This will ideally prevent specific custom preferences from being overridden, as well as eliminate a handful of issues caused by these files.
Subassembly Fixes
A couple of issues concerning the functionality of subassemblies were reported and resolved. The issues are as follows:
Fig. 1: The name variables appearing in spite of the subassembly not being loaded.
  1. When working with subassemblies in a product’s spreadsheet, it is expected that a subassembly needs to be loaded to edit variables like the subassembly name within the Edit Formula box. It was found that this was sometimes not the case, with some subassemblies not being loaded having no effect within the interface as to whether name variables would show.
Fig. 2: Two S workbooks appearing in Workbook Designer.
  1. When opening workbook designer after editing subassemblies, it is expected that only the latest subassemblies accessed will appear in the interface. Instead, it was found that two or more S workbooks would sometimes erroneously appear in the interface.
  2. Both issues have been resolved. Altering subassemblies should no longer result in this issue of multiple S workbooks, and Subassembly variables should display correctly when the subassembly is not currently loaded.
Splash Screen Fixes
Multiple issues centered around the Microvellum splash screen login UI have been resolved. The following issues should no longer occur:
  1. Users would sometimes experience an error when switching between configurations on the splash screen. This would noticeably occur when switching between configurations with different login requirements.
Fig. 3: The incorrectly spelled "Sofware Build".
  1. A grammatical correction has been applied to the software build section of the UI, which displays the current software build being run. The word “Sofware” has been replaced with the correct “Software”.
  1. When launching two instances of Microvellum software simultaneously, it is expected that they will both be capable of running separately (though this is not recommended). Instead, it was reported by some users that having the splash screen of both programs opened simultaneously would cause an error.
  1. An input issue with the login screen caused users to be unable to enter their password by hitting the Enter key, instead requiring them to use their mouse.
  1. The Update Available indicator on the splash screen had an issue wherein it would erroneously alert users of an update being available, even if there was none.
Report Groups Fix
  1. Users reported an issue wherein Microvellum BSB would experience errors and crashes while processing work order reports in a report group. This would only occur when a report group was assigned to the work order. This issue has been resolved and should no longer occur.
Hatch Pattern Fix
  1. When renaming a hatch pattern, it is expected that the software will register the pattern as missing and alert the user of this without issue. However, some users reported that when the hatch pattern name was changed, rather than being alerted, the software would crash. This issue has been resolved- the software should now instead only alert a user when a hatch is missing. Additionally, the alert message warning users that their hatch pattern is missing has been improved, increasing the specificity and clarity of which hatch is missing or causing the issue.
Drill Fixes
A pair of issues centered around drilling and the processing of drilling operations were resolved. The issues were:
  1. When processing drilling operations using specific values for vertical drills in one’s Toolfile, there was sometimes an error wherein the software would be unable to detect any drills capable of reaching the hole values, even if the drill’s maximum value should allow it to achieve that.
  1. When setting up a drilling operation, it was found that banking holes would sometimes fail during processing, with specific hole geometries. Banks with specific numbers of holes would sometimes drop one during processing.
  1. When opening the About Microvellum interface and attempting to create a support case (using the Create Support Case button), it was sometimes the case that the browser would open the page twice. This issue has been resolved. When creating a support case via the software interface, the page should only open a single time, as intended.
Batch Number Fix
  1. In the batch options of the processing station, it is expected when interacting with the + key of the interface that the batch number will increase accordingly with the number of times the + key is clicked. However, it was found that the button did not properly function in this regard, with the + key not increasing the batch’s name value as expected. This issue has been resolved- the + key should now increase the number of the batch name by integers of 1 (if there is a number in the batch name).
Associate Product to Wall Fix
Fig. 4: The error that appears when double clicking the option.
  1. There was a reported issue with associating products to walls. When double-clicking the option to do so in the Modify tab, rather than giving the expected warning that the command line was still active, users would instead experience an invalid input error. This issue has been resolved. Users will now receive a warning that the command line is still active.
Nesting Fix
Fig. 5: The nesting error occurring with specific tool files.
  1. Certain processing stations and tool files were reportedly having difficulty fully processing a work order. When trying to complete an operation using specific nesting tool files, it was sometimes the case that the operation would experience an error, causing the current batch to be deleted. This issue has been resolved; this error should no longer occur when processing work orders.
Product Prompt Fixes
A handful of issues surrounding product prompts were resolved with this build. The following issues should no longer occur:
  1. When copying a product with bays between rooms using the product viewer, it is expected that the product will update accordingly and correctly when being redrawn in the new room. However, it was found that products with bays would sometimes calculate incorrectly when redrawn.
  1. When working with product calculators in the spreadsheet, it is expected that the values of various calculators being left blank will not affect any associated calculators. Users reported an issue wherein having blank values in one calculator would cause the calculators after them chronologically to be unable to open.
  1. Product bay size would sometimes calculate incorrectly when altering specific dimensions of products. For instance, a product with bays would sometimes fail to recalculate the size of those bays accordingly when the width of the product was increased.
Fig. 6: The product angle prompt in the interface.
  1. When working with prompts, it may sometimes be necessary or desired to control the angle of the product as it is placed on a wall. As such, products have a prompt to control product angle (ProductAngle), which can be added to the Product Prompts interface through modification. However, it was found that this prompt would sometimes not function correctly, with the product not filling in the angle correctly when this prompt is defined within the design data.
Post-Processor and Optimizer Decoupling
  1. The machine code post-processor and optimizer have been decoupled from Microvellum’s core codebase. This architectural update allows the post-processor and optimizer to operate independently, enabling integration with both Microvellum and INNERGY DESIGN in a disconnected state.
  1. This change improves modularity and long-term maintainability while providing greater flexibility for how machine code generation and optimization are deployed across platforms.
Microvellum Release Notes | Build 25.2.0114.641
The following release notes apply to Microvellum build 25.2.0114.641
Processing Center Message Fix
Fig. 1: An error message running in the background of the software.
  1. An issue was reported within the Processing Center. When processing an order, there would sometimes be an issue wherein error alerts or pop-ups would not appear within the interface, but instead in the background of the program. This could lead to situations wherein users would sometimes assume the software had crashed or frozen during processing, prompting unnecessary shutdowns or closure. This issue has been resolved, and alerts should now appear directly on screen when processing work orders, as intended.
Optimizer Change
Fig. 2: The new checkbox to enable the legacy optimizer.
  1.  Microvellum’s Beta process for the new optimizer has concluded. With this, the Beta Optimizer has been set as the default option for optimization and will be referred to as the standard Microvellum optimizer in the future. To reflect this change, the option to use the Legacy optimizer has been changed in the interface from a drop-down menu to a checkbox.
Saw Trim Value Fix
  1. When processing a sawing operation using Microvellum’s current Optimizer, an issue would sometimes occur in which two values would be incorrectly controlled by a single option. When setting the value of the Leading Length of a part, it was sometimes the case that the Leading Width would be set to the same value, with the “Leading Length” option controlling both options. This issue has been resolved; the Leading Length value should no longer affect the Leading Width value.
Label Output Fix
Fig. 3: The "Shorten Gcode Output Path" setting in the Tool File interface.
  1. Users reported an issue with the Autolabeling setting, wherein label image files would sometimes be placed in the incorrect location. When “Shorten GCode Output Path” option is enabled, it is expected that all output files will be placed a single assigned folder location, being added to multiple newly created subfolders. Some users instead found that even with the setting enabled, new subfolders would be created for label image files. This issue has been resolved, and should no longer occur. With the setting enabled, label image files should be placed in a single folder, as intended.
Module Access
  1. In alignment with Microvellum’s new values-focused announcement on January 14th regarding changes to how Microvellum is packaged, this update provides access to all Microvellum Software Modules and features to any Microvellum user with an active subscription or current Support and Maintenance plan. This ensures full availability of tools across design, drafting, engineering, and manufacturing workflows without requiring separate module access. Users who update to this build will see the list of modules they previously purchased and which ones have been unlocked in the UI only once during the first startup of the software after updating. After the initial startup, this list will no longer appear, as all features and modules will be unlocked, removing the need for a module list.
About Microvellum UI Overhaul
Fig. 4: The new layout of the "About Microvellum" UI.
  1. Accompanying Microvellum’s subscription model changes, the About Microvellum interface has undergone a visual change, relocating multiple options to a more linear, seamless list, as well as removed the module tracking section of the interface, due to the full integration of all Software Modules.
